croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Fri Mar 27, 2015 9:46 pm Post subject: Been thinking about steppin' up... |
195+ flywheel HP, N/A (no turbo, no EFI, etc.), carb all motor, T1 config., streetable, reliable (within reason) ...
How?
Now running 150-160 HP very streetable manners ... but want more.
Opinionated opinions welcome.
_________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
MarvinNash Samba Member
Joined: November 27, 2011 Posts: 44 Location: Northern California
Posted: Fri Mar 27, 2015 10:01 pm Post subject: |
I have an engine that is exactly that. Built by Anibal chico. It made 195hp on his dyno, and I've driven the car 3 hours on the freeway about 85mi in one trip, so I know it's reliable. Head temps never get that hot, the engine runs great, and has tons of power. My specs are
2332cc
Web 86c cam
9.45:1 compression
44x37 big wedge ports
48idas w 42mm venturies in tall manifolds
1 5/8 exhaust |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Fri Mar 27, 2015 10:18 pm Post subject: |
Well, what do you have right now? The more info you add, the better answers you'll get. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sat Mar 28, 2015 1:13 am Post subject: |
bugguy1967 wrote: |
Well, what do you have right now? The more info you add, the better answers you'll get. |
Okay... I'd like it to be a 2276 (cuz that's what I have now) 1 5/8" exhaust..., everything else is on "the chopping block". _________________ Please check my '67 sedan project progress!
Posted: Sat Mar 28, 2015 1:16 am Post subject: |
MarvinNash wrote: |
2332cc
Web 86c cam
9.45:1 compression
1 5/8 exhaust |
That's what I'm talkin' 'bout right here! I'm thinkin' 2275, 10:1 cr, DRD L7 heads, 48 DRLA's, everything else the same.... Same HP?
MarvinNash - BTW, I just recently drove my 160 HP 2275 300 miles+ 'round trip on the freeway (and around town extra mileage) 75 mph, 3500 rpm most of the way; she ran PERFECT.
Want similar reliability/drivability from 195+ HP, same displacement, same exhaust...
Thoughts? _________________ Please check my '67 sedan project progress!
Posted: Sat Mar 28, 2015 2:19 am Post subject: |
First, the engine has to be built "right" by a proper builder with a good combination of parts, and tuned well.
I'd keep the cr somewhat "low", probably under 10 unless you're running squishy Pistons. The 86c cam likes 11:1, and My engine with 9.45:1, while on the low side for this cam, feels incredibly powerful still.
Use stock type head casting for cooling. Not street eliminators.
Use an external oil cooler w/ a fan for keeping oil cool on longer trips. Possibly 2 or a dual fan type cooler.
Use as much stock tin as possible including sleds and industrials. Some say the Chinese tin works fine too however.
Prop deck lid or use convertible deck lid for more engine air.
.89 final gear in a 3.88 trans or possibly .82 to keep rpms low on freeway at 65- 70mph. If I start cruising faster than that my head temps start rising. For mine, 65 mph is my sweet spot. Use a Berg 5th gear trans if you want to drag race with close ratio gears, then cruise on the freeway with low rpm. My trans is 3:88, with a close 3rd for drag racing, and a .89 4th for freeway driving. It was the best compromise for me between the 2 but there's a huge drop between 3rd and 4th.
Just be prepared to baby this engine a bit to get it reliable while freeway driving. It will need more attention, more maintenance because it is higher strung, and you will probably have to go a lil slower on the freeway so it won't overheat depending on your build. But you could have a 200hp daily driver |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Sat Mar 28, 2015 6:34 am Post subject: |
What heads are on the current engine? _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
Posted: Sat Mar 28, 2015 7:14 am Post subject: |
Engine specs:
2276
Tim's Stage 2 plus heads (welded, p&p, 42x37.5)
1 5/8" exhaust
Dual 44 IDF's, 36mm vents
Stinger S4 Ignition
SLR XR302 cam, CB 1.4:1 rockers
This is what I meant about adding info. Your compression is around 9.6:1, right? I'd sell my heads, exhaust, and carbs and get a new cam combo. There are many ways to reach 200 fly horsepower. With a 2276, you'll get it around 7000 RPM, with 44x37 heads, a 1 3/4 exhaust, and 48mm throats. Choose whatever ratio rocker cam brand you want.
Oh, and with the same amount of ccs, I wouldn't expect to have the same kind of driveability. The powerband is going to move up to make another 40-50 HP. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
mark tucker Samba Member
Posted: Sat Mar 28, 2015 8:06 am Post subject: |
super pro heads,86-88 stroke,1 3/4 exhaust. 48's or biger.possiably cam change too |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Mar 28, 2015 10:11 am Post subject: |
You can get a pretty fancy EFI and turbo setup for less than what it would cost to upgrade plus you could put it on the engine you have and be at 300 hp.
It would be a docile cruiser till you mashed the throttle....
I hope to be at 200 plus hp with my 1679cc turbo as soon as I get it back together with the new heads. I only need 20 more hp. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Sat Mar 28, 2015 12:08 pm Post subject: |
How much power do think I'd be at if I just change the cam (FK45, XR316, or 86c) and carbs (48 DRLA's or 48 IDA's) and up compression (now at 9.5:1, take it up to 10-10.5:1)?
BTW, trans is as follows: 3.88 final drive, 3.78 1st, 2.25 2nd, 1.48 3rd, .89 4th. What I've really done with my trans is make it a 3-speed drag car with a freeway cruising 4th. The jump from 3rd to 4th while significant isn't annoying, especially since 4th gear is just for 40-45 mph+ cruising. I'd never use 4th gear in 1/4 mile drag race.
More out-loud thinking... I might have difficulty achieving that high of compression w/o fly-cutting heads and notching pistons. I had to fly-cut the heads for 9.5:1 cr and keep a safe deck height. _________________ Please check my '67 sedan project progress!
