Jim Dirt Samba Member
Joined: February 02, 2015 Posts: 17 Location: Brentwood Ca
Posted: Mon Mar 30, 2015 8:39 pm Post subject: Bug too low |
I have a 63 bug with a 66 adjustable ball joint beam. I just installed disc brakes with 2 1/2" drop spindles and now the fenders are setting on the tires. I have the beam raised all the way up. Help! |
vwsonmybrain Samba Member
Posted: Mon Mar 30, 2015 8:59 pm Post subject: |
Both the disc brakes and the dropped spindles increased your track. You'll likely need a narrowed beam to offset that and bring your wheels back in your fenders a bit. |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Tue Mar 31, 2015 8:10 am Post subject: |
I had the same issue with mine. I have drum brakes with 2in narrow beam and drop spindles. I am right now removing the drip spindles. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Tue Mar 31, 2015 9:22 am Post subject: |
What method did you use to attach the ball joint beam to the car? _________________ Mother Nature is a Mean Evil Bitch! |
Mr. Fickits Samba Member
Posted: Tue Mar 31, 2015 1:53 pm Post subject: |
I have CB 2.5 drop spindles with discs (5 x 205). I had to narrow my beam 4.5" to get the track width where I want it. I also had to make custom shock towers which barely clear the body of my 62 bug. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Tue Mar 31, 2015 5:27 pm Post subject: Re: Bug too low |
Jim Dirt wrote: |
Something is wrong with your statement, balljoint beams don't bolt to linkpin pans and visa-versa. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Mar 31, 2015 7:48 pm Post subject: Re: Bug too low |
Keith wrote: |
Jim Dirt wrote: |
Something is wrong with your statement, balljoint beams don't bolt to linkpin pans and visa-versa. |
^ yep....
Pan swap most likely...
Most likely someone wanted a slammed beam and installed the adjusters bias towards the lowered side.. (bad choice)..
Change 1 thing it effects 10....
Since you now have invested in drop disc spindles... you have two choices now...
Either correct the beam or buy one with neutral lowering and SLIGHT narrowing so you can tune it.
Sorry for the blunt facts...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Posted: Tue Mar 31, 2015 8:16 pm Post subject: |
I bought it that way. I just put the drop spindles and disc brakes on. |
Posted: Tue Mar 31, 2015 8:17 pm Post subject: |
Can I narrow the beam that's on it? |
microbus Samba Member
Joined: October 12, 2007 Posts: 527 Location: Alberta, Canada
Posted: Tue Mar 31, 2015 9:46 pm Post subject: |
Yes you can... _________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Tue Mar 31, 2015 10:17 pm Post subject: |
This^ Russell is a great guy and does amazing work! _________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Posted: Wed Apr 01, 2015 5:29 am Post subject: |
Thanks guys |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Wed Apr 01, 2015 5:56 am Post subject: Re: Bug too low |
Jim Dirt wrote: |
Pics?
Wheels / Tire combo? _________________ Paulie
63 Standard OG paint |
Posted: Wed Apr 01, 2015 10:12 am Post subject: |
You never answered the question of how the ball joint beam was attached to this car!
The answer may help solve your problem. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Apr 01, 2015 10:48 am Post subject: |
It's a 63 with a 63 pan with a 66 front end. How do I put pics on here? |
Posted: Wed Apr 01, 2015 10:50 am Post subject: |
BRM 15" wheels. 135's up from and 195's in the rear |
Posted: Wed Apr 01, 2015 11:00 am Post subject: |
Jim Dirt wrote: |
Your beam looks like this with the stepped lower tube? If yes, that will not bolt to a 63 pan. 63 should have a Link Pin.
This piece shows the different spacing between BJ and LP beam. The BJ beam tubes are spaced further and will not bolt up to a 63 pan.
Posted: Wed Apr 01, 2015 3:29 pm Post subject: |
It's a 63 pan for sure. I checked the vin. The front part was upgraded to a 66. I will post pics as soon as I figur out how too. |
Posted: Wed Apr 01, 2015 4:48 pm Post subject: |
