Charlo Samba Member
Joined: March 19, 2015 Posts: 50 Location: Southwest Oregon
Posted: Thu Mar 26, 2015 10:48 am Post subject: 69 Type 1 - seat belts & wing windows |
Hello Samba-Land!
Getting going on my new acquisition/project...
I've been reading through the original!! owners manual, and notice a couple items straight away.
1. It appears that 3-point seat belts were original equipment (per text and photo). Is this correct? My Bug has none, and don't know why they would have been removed.
2. Ditto for front doors wing windows. Stock item? Any/all pics I've seen of '69 Bugs show them. Again, my Bug has none, only 1-piece front side glass.
Thank You!! for any feedback on these.
Samba.com is amazing! _________________ 1969 Type 1171 Sunroof Sedan |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
windfish Samba Member
Posted: Thu Mar 26, 2015 11:34 am Post subject: |
Here's a topic on fitting Hummer seatbelts - http://www.thesamba.com/vw/forum/viewtopic.php?t=526370
Apparently they fit quite well and can be bought for reasonable.
I've always liked the vent wings, though I guess some people may like the sleeker look of the one pieces.
There's a fair amount involved in putting it back to stock, wolfsburgwest has a diagram here - (link)
If you're interested in doing so you should be able to find most of that in the classifies here, though may want new rubber pieces. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Mar 26, 2015 2:24 pm Post subject: |
Cipi1 also carries front retractable seat belts in black and tan. I installed the tan ones in my bug. They work quite well.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Q-Dog Samba Member
Posted: Thu Mar 26, 2015 5:14 pm Post subject: |
Yes, they were non-retractable, but they had these little plastic rollers that were supposed to wind up and take out the slack when you weren't using the belts. Those plastic winders failed fairly quickly. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
curtp07 Samba Member
Posted: Fri Mar 27, 2015 7:07 pm Post subject: |
I just did the Humvee belts off Ebay, I believe it was $50 for the setup with the special brackets from CIP. Works great! Easy to setup as well.... |
sb001 Samba Member
Posted: Sat Mar 28, 2015 6:24 pm Post subject: |
Q-Dog wrote: |
Yes, they were non-retractable, but they had these little plastic rollers that were supposed to wind up and take out the slack when you weren't using the belts. Those plastic winders failed fairly quickly. |
Never heard of this, and we've had my 69 since brand new-- when not in use we were supposed to hang the belts on the hooks on the B pillar
EDIT: well Ill be damned
http://www.thesamba.com/vw/classifieds/detail.php?id=1760876
I guess you're right then about them failing early, cause here's what's left of mine (always wondered what these pieces were in my parts collection box):
_________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Charlo Samba Member
Posted: Sun Mar 29, 2015 6:11 pm Post subject: |
Thanks to all of you!
LOTS of great info to absorb and research!
This is going to be a very fun restoration...
(Hmmm - wing/vent windows or not.) _________________ 1969 Type 1171 Sunroof Sedan |
