VolkDubz Samba Member
Posted: Wed Apr 15, 2015 2:31 pm Post subject: Engine stand Problems..... Big, Problems! |
Just bought a volkswagen bench stand, also bought a roll around stand..... Want to use the Volkswagen stand on the roll-around.... The hole is to big, harumph! what to do? anybody got any suggestions on how to marry the two together?
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Apr 15, 2015 2:51 pm Post subject: |
Off to the muffler shop for some short lengths of pipe in ever increasing sizes that sleeve together, build up the black part until it fits nicely in the yellow one. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Brian Samba Moderator
Posted: Wed Apr 15, 2015 2:59 pm Post subject: |
Expensive idea: Find proper sized bearings that have and ID of the OD black part and OD of the ID of the stand. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Wed Apr 15, 2015 3:14 pm Post subject: |
Weld the bench portion to the yellow stand _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Dauz Samba Member
Posted: Wed Apr 15, 2015 3:32 pm Post subject: |
mcmscott wrote: |
Weld the bench portion to the yellow stand |
QFT |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Wed Apr 15, 2015 3:55 pm Post subject: |
Get a piece of pipe that the small pipe fits into, drill a hole for the screw handle and weld that inside the top of the rolling stand. then weld a nut on the top so you cant tighten it with a threaded T-handle at what ever angle. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
bpritchert87 The Idea Man
Joined: February 26, 2007 Posts: 1507 Location: Wisconsin
Posted: Wed Apr 15, 2015 4:29 pm Post subject: |
mcmscott wrote: |
This is how I had mine setup before I had the adapter made.. Worked ok but the better way is to make an adapter.. I never trusted my welds and it did not look quite right.. it did work however... Maybe a local machine shop or tech school/community college will have a manual lathe "class" that could turn something up for you for little to nothing.. cheap 1018 steel or 1020 CRS would be fine.. _________________ Knowledge is Power Read and Learn !!!
The Intelligence of a Man should not be measured by his age....
check out my sand rover t bug build! http://www.thesamba.com/vw/forum/viewtopic.php?t=287204 |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Apr 15, 2015 4:35 pm Post subject: |
Cut the collar off the plate and have someone weld it to the VW yoke. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Wed Apr 15, 2015 5:12 pm Post subject: |
Weld a plate to the vw piece and bolt onto yellow plate... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Avalon'cha Samba Member
Joined: March 30, 2015 Posts: 16 Location: South Carolina
Posted: Wed Apr 15, 2015 5:30 pm Post subject: |
Y'all silly! I just drilled extra holes in my regular stand for more adjustability & some spacers made of pipe to give more room to work around the fly. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Yep.... Cut and weld.
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Apr 15, 2015 5:50 pm Post subject: |
Will the VW yoke fit into back side of the "Yoke" that came with stand?
Seems the bench model yoke has extremely small tube rather the yoke for "stand"...
Go to local "steel sales" and see if you can get a couple of short lengths of tube that will "telescope"....
This is what most of us use....
http://www.thesamba.com/vw/classifieds/detail.php?id=1176339
Posted: Wed Apr 15, 2015 6:33 pm Post subject: |
Wow, thank you all for the overwelming amount of choices that I can choose from.... I'll give it some thought overnight and post some pics of my complete piece..... thank you all again |
Posted: Wed Apr 15, 2015 9:20 pm Post subject: |
Well I took the least destructive method out of all the ideas, I saved the original mount by just cutting below it. Then I just welded up around the base of the VW mount and vhoila! cant wait to get the motor on it, just need some bolts....... I guess it's hardware store tomorrow Thanks again to everyone for your help!
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Thu Apr 16, 2015 3:58 am Post subject: |
Or get the VW Alley yoke that fits, vs the cheap Chinese POS.
_________________ Glenn
Member #1009
#BlueSquare |
mark tucker Samba Member
Posted: Thu Apr 16, 2015 5:50 am Post subject: |
make an addaptor like glen shows and weld it to yours. the little shaft they have now twist oh so easy. |
Posted: Thu Apr 16, 2015 8:55 am Post subject: |
Glenn wrote: |
Yeah I wish I would of known there was a differance before I bought it...... out of all the Engine Stand threads that I read none of them ever mentioned a bench vs roll around stand size differance...... Oh well, if I spend another chunk of money the ol' lady gonna have my backside |
Posted: Thu Apr 16, 2015 8:56 am Post subject: |
VolkDubz wrote: |
Glenn wrote: |
By the way, what size bolts/nuts are you using to connect to the motor? |
Posted: Thu Apr 16, 2015 12:50 pm Post subject: |
Same size as standard engine/trans "connection"... Use stud on bottom with spacer and nut...
