Lola Racing Samba Member
Joined: March 27, 2014 Posts: 44 Location: League City, TX
Posted: Thu Apr 16, 2015 8:31 am Post subject: Street performance heads |
Who do you think sells the best performance heads for a low budget? |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Apr 16, 2015 8:48 am Post subject: |
How low of a budget? |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Apr 16, 2015 9:02 am Post subject: |
Tims are really hard to beat.
http://www.thesamba.com/vw/classifieds/detail.php?id=1069091
37x32 SS 219.00 Per
40x32 229.00 per
I have used both and just needed to smooth the chamber and beginning of port with a flapper.
The SS look exactly like these but with smaller valves. I forgot to doc pictures of them. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
mark tucker Samba Member
Posted: Thu Apr 16, 2015 9:27 am Post subject: |
cheepest Ive seen is the scat prostreet, 40x35 ported for around $210 each,Ive used a few sets on other peoples builds. then comes the more expensive cb stuff. lost pan of cheetos &th 044 line up of heads are all good and lots to choose from for any size &usage. unlike one stage fits all. mofo's are nice but there not ported.it all depends on your usage,budget and what you expect. |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Thu Apr 16, 2015 10:22 am Post subject: |
I like the DRD stuff. Dan |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Thu Apr 16, 2015 10:38 am Post subject: |
Nobody in the world has cheaper Made in the USA street performance aircooled cylinder heads than me.
Our 040 and 041 heads have standard intake and exhaust ports.
Our 042 castings come with larger intake and exhaust ports cast into the head so there is no need for porting.
Our 050 castings come with a "D" shaped intake port and the same exhaust port as the 042.
Just click on the facebook link below to see the video I took on Monday of our heads being poured at the foundry. You can also type Roy or Mofoco into youtube to see some older videos of the same. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Thu Apr 16, 2015 3:58 pm Post subject: |
Mofoco sells very good heads at a good price, I have run many sets with good results. I also like the Tim's heads but I have not bought any since they went to the Chinese castings. |
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Thu Apr 16, 2015 4:01 pm Post subject: |
MoFoCo |
woodsbuggy Samba Member
Joined: December 15, 2007 Posts: 210 Location: NE Indiana
Posted: Thu Apr 16, 2015 5:19 pm Post subject: |
DRD, Darren does great work and NO Drama! _________________ The empty can rattles the most! |
Posted: Thu Apr 16, 2015 5:33 pm Post subject: |
woodsbuggy wrote: |
DRD, Darren does great work and NO Drama! |
My first set DRD Heads were great, the second set he had to send back after 7 months because he was to busy. I would call that Drama! I have bought six sets of Tim's heads with 3-4 week turn around. DRD does do great work. |
Posted: Fri Apr 17, 2015 7:17 am Post subject: |
so where do you buy the low priced mofoco heads? I used the scat heads because the owners couldent afford the mofo's I recomended to them....or is this a play on words???cheepest made in the USA.when the cheeper heads are offshore heads. |
Posted: Fri Apr 17, 2015 9:17 am Post subject: |
What Roy said is actually the truth. Cheapest US made heads. Just one comment however, i personally think that stainless valves should be included. _________________ 2276 IDA's 86C 11-1 DD !
theDrew Samba Member
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Fri Apr 17, 2015 10:01 am Post subject: |
MOFOCO X2 _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri Apr 17, 2015 3:29 pm Post subject: |
Power is in the heads and this is where you need to spend the money to get good heads. There are other areas where you can cut corners and go cheap but not on the heads.
I'd get Steve Tims or DRD or Aircooled.net heads. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Fri Apr 17, 2015 7:07 pm Post subject: |
no need for porting.......this too go's for single port heads and every other head.just like there is no need for a stroker or biger bore....unless you have the need for speed. |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Fri Apr 17, 2015 9:30 pm Post subject: |
the best "street heads" are the ones custom ported, cc'd etc by a competent head guy (theres only a few of these guys in the country that I'd have do my heads) for your own individual motor build.
Tims, DRD, Mofoco, CB etc all offer great heads, but runnin them "off the shelf" is leaving potential power on the table.
i have a set of custom worked CB 044's in my 2180 and couldn't be happier. my builder has tons and tons of experience putting together bullet proof reliable daily driver engine combo's from mild 1600's all the way to radical 2387's, his motors make anywhere form 80hp on up to 200+hp and he specializes in daily driver engines - meaning true daily drivers, drive anywhere on 87 pump gas and get up to 300k+ on the bottom end of his motors with heads/vavle jobs every 60-80k or so. I trust his head work implacably for my desired application.
the, for the most part, minor differences between one vendors heads and another are minute compared to custom working any of these heads to work to their fullest potential for your individual custom motor combo. One guys best for him mofoco heads may not be the next guys best for him DRD heads, which again may not be the best for the third guys Tims heads. _________________ 67 bug x3
67 ghia
64 bug |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3465 Location: Paradise, Ca
Posted: Sun Apr 19, 2015 9:25 pm Post subject: heads |
MoFoCo. Reasonably priced and you can support our country as he starts with his own USA made casting. The little money that you might save by purchasing slightly cheaper china/offshore heads is not worth that guilty feeling u get later, like when you purchase something that used to be made in America and you find the "Made in China" sticker. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Mon Apr 20, 2015 7:15 am Post subject: Re: heads |
jpaull wrote: |
MoFoCo. Reasonably priced and you can support our country as he starts with his own USA made casting. The little money that you might save by purchasing slightly cheaper china/offshore heads is not worth that guilty feeling u get later, like when you purchase something that used to be made in America and you find the "Made in China" sticker. |
If you are so worried about a "Made In USA' part then why did you buy a "Made In Germany" car instead of a Ford or Chevy? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
