jitup Samba Member
Posted: Fri Apr 10, 2015 8:35 pm Post subject: replace or supplement stock oil cooler? |
Hello,
Since I already have it, and I am building my engine to 1955.5 cc instead of stock I am interested in hooking up my oil cooler. I was going to pull off and plate over the stock oil cooler and run my external through a thermostat off of my full flow oil pump. I was also going to ditch my dog house fan shroud for and early fan shroud with no heater ports since I'm going with j-tubes.
But then I found this article.....
http://www.geneberg.com/article.php?ArticleID=238
Now I am considering leaving my stock oilcooler and dog house intact, and just adding my external as a secondary with the themostat still. Any real life input? How do I fill my oil cooler? (its mounted on my roof) How do I keep the oil from draining out of the cooler when the engine is off or the therm is shut? I have searched around the web with no real luck. if you have any advice or links it will be greatly appreciated. |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
Brian Samba Moderator
Posted: Fri Apr 10, 2015 10:57 pm Post subject: |
Don't roof scoop it
jitup wrote: |
I was also going to ditch my dog house fan shroud for and early fan shroud with no heater ports since I'm going with j-tubes. |
Don't do that either. Stick with the stock shroud and plug the heater outlets, that's better than the EMPI or SCAT pos shrouds that don't have cooling veins. Use industrial tins on the J-tubes and you're good to go.
Run the stock doghouse cooler and you'll be fine. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Sat Apr 11, 2015 1:44 pm Post subject: |
Brian wrote: |
Don't roof scoop it
jitup wrote: |
Run the stock doghouse cooler and you'll be fine. |
X2 _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
dustymojave Samba Member
Posted: Sun Apr 12, 2015 3:21 pm Post subject: |
My Baja has a Doghouse cooler and shroud. It also has a cooler mounted under the back window over the louvers. But then that cooler has been there since the mid-70s. It works great.
The doghouse cooler gets air flow whenever the engine is running. But that is only about 1/3 of the engine's oil flow. That's why the oil exiting from the pump cover is called "full-flow". It keeps an engine cool most of the time. Under severe stress, if you need additional cooling, then an external cooler helps. And a thermostat is a good thing to prevent over-cooling.
In your thread on the roof cooler I commented on that subject.
Don't put an oil cooler over the fan intake because that just restricts air flow to the engine and pre-heats the air that gets in.
You know...you COULD put all of these little threads together into one build thread about your whole car. _________________ Richard
SoCalBajas Member
mattfarmer Samba Member
Posted: Mon Apr 13, 2015 7:08 am Post subject: |
I'm glad I saw this post... I've been looking at oil coolers and trying to figure out where I'd like to mount one.
I live in the central valley of Ca, it gets pretty hot and doesn't cool off till late at night, not like where I used to live in southern Ca...
Just to clarify, has anyone run a secondary cooler with their stock dog house cooler? and does it help?? also, if not mounting it on the roof, where would you put it? I was thinking all the way in back of the engine, on the engine cage? |
Posted: Mon Apr 13, 2015 8:45 am Post subject: |
I do in my truck and I never see over 180. But that's a different application.
Have you seen how Mr. Bill did his? He just routed the oil cooler inside the cabin next to the window (which isn't installed)
Putting it towards the back of the car would be interesting. Stick some fins on your pulley to make a little fan for the cooler _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Mon Apr 13, 2015 10:17 pm Post subject: |
mattfarmer wrote: |
I don't recommend mounting a cooler down behind the engine. But mounting one up above the engine on brackets from the hood hinge brackets would work. _________________ Richard
SoCalBajas Member
Posted: Wed Apr 15, 2015 8:06 am Post subject: |
Right on, thank you! |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
Posted: Wed Apr 15, 2015 11:22 am Post subject: |
If you running just a little hotter then you would like. Replace the stock cooler with a Type 4 cooler. It is about a third wider, and really helps in the cooling department. You do have to modify the sheet metal bump on the fan house though. I used a cut off wheel and separated the bumped section down the middle and welded in a strip that was about 1/2" wider. It still clears the firewall nicely, and my temps dropped considerably. I also live in CA and the engine is a 2010, and I do not need an external cooler. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
