Laurie mcCurdy Samba Member
Posted: Mon Apr 13, 2015 1:47 pm Post subject: 2000 passat automatic stuck in park |
2000 Passat wagon automatic stuck in park. gear selector lever moves,gear display reads P in all gears. car wont move!!! cable?? plastic parts in shift mechanism? anyone had this problem? |
Elciteeve Samba Member
Joined: September 26, 2010 Posts: 29 Location: Albany OR
Posted: Mon Apr 13, 2015 3:26 pm Post subject: |
Could be the cylinder for the key. Basically the gear selector isn't being freed when the key is turned to start the car (the gear selector is locked in place until the key is turned to the on position) If that mechanism is faulty, you are stuck in park.
As to why the Gear selector lever still moves, I'm not sure what's going on with that, but that is what has happend to me. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Apr 14, 2015 7:17 am Post subject: |
These cars had a problem and recall for the brake switch. If you press the brake pedal and don't hear the solenoid trip the lockout, there is your problem. I do believe there is a manual release for this mechanism to allow for it's release if the keys are not available in case of towing and such. |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Wed Apr 15, 2015 8:07 pm Post subject: |
The control unit for the trans is in a plastic box under the front passenger carpet. If there was ever a water leak, water will get into the box and corrode the wiring and control unit. First thing I would do is scan the module for faults. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
