70's gearbox
Udo.B.
Udo.B. is offline
PostPosted: Fri Mar 27, 2015 7:53 am    Post subject: 70's gearbox Reply with quote
I bought a 70 beetle and would like to know what Ring and pinion the original gearbox has ? I think they have IRS in the rear also ? I do not have the car here so this is why i ask silly questions Smile
Udo
www.udobeckertuning.de
Busdriver79
Busdriver79 is offline
PostPosted: Fri Mar 27, 2015 8:28 am    Post subject: Reply with quote
You can find the transmission final drive ratios in the HBB off road section...Look up the "transmissions for Dummies" sticky.....I believe a 1970 Bug w/IRS would be a 4.12 ring and pinion ratio.
Bruce
Bruce is offline
PostPosted: Fri Mar 27, 2015 6:15 pm    Post subject: Reply with quote
If your 70 Beetle had a 1200 or 1300cc engine, it would have a 4.37:1 R&P. If it had a 1600, it would have a 4.12 R&P.
andrewvwclassic
andrewvwclassic is offline
PostPosted: Fri Mar 27, 2015 8:21 pm    Post subject: Reply with quote
I would wait if you are buying parts to confirm anything that might be unkown until you look in there. best indicator of a replacement part is finding the tranny code and checking with a parts supplier. I would avoid rebuilding it yourself it is actually chaeper to buy a rebuilt one moost of the time.
Joel
Joel is offline
PostPosted: Sat Mar 28, 2015 11:49 pm    Post subject: Reply with quote
It was only north America that got IRS in standard beetles, being in Germany it will be swing axle unless it was automatic or been converted and as Bruce said the ring and pinion will depend on what engine it had.
If its 1200 or 1300 (car will drum front brakes) 4.375 or 1500 (disc brakes) is 4.125
Only north America got 1600 beetles in 70 so it wouldn't have been that originally.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
Udo.B.
Udo.B. is offline
PostPosted: Sun Mar 29, 2015 2:36 am    Post subject: Reply with quote
It is a californian car - i wait until i get it here to look for the code on the gearbox.
thanks for your reply's
Udo.B.
Udo.B. is offline
PostPosted: Mon Mar 30, 2015 12:36 pm    Post subject: Reply with quote
Looks like i had good luck with the car . it has AH engine so 1600 cc and may be a long gearbox
Udo
Bruce
Bruce is offline
PostPosted: Tue Mar 31, 2015 8:50 pm    Post subject: Reply with quote
And Australia in 1976. I know it's an obscure country, but they got IRS std Beetles with manual gearboxes there. You should visit there and see them at the car shows.
Joel
Joel is offline
PostPosted: Wed Apr 01, 2015 12:47 am    Post subject: Reply with quote
Yeah I hear they have good VW shows Wink
I left the Oz 76 out to avoid confusion as not many on here would know about them.
Anyway interesting that someone would go to all the effort of importing a US car to Germany.
