ronbug73 Samba Member
Posted: Fri Mar 27, 2015 1:01 pm Post subject: Fasty 71 ac project |
Hi
after 3 years i decided its time for an a/c. i live in isael its very hot here.
we never got the ac kit. i found some parts on samba end i want to say thank you Tram for your help .
we will use modern senden compresor end modern condensor.
Beny end Roy from DR Bug israel is duing all the work.thank you Beny end Roy
my fasty
the bracket
the inside 71 unit
with the help of Tram
i will up date the project
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Mar 27, 2015 2:12 pm Post subject: |
OK, that answers my question about the Sanden compressor- no way you could make it work with a stock air cleaner. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Mar 28, 2015 4:56 am Post subject: bolt spacer |
Hi
i have the pulley
but im misssing the bolt end spacer for the pulley
1. somone have tham?
2. can somone send me the measurement or ; size of the bolt end spacer?
thank you
Ron |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat Mar 28, 2015 7:00 am Post subject: |
On the left is the spacer bolt, and on the right is the regular pulley bolt. The length of the spacer bolt's head is marked in the picture.
Here's the spacer bolt viewed from the top. The thread depth is 45 mm; the thread pitch is of course the same as the regular pulley bolt.
_________________ 71 Elm Green FI A/T Squareback |
Posted: Sat Mar 28, 2015 2:43 pm Post subject: |
The way I read that, a spacer is always needed, but they are warning you that there are some pulleys which are not compatible with the spacer.
Posted: Sun Mar 29, 2015 11:26 pm Post subject: pulley |
the ac pulley
we will fabricat the bolt end spacer
today we will finish with the condencer end compresor
ron |
Posted: Mon Mar 30, 2015 4:53 am Post subject: condensor |
Hi
today we fit the condensor we put it in the front in the gap between the beam end the sper wheel.
i know Tram will not like it
Ron |
Posted: Mon Mar 30, 2015 9:02 am Post subject: Re: condensor |
ronbug73 wrote: |
Hi
Ron |
Why? It fits nicely there. There's more room on a second design car than a first design car in that area. Does it have a cooling fan? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
Posted: Mon Mar 30, 2015 9:23 am Post subject: |
How is the airflow in this location? Will you be adding ducting to improve the airflow?
Also, have you calculated the amperage draw for the fan?
Thanks |
Posted: Mon Mar 30, 2015 9:49 am Post subject: Re: condensor |
Tram wrote: |
Why? It fits nicely there. There's more room on a second design car than a first design car in that area. Does it have a cooling fan? |
I can't say about the airflow, but that's where the condensor was on my car when it had A/C (which was removed before I bought it). _________________ 71 Elm Green FI A/T Squareback |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Mon Mar 30, 2015 9:50 am Post subject: |
I hate space saver spares, but if this were mine, I'd make a smaller tray for a smaller spare, and maybe add a deflector or duct to scoop air into it. That's a fairly dead air space now. |
Posted: Mon Mar 30, 2015 11:04 am Post subject: cooling fan |
Hi
we will add a cooling fan .
Ron |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Mon Mar 30, 2015 7:29 pm Post subject: Re: condensor |
Donnie strickland wrote: |
Tram wrote: |
I can't say about the airflow, but that's where the condensor was on my car when it had A/C (which was removed before I bought it). |
Yup, my old 70 Square had the condensor located right there too. But, it had a dual fan unit mounted right behind it. Sorry, no pics, as I took it off over 18 years ago, and sold the car 3 years later. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Apr 01, 2015 10:30 am Post subject: up date |
Hi
today we fit the condencer with the finel bolt end the fan of the condencer
the fan
i need the corect place end size to cut the fan house for the belt from the pulley to the compresor
Ron |
Posted: Wed Apr 01, 2015 5:06 pm Post subject: |
Here are measurements from my fan shroud. They are taken from the hole centers:
And a view from inside the shroud. You can see how they cut out extra metal to be able to get the belt on.
KTPhil Samba Member
Posted: Wed Apr 01, 2015 5:28 pm Post subject: |
These are from an OEM installation , right? If you use a different compressor/bracket, those dimensions may or may not work. |
Posted: Wed Apr 01, 2015 5:38 pm Post subject: |
If Ron uses the pulley spacer dimensions I posted earlier in the thread, these measurements will be correct. He'll have to make his compressor mount to conform to this. _________________ 71 Elm Green FI A/T Squareback |
Posted: Wed Apr 01, 2015 9:55 pm Post subject: thank you |
Hi Donnie
thank you
Ron |
Posted: Thu Apr 02, 2015 2:16 am Post subject: corect pulley |
Hi i have 2 pulley one is big end one is small
we think that the big one is from a beetle. it seats nice on beetle pulley
the big
the big pulley 2 legs are seatinig on the wings of the fan
look at the small pulley
1.waht to use?
2. the spacer bolt dosent fit good with the small one
thank you
Ron |
