steveoutlaw Samba Member
Joined: November 14, 2014 Posts: 211 Location: Woodbridge, VA
Posted: Sat Apr 18, 2015 7:18 am Post subject: Replacing front beam |
The 70 ghia I bought had drop spindles put on it and I'm looking to bring it back to the original height. It also has no pads left on the brakes and lots of grooves in the rotors.........
So, I'm looking to replace the front beam and get new disc brakes for it. Question is, should I stick with the 4 lug or convert to 5 lug? Also, does anyone know of a good deal that will include the beam and brake set......basically a whole new front end?
TIA. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Sat Apr 18, 2015 8:19 am Post subject: |
You don't need a new beam. Just replace the dropped spindles/brakes with stock ones. Someone on here will probably offer to trade straight across. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
craigman Samba Member
Posted: Sat Apr 18, 2015 9:27 am Post subject: |
yep, if it's lowered disk spindals I'd trade you strait across for my stock disk brake spindals off my 72. I'll even pay for shipping! |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon Apr 20, 2015 3:38 pm Post subject: |
Hi. While you have the front end apart, check the ball joints for needed work. The rotors are all the same for the 67-74. Three different styles of calipers. Service wheel bearings. Inspect tie rod ends. Possible rubber brake hoses. A possible advantage is the different calipers fit all the oem spindles.
Hope this helps, Bill. |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Tue Apr 21, 2015 4:50 am Post subject: |
why would you want to change the lug pattern from stock 4 to wide 5? (other than being able to run early steelies or other wide 5 rims) _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Posted: Tue Apr 21, 2015 10:20 am Post subject: |
First, thanks to all for the replies. Couple of things:
Found out that the beam is fine and the spindles are stock. Anyway, I'm just going to replace it with the stock brake kit and keep the 4 lug wheels. I wanted to go to the wide 5 to have more options for rims but I think I'm just going to keep it stock for now. |
Posted: Thu Apr 30, 2015 11:05 am Post subject: |
I haven't been able to find a definite answer on the 4 to 5 lug question. Can I simply replace my 4 lug rotors/drums with 5 lug? I'm getting ready to replace them anyway so might as well get what I want.
I like the rim options that come with the wide 5 lug pattern. |
c21darrel Samba Member
Posted: Thu Apr 30, 2015 4:51 pm Post subject: |
Well crap! Looks like I'm sticking with the 4 lug. |
Posted: Sat May 02, 2015 5:38 am Post subject: |
Do they make a Porsche pattern 5 lug rotor that would fit my current setup? Those are the exact rims that I want. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
