tavogalarza Samba Member
Joined: July 17, 2008 Posts: 30 Location: Ellenton ,Florida
Posted: Thu Apr 16, 2015 9:17 pm Post subject: What type of turbo do I need for a 2.0L type 4 engine? |
HI, I have a 1972 Baywindow camper that I would like to ad a turbo. Does anybody know what type of turbo do I need? Any intake kits available on the market? Any step by step info will be appreciated. [/img] |
deronmoped Samba Member
Joined: November 18, 2006 Posts: 375 Location: San Diego
Posted: Thu Apr 16, 2015 10:48 pm Post subject: |
I've turbocharged a couple of engines and what I've learned is, it is not very easy. The best thing to do is get a kit and even at that, there is a big learning curve. Even if you get a kit, there will be quite a bit of things that need to be done that the kit does not cover. The added heat is one of them. You will be dealing with parts that get cherry hot and you need to shield other parts from this intense heat. Fuel is another big issue. You need lots more of it in the right amount. That is where a well designed kit will address this. |
timvw7476 Samba Member
Posted: Fri Apr 17, 2015 2:31 am Post subject: What type of turbo do I need for a 2.0L type 4 engine? |
as I recall, the prevailing theory is: the type 4 exhaust ports do not make
for a decent boosted engine, type 1 is far superior in actual use, so in this
case, swapping to type 1 turbo power makes the most sense.
Now you have to choose carb, carbs, or EFI for your monster. |
Bleyseng Samba Member
Posted: Fri Apr 17, 2015 5:42 am Post subject: |
What? The exhaust ports? No the problem is cylinder to head sealing on any air-cooled engine and heat. Too much boost and you melt the pistons.
A couple of 914 guys have done it with 1.8 and 1.7L engine using CIS FI. I knew of two 2.0L engines, one used a wet systems and the other used Djet FI but kept the boost below 10psi.
Crown engineering made a kit and they show up at swap meets so look for one. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Fri Apr 17, 2015 8:23 am Post subject: |
Bleyseng wrote: |
Crown engineering made a kit and they show up at swap meets so look for one. |
All of that and the fact that the exhaust for a turbo (obviously) will need to be full custom and have to have good exhaust port sealing along with a support system to hold up the combined weight of header, turbo and associated hardware. Ray |
danfromsyr Samba Member
Posted: Fri Apr 17, 2015 9:43 am Post subject: Re: What type of turbo do I need for a 2.0L type 4 engine? |
I'm of the opinion this falls into the "If you have to ask, you probably shouldn't be doing it" category.
has someone done it. sure most likely, should you do it most unlikely.
there's sure to be a huge learning curve.
but you might want to go over to www.shoptalkforums.com in the Forced Induction forum and find some real world users/builders.
*minor credential qualifier (if any), I've ~20yrs experiance of hooking up the wrong fuel parts to the wrong engines, from CIS to mega squirt with varying yet successful results. also quite familiar with the concepts and principals of forced induction. know enough to say no (unless it's purely a toy and not the family Truckster(tm) .
tavogalarza wrote: |
Abscate wrote: |
Posted: Fri Apr 17, 2015 7:47 pm Post subject: |
deronmoped wrote: |
Posted: Fri Apr 17, 2015 7:48 pm Post subject: |
deronmoped wrote: |
I think there is a lot to learn about this for sure.Would it be better to swap to type one engine instead? |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Fri Apr 17, 2015 7:58 pm Post subject: |
Probably not.
What size T4 do you have? How many miles are on it? What waste a bunch of money with a turbo and an unknown engine? Find a T4 builder in your state and build a kick ass T4. You bus will be fast, reliable and won't have any heat issues. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Fri Apr 17, 2015 8:06 pm Post subject: |
richparker wrote: |
Probably not.
What size T4 do you have? How many miles are on it? What waste a bunch of money with a turbo and an unknown engine? Find a T4 builder in your state and build a kick ass T4. You bus will be fast, reliable and won't have any heat issues. |
It's a 2.0 rebuilded . about 3500 miles ago. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Apr 17, 2015 8:36 pm Post subject: |
Perhaps a Floyd R. Turbo? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Fri Apr 17, 2015 8:51 pm Post subject: |
depending what your goals are, just go Subaru and uck the aircooled stuff. you will be happier in the end.
trust me, you have enough disappointment in your life now to even play with keeping a turbo aircooled alive for long.
you can build a 200+h/p n/a pretty cheap (like cheaper than a "quality" T4 rebuild)
with some creative engineering, you can squeak a turbo subi lump in too. I just had my bus well over 100 the other day. it's not all it's cracked up to be. fwiw, the "P" in mph is about 118 _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
