dillon70 Samba Member
Joined: October 20, 2008 Posts: 234 Location: Ventura, Ca.
Posted: Sun Mar 29, 2015 8:47 pm Post subject: Center Cap Help |
So I got these wheels from CIP1, but the center caps only work on the front. The rears stick out about an inch and won't fit. I need some kind of extension or different chrome cap that will fit a 70mm hole.
Any suggestions would be great.
_________________ 2001 ZO6 (450+hp)
1985 930 Turbo (400+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
1970 Chimney Pop Top (120 hp) SRFBUS1
1990 Vanagon (95 hp)
1985 Vanagon GL (85 hp)
1969 Tin Top 1 owner OG
Can I get any slower?
2015 CC R-Line (heavily mod'd) |
stamperman Samba Member
Joined: June 15, 2013 Posts: 5 Location: Alma, Arkansas
Posted: Tue Mar 31, 2015 8:06 pm Post subject: |
I found some on ebay to fit my 5 spoke wheels. My openings are also 70mm. I believe that they stick out a little over 2". Do a search on ebay, I bet you can find some to fit your needs. Good luck! |
pitargue Samba Member
Posted: Tue Mar 31, 2015 9:13 pm Post subject: |
In San Jose, CA, there's a shop called Hub Cap City. No web site. But here's the yelp page. http://www.yelp.com/biz/hub-cap-city-san-jose
Maybe there's a shop like this in your neck of the woods? |
Posted: Wed Apr 01, 2015 10:26 am Post subject: |
Thanks guys. I am going to try and fine a local place and try to find something that will work and not look to bad.
I have been looking on ebay, but no luck. The 914 hub looked like it would fit, but different ID.... _________________ 2001 ZO6 (450+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Apr 02, 2015 6:58 pm Post subject: |
Maybe Flat4 can make you some? They have them for BRMs. _________________
EverettB wrote: |
FU#5 |
Posted: Wed Apr 08, 2015 2:11 pm Post subject: |
Well, I found some caps that fit tight, but are just a little deep. I could have got away with a 1.25" deep cap, but the best I could find in 2.75" (70mm) width was 2.10" deep cap. They are plastic, but the finish is a perfect match.
Found them at Automotive Super Saver, but they sell mostly on ebay. I got lucky in that they were only 45 minutes from me so I drove there and tried the fit.
Danny was the guy I dealt with and he hooked me up. I highly recommend these guys if you have the same issue I did and there should be a few of us.
Ebay item number is 321670454751.
1970 Z28 (360+hp)
1979 911 (235 hp)
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Thu Apr 09, 2015 10:02 am Post subject: |
I just used EMPI spacers on the rear to get the caps to fit. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Apr 09, 2015 10:52 am Post subject: |
Mike Fisher wrote: |
I just used EMPI spacers on the rear to get the caps to fit. |
Spacers for the wheels or caps? I cannot use wheel spacers because of the backspacing with the rims. 4" backspace puts the rear wheels out to a 1/4" or less from the fender. _________________ 2001 ZO6 (450+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
cannibus Samba Member
Posted: Fri Apr 10, 2015 4:22 am Post subject: Axle. Nuts |
Have the nose of your drum turned down and get a spacer but I don't know if amy one is making a spacer for wide five if it were me I would call Russell at oldspeed ! Paramont California he can make anything ! _________________ Can bring to Bug O Rama |
Posted: Fri Apr 10, 2015 9:13 am Post subject: |
1/4" spacers brought my rear wheels out to 1/4" fender clearance, so I'm good w/205X70 & 185X60. Grind the nose down & taper the end a little.
Posted: Fri Apr 10, 2015 10:51 am Post subject: |
If I do grind down the nose, I don't think I am going to get an 1"+ out of that. This means I still need a different cap than what came with the wheels and it was hard enough locating the deep ones I did.
I guess it comes down to, how much am I willing to spend... I could change to rear discs, but then I would need to do the front and your talking cash. I just dropped $4k into her this last month, so I will have to live with what I found for a while.
Just putting the info out there in case someone else is in my same boat and there should be a few. _________________ 2001 ZO6 (450+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
Posted: Fri Apr 10, 2015 11:18 am Post subject: |
ISP West was selling some custom billet caps, but yours don't look bad! _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Fri Apr 10, 2015 11:26 am Post subject: |
I have to say that the USA made plastic caps are terrible looking from a chrome perspective. The Taiwan plastic chrome caps match perfect. Something to do with the US regulations on the type of paint or process. When I was at the cap place, it was almost a night and day difference between the two. I think polished Billet would look dull unless chromed. _________________ 2001 ZO6 (450+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
Wendell Harvey Samba Member
Joined: July 04, 2019 Posts: 8 Location: Overland Park, Ks. 66212
Posted: Fri Jan 24, 2020 9:15 am Post subject: Re: Center Cap Help |
I have a different problem. bought 4 new 911 style wheels and the rear ones fit and center cap fits. The front center caps wont go on so I get 3/8" spacers and grease caps still protrude to far out and keep center cap from going all the way on. Brakes are still drum and I don't know what to do next.
Will installing disc brakes on the front cure my problem?
Im not a fan of having to modify the car to make a product make to fit the car doesn't work. Something wrong here. |
slalombuggy Samba Member
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Wed Jan 29, 2020 2:11 pm Post subject: Re: Center Cap Help |
I used the ISP-West polished aluminum caps on the Porsche 2L 914 wheels I have on my VW pan based Porsche Speedster Replica. They work and look great. Hidden Allen screws holt them on. The cleared the front speedo drive hub and the rear 36 mm axle shaft bolts.
https://www.vwispwest.com/GA-CAP914.html?p=YzE9Mjc5 _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
