cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Sun Oct 23, 2016 12:01 pm Post subject: Re: My project Doom Buggy |
so is it just tension on the throttle cable that keeps it all together??
the tube that goes throu the fan shroud, does it attach to the flexable tube?
also does the tube tht goes throu the fan shroud have the flare portion to the rear or pulley side of the motor? |
joescoolcustoms Samba Member
Posted: Sun Oct 23, 2016 12:38 pm Post subject: Re: My project Doom Buggy |
Just the tension keeps it together. On the rear side of the engine, (pulley side), the tube is flared and the front side of the engine, (bellhousing side) it is straight and goes up into the flare on the accelerator Boden tube.
I do put a hose clamp on mine like the picture below to keep everything taught.
_________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Oct 23, 2016 9:03 pm Post subject: Re: My project Doom Buggy |
[quote="joescoolcustoms"]Just the tension keeps it together. On the rear side of the engine, (pulley side), the tube is flared and the front side of the engine, (bellhousing side) it is straight and goes up into the flare on the accelerator Boden tube.
Thanks Joe |
Posted: Tue Nov 01, 2016 10:01 pm Post subject: Re: My project Doom Buggy |
ok so now a new problem.
i was going to hook up fuel lines tonight. the fuel line at the front of the frame was missing. so i removed the cover from the front to see where the line was. well turns out it is rotted off back a wys.
what does everyone suggest. i dont want to open up the bottom of the tunnel |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Nov 03, 2016 2:55 pm Post subject: Re: My project Doom Buggy |
thanks Q-Dog
i think i am going to do the second one. easier and faster |
Posted: Wed Jan 04, 2017 9:42 pm Post subject: Re: My project Doom Buggy |
been a while since i did and update. well here it goes
i have totally wired the buggy only thing missing is the alt to battery wire.
i did not buy an expensive harness as i was able to install the gm coloumn into my buggy so totally custom wired. everything turned out as planned.
may not be the best looking harness, and may not be the easiest to trouble shoot. but there is not much to it.
i did daytime running lights and electric fuel pump with low pressure shut off.
go the new mater cylinder install and brakes bled, after messing around with 50 year old brake fluid in the front brake lines. nrew are on order
i am going to install a gel cell u1 lawn mower battery under the rer shelf i think.
it is getting closer and closer.
took the body off the other day to finish the pan off. i am using a DIY roll on bed liner kit. gonna make it nice and thick in the front where it will get all the abuse
all for now i think
Posted: Fri Jan 20, 2017 9:24 am Post subject: Re: My project Doom Buggy |
so got my battery box made and installed
now onto building supports for the rear shelf/seat support, the rear engine cage. |
Posted: Tue Feb 07, 2017 6:39 pm Post subject: Re: My project Doom Buggy |
got the rear shelf support supported
Posted: Tue Feb 07, 2017 6:40 pm Post subject: Re: My project Doom Buggy |
and becasue i am cheap and have access to a pipe bender i am building my own engine cage
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Wed Feb 08, 2017 6:04 am Post subject: Re: My project Doom Buggy |
How will you remove the transmission with the two uprights from the frame horns to the cross member?
I am thinking the same idea, but had to pull my transmission and realized this is not possible with the uprights.
Thanks, Jeff _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Wed Feb 08, 2017 7:23 am Post subject: Re: My project Doom Buggy |
heywebonya wrote: |
Thanks, Jeff |
it will require removal of the tranny mount first the the support shelf |
Posted: Sat Feb 11, 2017 7:02 pm Post subject: Re: My project Doom Buggy |
got some more cage done and also relocated the exhaust |
Posted: Sun Feb 12, 2017 5:39 am Post subject: Re: My project Doom Buggy |
Great looking rear cage. This is coming together very nicely. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Sun Feb 12, 2017 4:14 pm Post subject: Re: My project Doom Buggy |
heywebonya wrote: |
Great looking rear cage. This is coming together very nicely. |
Thanks |
Posted: Wed Feb 22, 2017 12:48 pm Post subject: Re: My project Doom Buggy |
got my antenna mount done and the antenna mounted. its just for looks not function
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Wed Feb 22, 2017 6:15 pm Post subject: Re: My project Doom Buggy |
What's the silver carcass on the rack left rear? _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
Posted: Wed Feb 22, 2017 7:31 pm Post subject: Re: My project Doom Buggy |
hillmotorsports wrote: |
What's the silver carcass on the rack left rear? |
not sure i think it is someones MG in a forgotten state of restore |
Posted: Fri Mar 03, 2017 8:48 pm Post subject: Re: My project Doom Buggy |
should be the last update on the engine cage. put some 3/4" LED lights which are dual element style. also there is a licence plate light on there too.
now onto the last of the body repairs before mounting it again
cwat1982 Samba Member
Joined: June 24, 2014 Posts: 143 Location: Alberta, Canada
Posted: Sat Mar 04, 2017 8:10 pm Post subject: Re: My project Doom Buggy |
Looking' good!!! _________________ 1970 Joe Poty Sand Rover T Bug Pickup, 2095cc |
