onurenka Samba Member
Posted: Sat Mar 28, 2015 6:50 pm Post subject: shorter sway bar |
Has anybody seen some webshops where to get 4" shorter sway bar for 71 bus? |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Mar 28, 2015 8:45 pm Post subject: |
I don't believe they exist. Can I ask why you need a shorter one? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Tcash Samba Member
deronmoped Samba Member
Joined: November 18, 2006 Posts: 375 Location: San Diego
Posted: Sun Mar 29, 2015 12:02 am Post subject: |
Just have one made.
I once had a set of leaf springs made and was real surprised on how cheap it was. A bent up heat treated bar shouldn't be all that expensive. |
1967250s Samba Member
Posted: Sun Mar 29, 2015 12:39 am Post subject: |
You could always cut yours, at the center, and reweld it, though a little reinforcement at the weld might be a good idea. _________________ '72 Elm Green Deluxe |
Posted: Sun Mar 29, 2015 9:47 am Post subject: 4" sway bar |
Sorry, mixed up the words, i need 4" narrowed sway bar for a 4" narrowed beam.
Thanks for the links, Ill be contacting the specialists in steel works. Hopefully its not very expensive to get one made.
Not very keen on the idea of sleeving and welding, if you think about the purpose and task of a sway bar(spring effect) then these two ideas dont mix.
Thanks! |
Posted: Sun Mar 29, 2015 11:01 pm Post subject: |
Welding on spring metal does not work. Welding changes the temper of the metal. |
Dogo Samba Member
Posted: Sat Sep 19, 2015 8:01 pm Post subject: |
Someone was telling me that in order for it to work properly it should be cut as close to the outer edge as possible because all the twisting happens in the centre of the bar? It kind of made sense to me. Does it? |
Posted: Sun Sep 20, 2015 12:23 am Post subject: |
Dogo wrote: |
The torque is going to be fairly constant along the bar. Any place you cut it and weld it will likely break. I would think that the thing to do would be to have a custom bar made. |
Brian Samba Moderator
airschooled Air-Schooled
Posted: Sun Sep 20, 2015 10:03 pm Post subject: |
Brian wrote: |
You don't need a sway bar. |
You need one when you're as drunk as Brian. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon Sep 21, 2015 4:49 pm Post subject: |
asiab3 wrote: |
Brian wrote: |
You need one when you're as drunk as Brian. |
Someone needs a 12 step program. |
