mykafone Samba Member
Joined: March 09, 2014 Posts: 19 Location: La Quinta, CA
Posted: Thu Apr 16, 2015 2:12 pm Post subject: Lots of Smoke and Low Compression Help |
I need a little help again on my 1835 buggy
Running good, then it started to produce lots of smoke and you can tell it is burning oil.
Pulled the plugs and the two forward(1 and 3) front spark plugs are really oily and lots of build up all over them.
Did a compression check. all 150# except #3 which is 120#. slowly turning the motor over you can audibly hear #3 "swwissssh" as the motor turns over.
pulled the end of the header off so I can see 4 separate exhausts and 95% of smoke seems to come from cylinder 1.
I pulled the head off of the side with low compression and there is no scratching of any sort on they cylinders so hopefully the rings are ok. there is a ton of build up on the head and the valves.
cylinder and valves for #3
cylinder and valves for #4
I haven't pulled the head on the other side yet but I will tonight. Based on some phone advice from my bother in law I pulled the head and am planning on taking them to machine shop to have them checked out.
any thoughts? any advice? Why is the problem on the two front cylinders and not just one side? Thanks in advance |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Thu Apr 16, 2015 5:36 pm Post subject: |
What carb's are you running? Single or Dual? Those are thin wall 92's, did you over heat it? We need more info. |
TURBOEDVW Samba Member
Posted: Thu Apr 16, 2015 7:46 pm Post subject: |
Are those 90.5s?? That would be a 1776? Look like AA pistons to me. I broke an AA ring land but it was from detonation and 15 psi boost. |
mark tucker Samba Member
Posted: Fri Apr 17, 2015 7:12 am Post subject: |
head joints looked to be leeking some,not bad,probably when cold.pull cylinders&check pistons&rings for breakage & tension . pull appart heads check guides&vj,port if needed clean & reassemble after all is right.use stainless ex valves(or both in&out stainless valves)gap keepers.cut out step,set deck to 0 and use .040 copper head gadgets.tune properly,remove rag from fan and go have fun. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Fri Apr 17, 2015 8:39 am Post subject: |
It's all because of those EVIL Type III COOL TINS!
:2gunfire:
Unless this engine has a Type III cooling system. Then it was something else.
_________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Fri Apr 17, 2015 3:18 pm Post subject: |
SBD wrote: |
Unless this engine has a Type III cooling system. Then it was something else. |
I totally disagree. On a Buggy with an exposed engine I believe the "Cool Tins" actually help _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Fri Apr 17, 2015 7:38 pm Post subject: |
It has dual Kadron carbs on it.
I'm new to the hobby, minus a vw bug when I was 14, and I felt like I had the carbs dialed in pretty well. I was always tinkering with them. My gut feeling is yes I probably ran it too lean, but I've driven the heck out of it and when this happened it was in a short trip to the gas station. Soooooo????
I was told it was an 1835 but by all means I would not be surprised if it's not. Honestly I don't even know how to tell. The piston seems to have 90.43 stamped on it. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Fri Apr 17, 2015 8:40 pm Post subject: |
Check the rings and check the guides.
You cannot SEE if a ring is sealing or not, but you can check the gap and side play. There is a lot of DUST on those jugs, too much of that kills the cast rings very fast unless it has good airfilters |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Fri Apr 17, 2015 10:01 pm Post subject: |
Your rings are toast, and the heads will need disassembled and cleaned up too _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
Last edited by Dr OnHolliday on Sat Apr 18, 2015 2:37 pm; edited 1 time in total |
g3bill Samba Member
Joined: March 30, 2015 Posts: 247 Location: So. Cal usa
Posted: Fri Apr 17, 2015 11:59 pm Post subject: |
Please let us know what caused this damage when known. I'm looking at the AA Hypertec piston sets but with thick wall. Seeing as there made in China I dont know the quality, also wonder if the rings were made there also, if so I'd most likely install better rings anyway if rings are interchangeable from brand to brand? I thought thin walled P/C sets were ok with bugs or light weight VW's... I wonder about the discoloration of the one jug, like it over heated? _________________ I have Dial-Up an a hole in my pocket:)......Where are the 3 Stooges when we need them:)
'67 Camper PT westfail w/tent, hammock, jump seat. uping the motor to 1900 w/88bore/78crank.
& will be using carb 34 pict 3 ....Someday?
'82 Toyota 4x4 5sp PU lb, daily driver
Many Corvairs /& 4 rag tops
'63 Chevy 20 Truck w/4sp 292
Want, white plastic end pieces for dash grab handle |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sat Apr 18, 2015 12:05 am Post subject: |
90.5 usually aren't thought of as "thin walled." The AAs come with nice cast iron rings that seal quickly, but yes you can replace them with others easily enough - they are a standard size. A broken ring or dropped guide are the most likely answers, but we'll have to wait and see. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Fri May 01, 2015 11:04 am Post subject: |
Ok I took both heads down to the machine shop and had em checked out. All good.
I took the cylinders next and had em mic'd. they were .004 on the bottom and .005 on top.
I believe that is within spec according to the back of my parts magazine. It says side clearance is .004-.016 Does this sound correct??????????
So I guess im going to slap on new rings and give her a whirl.
How do I know what thickness of rings to choose from?
It looks like it has "total seal rings on it" since there is one on top and two on bottom. but im not sure.
Any more advice would be greatly appreciated to get me through this project.. Thanks |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Fri May 01, 2015 11:01 pm Post subject: |
How did the machine shop check them? If the chambers aren't blasted or had the carbon removed, they didn't check well enough. If you had adequate clearances, no signs of bad scuffing, and your heads were fine, there wouldn't have been a problem. I think a crack in the chamber is the issue. Was there any pooled up oil in any of the chambers? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Mon May 04, 2015 11:12 am Post subject: |
Im not sure how he checked em. He just told me they were all at "40"(i think thats what he said) and good to go.
There was oil pooled in the #1 cylinder when I pulled it.
Ive checked everything over for cracks and I didnt see any, but I will check again more thoughly tonight. |
W1K1 Samba Member
Posted: Mon May 04, 2015 11:32 am Post subject: |
this you couldn't see from the outside of the heads, but it had all the same symtoms you describe. A ton of smoke & oil, and it fell out when I pulled the valve.
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Thu May 07, 2015 9:24 am Post subject: |
I closely inspected the heads again and no visible cracks.
After closer inspection of the pistons and rings I noticed that the oil rings on the 2 cylinders that had the most carbon buildup were showing signs of wear. the inner ring is showing wear ont he little bumps in the rings. the cylinder that had the oil inside has the most wear on this ring. could this be the issue??
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Thu May 07, 2015 7:37 pm Post subject: |
Sounds like they only checked if the valves leaked.
That is not your issue, and the heads needs to be taken apart.
I'm guessing the problem is in the heads. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
modok Samba Member
Posted: Thu May 07, 2015 8:57 pm Post subject: |
mykafone wrote: |
Yeah it's worn out. I told you to check ring gaps..........
You have to hone the cylinder to use new rings. |
