Trike shifter questions..
VSarge
VSarge is offline
PostPosted: Sat Mar 28, 2015 10:00 pm    Post subject: Trike shifter questions.. Reply with quote
OK, I've used the search here and elsewhere and still have some questions.
My trikes shifter is sloppy as all heck and will go into reverse if you look at it hard. I understand this is all curable by replacing the bushings and such, no problems there.
The problem is where the shifter is located, basically. In the center between my legs. Convenient, yes. Also occasionally painful! I'm 5' 10" but have short legs so my seat is pretty forward. Every so often a shift will smack me right in the crotch. Shocked
Looking for a short throw shifter with a short handle. I do mean short, less than the 10" ones I see listed as "short". I also like the trigger style of reverse lock out. As the shifter is centered a T-handle doesn't work very good either.
So am I just searching wrong or does a shifter like this not exist?
Sarge
VW trike -- FrankenMutt
1971 1600
Swing Arm frame
Stock 4 spd tranny - no reverse gate (crap!)
1966/67 rear brakes wheel cylinders from front of 1966 Bug
1934 Chevy headlight
Custom leading link front end
Ford Ranger rims
P225/60R15 rear tires
GoldWIng front tire
Body is fiberglass nose from semi
One ugly exhaust, heavily rusted, set up for heat??? On a trike??
Letterman7
Letterman7 is offline
PostPosted: Sun Mar 29, 2015 5:21 am    Post subject: Reply with quote
I've not seen a short trigger lock. If you can find a used one in the classifieds, it wouldn't be difficult to cut it to length that you want and weld it back together. The trigger locks are usually just a cable anyway, so that can be shortened as well. If you can live without a trigger, cutting a stock shifter down and rethreading the top for the ball is very easy.
BL3Manx
BL3Manx is offline
PostPosted: Sun Mar 29, 2015 3:19 pm    Post subject: Reply with quote
Not sure it would be practical in your application but there are linkage systems which offset the shifter to the side in a single seat vehicle.
http://www.pacificcustoms.com/jamar-js1.html
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Sun Mar 29, 2015 6:38 pm    Post subject: Reply with quote
The buggy super shifter in that pic or even the copy is a lot better than a stock one. If I had a place to put it I would run one on my trike.
I also prefer mine shifter out the lh side.
VSarge
VSarge is offline
PostPosted: Sun Mar 29, 2015 7:23 pm    Post subject: Reply with quote
I have been considering the Jamar side shift unit but then I also need to get a shift box and shifter. But a left shifter is something I am used to; like a suicide setup on a bike.
Sarge
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
DeathBySnuSnu
PostPosted: Mon Mar 30, 2015 11:15 am    Post subject: Reply with quote
Buggy super shifter. Just mount it sideways.
BL3Manx
BL3Manx is offline
PostPosted: Mon Mar 30, 2015 12:56 pm    Post subject: Reply with quote
You should try to ask JAMAR but I think the input and output levers on the side shift linkage mechanism could probably swapped so it could be used on the left.
VSarge
VSarge is offline
PostPosted: Mon Mar 30, 2015 1:48 pm    Post subject: Reply with quote
Yeppers, sent an email to them this morning about that.
Sarge
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
VSarge
VSarge is offline
PostPosted: Mon Mar 30, 2015 1:50 pm    Post subject: Reply with quote
The knob is the reverse lock out, correct? Does it have to be held in to get in reverse? How would single hand use work with it?
Sarge
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
PNGPNG
PNGPNG is offline
PostPosted: Fri May 22, 2015 6:18 am    Post subject: Reply with quote
What did you come up with on this... I am facing the same dilema on my trike, and was hoping to see what others have done.
