tymaster22 Samba Member
Posted: Tue Apr 14, 2015 12:26 pm Post subject: What is causing a slight drag? |
I have a 1966 type 1, with a 1300 motor. When I am driving at 5-10 miles per hour, I can feel something catching and releasing as I am rolling. The only thing I can think of is the shoes may be stuck. Could this be a bad wheel bearing issue? Any suggestion or possible troubleshooting tips would be a great help! |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Apr 14, 2015 1:48 pm Post subject: |
possibly the e brake cable? pull all 4 drums and take a look at things. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Tue Apr 14, 2015 2:41 pm Post subject: |
So the even if the E-brake is disengaged, the cable can still get stuck and keep the brakes on? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Tue Apr 14, 2015 3:46 pm Post subject: |
Jack up one wheel at a time and spin by hand. You should be able to feel any dragging. |
Harris Samba Member
Posted: Tue Apr 14, 2015 6:31 pm Post subject: Slight Drag |
Emergency brake |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Apr 15, 2015 12:00 am Post subject: |
Since it would be more noticeable at "5 to 10 miles per hour", you might also look at your return springs to see if they're strong enough to release the brakes all the way; and also partially clogged soft brake lines that are preventing (at least, partially) the brakes from fully disengaging. you are, after all, usually pressing down on the brake pedal before taking off.
Your problem may also exist at higher speeds, but you're going too fast to know it.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Fri Apr 17, 2015 1:34 pm Post subject: |
KTPhil wrote: |
X2.
Remember all of the safety concerns with a car being jacked up. Make sure car is in neutral and e brake is disengaged when testing the back tires.
Just remember, safety first.
Kyle _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.) |
Posted: Sat Apr 18, 2015 3:51 pm Post subject: |
Thank you for all the advice, I will be doing that this weekend! |
