Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Apr 02, 2015 3:48 am Post subject: |
Neither of those looks like the right pulley. I'll post a picture of mine when I get home. _________________ 71 Elm Green FI A/T Squareback |
Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
Posted: Thu Apr 02, 2015 5:47 am Post subject: |
You might want to consider having the pins of the crankshaft pulley ride on some sort of hardened collar. I would be concerned that the intermittent start up loads when the compressor clutch closes could, over time, force the pins right through the fan blades. |
Posted: Thu Apr 02, 2015 5:49 am Post subject: |
Do you have technical specs for your compressor?
I would like to know the compressor's operational RPM range as well as the horsepower needed to operate the compressor.
Thanks
I was able to find the specs, they are located here:
http://www.sanden.com/objects/TRSE07_performance_curve.pdf
Thanks |
ronbug73 Samba Member
Posted: Thu Apr 02, 2015 6:40 am Post subject: pulley |
Hi Donnie
can you please send me measurements of the pulley
thank you
Ron |
Posted: Thu Apr 02, 2015 7:39 am Post subject: |
Here's my pulley, which has two lugs on the back. It has a diameter of 107 mm:
And here's how the lugs engage the fan:
And a closeup:
Posted: Thu Apr 02, 2015 2:03 pm Post subject: thank you |
Hi Donnie thank you
we will fabricate the pulley
interistic i dont have the sanden 505 technical specs.
Ron |
Posted: Wed Apr 08, 2015 9:12 am Post subject: 71 inside unit |
Hi samba
today i got the 71 inside unit, look at it im
thank you Tram
i think the story is not in the unit look at the box that Tram made
in order to cross the ocean
the unit is very fragile in the steering section.
Ron |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Wed Apr 08, 2015 9:40 am Post subject: |
I think we all can say Tram is one helluva guy. that unit is gorgeous! _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Apr 08, 2015 10:03 am Post subject: |
That was a good trade! Ron needed the late model, and he had a '66/7 unit similar to the one we put in RC's Notch that I needed for a friend's '67, so we made a long distance trade. The unit I got from Ron was really nice as well.
I'm glad the shipping gorillas didn't damage either unit. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Apr 08, 2015 1:11 pm Post subject: ok |
Hi
i will up date the project next week
we have the engine bracket, compressor sandan505, new condensor, 71 inside unit. we have pulley problem but we are stilll working
so next week wil be the hoses end weiring hreness the draier
end again thank you Tram for the very nice unit.
end Donnie for all the help.
end samba
ps today in israel it was 40c very hot
Ron |
Posted: Thu Apr 09, 2015 10:17 am Post subject: |
I need to remember to find my 1971 A/C installation supplement for you... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Apr 16, 2015 1:45 pm Post subject: up date |
Hi
today we fit the pulley. we had to go to a machinict to make the spacer we close the bolt at 100 ftlb end there is a gap of no moer 1/16 so the pulley will not seat on the pulley of the generator.
the bracket of the sandan 505
Ron |
Posted: Sun Apr 19, 2015 12:59 pm Post subject: compresssor |
Hi Samba
today Beny was working on the compressor bracket end pulley belt. he olso made the cut for the belt.
compressor bracket.
making the cut
the fan belt.
ok so we wiil paint end make the final adjustment
Ron |
Walter64 Samba Member
Joined: December 06, 2013 Posts: 146 Location: Sydney
Posted: Sun Apr 19, 2015 3:11 pm Post subject: |
Yes, looks great, i'm following this thread as I want to install A/C in my T34 ghia. Will you be able to fit the stock air cleaner base, regardless of the fresh air tube coming from the rear? _________________ VW fan & Real Estate Agent at www.argyproperty.com.au
66 RHD teak T34 karmann |
gavs Samba Member
Posted: Sun Apr 19, 2015 4:24 pm Post subject: |
Hey ronbug,
just wondering, how and where are you running the refrigerant lines from the condenser to the compressor? |
Posted: Sun Apr 19, 2015 8:27 pm Post subject: air cleaner hose |
Hi
1. i dont use the stock air cleaner base i dont know if it will fit.
2. refrigerant lines from the condenser to the compressor. i will up date in the next days.
3. Donnie thank you
Ron |
Posted: Mon Apr 27, 2015 4:04 am Post subject: inside unit |
Hi Samba- up date
the inside unit.
looking for some ideas how to place the radio
Ron |
Posted: Mon Apr 27, 2015 9:44 am Post subject: |
Ron: Radio mounts in the plastic bracket which is now attached under the unit rather than under the dash.
OE dealer installed radio from 1971 on in USA was this:
http://www.thesamba.com/vw/classifieds/detail.php?id=1782276
There was an AM/FM version available too, as well as a "Playtape" option.
The plastic mounting bracket is the same for all markets, though. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Apr 27, 2015 11:45 am Post subject: CENTER CONSOLE |
Tram
i thinking about CENTER CONSOLE like you made
Tram center console
Ron |
