roymartian Samba Member
Posted: Thu Apr 02, 2015 5:56 pm Post subject: 383 Cap Repair |
Unfortunately one of the pins in my 383 cap has broken off.
Any ideas for repair idea or replacement.
- solder a new pin in ?
- drill and tap ? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76899 Location: Sneaking up behind you
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Fri Apr 03, 2015 1:20 am Post subject: Re: 383 Cap Repair |
roymartian wrote: |
I have one laying around with the same problem.
I thought of drilling a little hole. Not too deep.
And solder a new made pin in.
But I have not tried yet. _________________ Master of my domain! |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Apr 03, 2015 4:06 am Post subject: |
Those pins are pretty hardy but today's rubber covered ignition wires are much stiffer that the original cloth covered wires. I would suggest using the cloth covered wires with that cap. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Fri Apr 03, 2015 11:43 am Post subject: |
People are asking stupid money these days for those caps. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Glenn Mr. 010
Posted: Fri Apr 03, 2015 12:54 pm Post subject: |
johnshenry wrote: |
People are asking stupid money these days for those caps. |
They are asking stupid money for all cast iron distributor and parts.
But do you want to get stuck on the side of the road because you're using a "repaired" distributor cap and it's not like your local Pep Boys has them in stock. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Apr 03, 2015 1:43 pm Post subject: |
Glenn wrote: |
But do you want to get stuck on the side of the road because you're using a "repaired" distributor cap and it's not like your local Pep Boys has them in stock. |
I have a spare one with me in the car anyway.
As long as a repaired one will work agan, why not? _________________ Master of my domain! |
Posted: Tue Apr 07, 2015 3:48 am Post subject: |
1.25mm drilled, pin made from drill bit, solder drop in hole, pin heater and inserted...
Posted: Tue Apr 07, 2015 9:54 am Post subject: |
That looks like it will work again.
I will do the same with mine. _________________ Master of my domain! |