VSarge
VSarge is offline
PostPosted: Fri May 22, 2015 6:29 am    Post subject: Reply with quote
So far, I will most likely just cut the stock shifter down some. Cash flow problems.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
PNGPNG
PNGPNG is offline
PostPosted: Fri May 22, 2015 9:11 am    Post subject: Reply with quote
Gotcha... I am thinking I am going to change mine to the side shift setup... very new at this vw game, but learning quickly. Infact in negotiations for another trike now
VSarge
VSarge is offline
PostPosted: Fri May 22, 2015 9:58 am    Post subject: Reply with quote
If anything I'm getting more and more disappointed with mine.
Finally got the brakes all sorted out and working awesome but now it won't run for more than 1/4 mile or so. It will sit and idle but get moving and within a short time, it spits, sputters and shuts down.
Most likely just a fuel filter going bad but since I've had it (about three months) I've gotten one decent ride on it. Mad
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
rsfowler
rsfowler is offline
PostPosted: Fri May 22, 2015 12:21 pm    Post subject: Reply with quote
I used a side sifter and it works great as long as you keep it bolted down tight and adjusted correctly
see the bottom of this page
http://www.3fowlers.com/tranny.html
Thanks
Bob
PNGPNG
PNGPNG is offline
PostPosted: Fri May 22, 2015 5:22 pm    Post subject: Reply with quote
I picked my scoot up last friday... rode it around a lil sat and sunday to get used to it.. then after work friday put 40 or so miles on it.... then tuesday took it to work and the shifter is stupid sloppy.. causing me to miss shifts and stall.
Sadly my front forks developed a leak.. and the engine has a bad leak.. I am hoping it is only blow by on the engine and the forks leaking is more I beleieve is due to them being from a 74 CB 550.
My scoot is more a traditional bodied trike. I am going to have to move my shifter from the right side over to the left side... Plan is to try one of the Jamar shifters.. then if needed do the side shift on it.
Crazy as it sounds I am negotiating a deal on a 76 one with a girder front end too. we shall see what happens
V-driver
V-driver is offline
PostPosted: Sat May 23, 2015 7:30 pm    Post subject: Reply with quote
I use the super shifter mounted on its side, handle out to the left. It puts the reverse lockout button under the end of my thumb if I grab the shifter shaft - wrap my fingers around the shaft (that sounds lewd). Press the button with my thumb and move the shaft down and back to hit reverse. It works great in that arrangement. No need for the side offset mechanism with a small u-joint at the transaxle end of the control shaft. Shifter is some 40" in front of the trans.
PNGPNG
PNGPNG is offline
PostPosted: Tue May 26, 2015 2:21 pm    Post subject: Reply with quote
Well I just pulled the trigger on the super shifter... went for a ride on my scoot, and could only get 2 and 3rd gear.. no first or 4th.. well got back home and looked at the Ghetto fab the PO did. Apprently he used what appeared to be 1/8 or thinner tube that he heated and bent to make the shifter.. to solve the length problem he slid it inside the other tube.. then driled a hole that was too bif for the 5/16 bolt.. so needless to say the more you used it.. the looser it got cause the tube was deforming... WTF
SO I ordered the shifter shifter kit, and a few other misc things to get scoot back like it should.
brettsvw
brettsvw is offline
PostPosted: Sun Jun 14, 2015 4:49 am    Post subject: Reply with quote
This is what I did for shifter location. Works great using a off-road weld in shifter box.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
BERKELUSA
BERKELUSA is offline
PostPosted: Wed Sep 02, 2015 8:26 pm    Post subject: Shifter.. Reply with quote
Mine uses the stock VW Shifter bracket mounted on the tube frame and sticks out the side of the fiberglas body, We made an adapter that connects a shorter shaft to the hockey stick.. Should be in this video..
Rob Shocked
BL3Manx
BL3Manx is offline
PostPosted: Thu Sep 03, 2015 11:26 am    Post subject: Reply with quote
The machine work and fabrication are impressive. What problem with a stock coupling were you overcoming? Does your design have the same length and lateral fine tuning an adjustable shift rod end has?
