nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Tue Mar 31, 2015 7:15 pm Post subject: Horn Grills |
On Deluxe splits where the horn is behind the fender, was a block out plate used between the decorative, round grill and the fender to hide the direct view of the horn, or was the horn visible through the grill?
I've seen it used on the early 60's cars but I'm not sure if it was used on my 49 deluxe? |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Tue Mar 31, 2015 7:39 pm Post subject: |
The block out plate behind the latter style oval shaped horn grills didn't block the sight of the horn. It was used on the fender that didn't have the horn. The side with the horn had an open hole with the grill. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Tue Mar 31, 2015 8:40 pm Post subject: |
drscope wrote: |
The block out plate behind the latter style oval shaped horn grills didn't block the sight of the horn. It was used on the fender that didn't have the horn. The side with the horn had an open hole with the grill. |
Duh, of course you are correct on the location.
My question stands. Was one used on a split? |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Tue Mar 31, 2015 10:17 pm Post subject: |
nlorntson wrote: |
I think no.
Just bare paint behind the grill.
" _________________ Master of my domain! |
xeno Samba Member
Posted: Tue Mar 31, 2015 10:21 pm Post subject: |
He is right, the right fender never received the hole, just the grill to even out the look. _________________ Currenlty Corralled:
1952 Crotch Cooler Deluxe (US specs delivered to Stuttgart, Germany GI.)
1955 Early (Competition Motors - Hollywood, California)
1974 Thing (US specs - Mexicanos)
2008 Rabbit S (Wolfsburg DE)
2012 Golf TDI Tech Package (Wolfsburg DE) |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue Mar 31, 2015 10:24 pm Post subject: Re: Horn Grills |
nlorntson wrote: |
On Deluxe splits where the horn is behind the fender, was a block out plate used between the decorative, round grill and the fender to hide the direct view of the horn, or was the horn visible through the grill? |
Horn was visible through the grill _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Wed Apr 01, 2015 10:16 am Post subject: |
On splits the horn was visible through the grill, but the other fender only had the tab slots to hold the grill on, no hole for the horn sound to get out.
Latter when they went to the oval shaped grills, they had a separate block off plate that went behind the horn grill on the non-horn side. _________________ Mother Nature is a Mean Evil Bitch! |
Suboval Samba Member
Posted: Wed Apr 01, 2015 11:46 am Post subject: Re: Horn Grills |
RareAir wrote: |
nlorntson wrote: |
Horn was visible through the grill |
Glenn is correct. No plate on driver's side. You can see the horn. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Posted: Wed Apr 01, 2015 12:36 pm Post subject: Re: Horn Grills |
Suboval wrote: |
RareAir wrote: |
nlorntson wrote: |
Glenn is correct. No plate on driver's side. You can see the horn. |
Yep. Answered that above
nlorntson wrote: |
drscope wrote: |
Posted: Wed Apr 01, 2015 2:24 pm Post subject: |
Here´s the 1953 parts catalog.
Lists round and oval grills but just an oval backing plate for the right side.
So there was no round one.
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Fri Apr 10, 2015 7:31 pm Post subject: |
view of passenger side front fender, from inside the fender, looking out, without horn grill...
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
splitjunkie Samba Member
Posted: Sat Apr 11, 2015 5:05 pm Post subject: |
There was a round grill backing plate made but it was only used on the split convertible glove box doors. As others have said, the passenger side front fender just had four small slots for the grill mounting tabs. _________________ Chris
kafer52 Samba Member
Joined: October 05, 2012 Posts: 39 Location: Texas USA
Posted: Sat Feb 01, 2020 4:16 pm Post subject: |
drscope wrote: |
Latter when they went to the oval shaped grills, they had a separate block off plate that went behind the horn grill on the non-horn side. |
Resurrecting an old thread - On a Nov '52 Zwitter, on the passenger side front fender, I know there was an oval shape block off plate that went behind the grill. Was there an oval hole being covered on the passenger side or no hole cut in the passenger side fender?
Thanks,
Mark _________________ November '52 Zwitter |
Posted: Sun Feb 02, 2020 5:46 pm Post subject: |
kafer52 wrote: |
drscope wrote: |
Thanks,
Mark |
Using the owners manuals can be a dicey proposition at best since they were so heavily retouched and reused and the cars photographed often had components painted a different color so it would photograph better. However, they can sometimes be helpful in showing when a certain detail first was introduced requiring a new photograph.
This same picture first appeared in the October '52 printing. It appears to be black behind the grill. They never took the time to paint the surface behind the round grill black so you could assume that they wouldn't have done it on the zwitter fenders either.
Based on that it seems pretty likely that they stamped both sides for grills and used the blanking plate from the beginning of the introduction of the oval horn grill.
There is some retouching on the picture, particularly on the fuse box and inspection cover so it is possible that they retouched the grill background but does seem unlikely.
Posted: Sun Feb 02, 2020 7:09 pm Post subject: Re: Horn Grills |
Thanks Chris,
This is very helpful. 👍🙂
FRK Samba Member
Joined: December 09, 2002 Posts: 2652 Location: Orange county, CA
Posted: Sun Feb 02, 2020 11:10 pm Post subject: Re: Horn Grills |
On the left fender where the horn is placed behind the fender the hole only has the round grill and you can see the horn through the hole.
On the right fender there is no hole. there is only 4 tabs for the horn grill.
the covers on the picture below are for the split glovebox doors.
_________________ 64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club |
