tom_hd02 Samba Member
Joined: July 09, 2013 Posts: 53 Location: Massachusetts
Posted: Thu Mar 26, 2015 6:31 am Post subject: H30/31 and 034 SVDA....amazing performance |
I know, I know.... the title sounds like a science fiction movie, but, how could this be possible?
Yesterday I installed a H30/31 carb (125 main, 65 angle jet, 50 right side jet) with a Chinese 034 SVDA distributor on my bone stock 1600cc dual port engine. The engine performance was incredible. I timed the distributor at 7.5° BTDC at idle and 30° at 3500rpm with vacuum line disconnected (max advance is 40° with vacuum line connected). I know this carb and distributor don't match, but how can this be possible? The engine runs better than ever, pulls strong, great acceleration, way much better than a 34pic3 with the same distributor. I got the feeling that this is to good to be true. Could I be hurting the engine by running this combo? Is too much advance bad for the engine?
All opinions are welcome.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Thu Mar 26, 2015 6:55 am Post subject: |
The H30/31PICT should not be providing enough vacuum to cause the canister to add advance under load.
What you could be feeling is just the mechanical part of the distributor.
What distributor did you have before? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Mar 26, 2015 7:19 am Post subject: |
I was running the h30/31 with 205T vacuum only distributor. It ran ok, but not that well. After that, I installed a 34pic3 with a 034 distributor, great mid to high rpms, but I couldn't get rid of the flat spot and hesitation at low rpms. That's when I switched to the the h30/31 with the 034 just to see how it ran. |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Thu Mar 26, 2015 10:05 pm Post subject: |
You shouldn't be getting too much advance. More than likely you're not getting enough. Can you plug the venturi port for the vacuum advance? But then again, if you like it you should probably leave it alone. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Frank Bassman Samba Member
Posted: Thu Mar 26, 2015 10:10 pm Post subject: |
This is truly mind-boggling. To tell you the truth, I've seen bastardized engines running an svda with a h30/31.... usually accompanied by a very high idle. (I'm talking 1100 rpm range) Do you have an uncharacteristically high idle? (Above 800-900 rpm?) If so, what you may be feeling is the centrifugal advance only doing its dance while not even using the vacuum can, since that's centrifugal advance rpm territory.
Or maybe, the Chinese finally came up with a vacuum-centrifugal distributor that actually does work with the H30/31...
But I highly doubt that. |
XXX/Rx/RnR Samba Member
Joined: March 01, 2008 Posts: 405 Location: valley of the sun
Posted: Thu Mar 26, 2015 11:48 pm Post subject: |
I have a 034 with that carb. Mine came from aircooled .net and was setup for the t-4 in my baywindow with fi and it runs great. Timed at 28 degrees with hose off and plugged full throttle. Hose on advances to bout 40. Used the scale off the bus to mark the pully. Advanced the same in the bus. I can't tell any difference between the 205an that was in there and the 034 that's in there now. _________________ 78' westy, 2.4 195hp ecotec, audi turbo a/t, a\c, 2 1/2" lift spindles, index rear, 930 cv's & axles, 225x65x17 BFGs ## 77' hardtop 2.0 T-4 duel 44 weber's, 225x50x17s ## 74' baha bug |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Fri Mar 27, 2015 2:19 am Post subject: |
OP, where are you connecting the vacuum advance hose on the carb?
Normally, vacuum advance connects to the left side vacuum port on the Pict carbs ("A" in the above pic). For many Pict-3 carbs this is "ported vacuum" from just above the throttle plate. For the Pict-1 and H30/31 carbs this left side port is "venturi vacuum" from the narrowest part of the carb throat (very small changes in vacuum which increase with air speed flowing through the throat).
If you are connecting your vacuum advance hose to one of the rear facing ports of the carb (probably B in the above pic) it will see intake vacuum. This vacuum responds nearly the same as the SVDA distributor expects... at speeds above idle. But at idle, the SVDA vacuum can will see more vacuum than expected. The result will be increased idle rpms and the timing readings with vacuum hose connected will be much higher than typical at idle. _________________ AshMan40
wcfvw69 Samba Purist
Posted: Fri Mar 27, 2015 5:54 am Post subject: |
The H30/31 carb usually matches well with the 205T or 205K vacuum only distributors. If your motor is dual port and running a dog house fan shroud, you shouldn't be running either of these vacuum only distributors as they retard 3* on number 3 cylinder. This was for the single port motors that were not running doghouse fan shrouds and had the oil cooler in the way of cylinder 3 cooling air.
Back to your distributor. In most cases, the 205T has never been cleaned and serviced during it's life time and will have a frozen or a very sticky advance plate in it. As a result, the vacuum can struggles to advance the timing and you have a poor running engine.
I'm currently running a H30/31 carb with a German made 009 distributor. It runs perfect. No off idle hesitation or any other issue. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Mar 27, 2015 7:46 am Post subject: |
Frank: The idle ranges between 900 and 1100 rpm (which is unusual). With the 205T the idle was very stable at 850-900rpms. I’m still trying to fine tune the idle. At what RPM does the centrifugal advance kick in?
Ashman40: the vacuum hose is plugged in to the “A” port. I have a vacuum gauge; I will hook it up and measure both “A” and “B” ports at idle and report the results.
wcfvw69: I disassembled, cleaned, and lubricated the 205T. The advance plate moves freely. I installed a petronix points replacement, which (supposedly) eliminates the 3° retard on #3 cylinder. The engine runs fine with the 205T, but not as strong as with the 034. |
Posted: Fri Mar 27, 2015 8:14 am Post subject: |
tom_hd02 wrote: |
Frank: The idle ranges between 900 and 1100 rpm (which is unusual). With the 205T the idle was very stable at 850-900rpms. I’m still trying to fine tune the idle. At what RPM does the centrifugal advance kick in? |
Anywhere above 1000rpm. It depends on spring tension and friction in the mechanical advance.
tom_hd02 wrote: |
Ashman40: the vacuum hose is plugged in to the “A” port. I have a vacuum gauge; I will hook it up and measure both “A” and “B” ports at idle and report the results. |
Good test. I would expect at idle the vacuum on "A" would be zero (or very nearly zero).
For your H30/31 the vacuum should increase as airflow/engine rpms increase. Max vacuum from the H30/31 should be in the 3-in-Hg range at higher rpms.
If you had a Pict-3 carb I would expect this "A" port to read zero at idle. As soon as you opened the throttle plate the "ported vacuum" would see intake vacuum and be the same as one of the rear facing vacuum ports (intake vacuum ports) with a max intake vacuum in the 12-in-Hg range. This is why the Pict-1 "A" ports typically don't make enough vacuum for SVDA distributors to fully advance.
If you find that your H30/301 is not creating enough vacuum for your SVDA distributor to reach max vacuum advance of +12deg, you could try connecting it to one of the rear facing ports that are "intake vacuum" and see how it runs. _________________ AshMan40
Posted: Fri Mar 27, 2015 9:38 pm Post subject: |
ashman40 wrote: |
If you are connecting your vacuum advance hose to one of the rear facing ports of the carb (probably B in the above pic) it will see intake vacuum. |
I like this idea! _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
