Is this a 356 ignition switch? Need help.
tweet
tweet is offline
PostPosted: Tue Apr 21, 2015 8:17 am    Post subject: Is this a 356 ignition switch? Need help. Reply with quote
I just recently purchased and received this ignition switch. It was advertised as a "356" oem part. Upon closer inspection, now I am not sure. I bought it for a friend and I do not want to send him the wrong switch.
The lock uses a K300 series key profile and has 10 receptacle connectors on the back side. The bakelite has a "K" logo and the top metal housing has part #21585.
Any help is greatly appreciated.
fcampbell356
fcampbell356 is offline
PostPosted: Tue Apr 21, 2015 11:30 am    Post subject: Switch Reply with quote
Yes, looks like for 356BT6 and 356C . Just needs the chrome bezel to mount in
dash.
The K is for maker Kostal (spelling)?
tweet
tweet is offline
PostPosted: Tue Apr 21, 2015 11:49 am    Post subject: Reply with quote
Thank you, .My concern is that it might be for 911/912. It seems some 356 switches are shown with 10 connectors or 11 connectors The same differences seem to appear in ads for the 911/912 as well. I also see them advertised as "Kirsten" brand. Can anyone explain these nuances?
Jacks
Jacks is offline
PostPosted: Tue Apr 21, 2015 6:34 pm    Post subject: Reply with quote
.l..
Jack Staggs
Actual name
Jacks
Jacks is offline
PostPosted: Fri Apr 24, 2015 12:29 am    Post subject: Reply with quote
You asked if anyone can explain. I did. It took a bit of time to write. A simple "thank you" or "I don't give a rats ass" might be appropriate. Never mind tweet. I'll be sure to not answer to you again. Post deleted. Hope you didn't save it.
Jack Staggs
Actual name
tweet
tweet is offline
PostPosted: Fri Apr 24, 2015 7:01 am    Post subject: Reply with quote
Hello Jack,
As it happens, I did not see your post. I don't know why, but I did not receive a notification that there was a second reply to my query. If I was aware of your reply I would have replied to thank you as well. As far as I could tell there was one answer and I was still waiting to see if anyone else would respond. In my original question I did state that I am appreciative of any help, and I am so thank you as well. Sorry for the mix up but the internet and messaging are not fullproof.
jt912
jt912 is offline
PostPosted: Fri Apr 24, 2015 1:15 pm    Post subject: Reply with quote
That may also be for an early 911/912. I know the later used a spade terminal, but I think the early also used the bullet type terminal. I'll check my 912 after work.
tweet
tweet is offline
PostPosted: Fri Apr 24, 2015 1:48 pm    Post subject: Reply with quote
Hello Jt,
That is what was throwing me off. I see them advertised as for 911/912 along with ads for 356. Thanks for checking.
jt912
jt912 is offline
PostPosted: Fri Apr 24, 2015 4:46 pm    Post subject: Reply with quote
Confirmed it is the same style as an early 912.
tweet
tweet is offline
PostPosted: Fri Apr 24, 2015 8:43 pm    Post subject: Reply with quote
Thanks for the picture Jt. So of the two switches visible, the bullet terminal one is your ignition switch?
jt912
jt912 is offline
PostPosted: Fri Apr 24, 2015 8:59 pm    Post subject: Reply with quote
Yes. The other one is my headlight switch.
puppynuts
puppynuts is offline
PostPosted: Wed Jun 03, 2015 6:12 am    Post subject: 356 key switch Reply with quote
that is a 100 series key switch. A and T5.
tweet
tweet is offline
PostPosted: Fri Jun 05, 2015 8:10 am    Post subject: Re: 356 key switch Reply with quote
Hello,
Thanks for the input, but I am a little confused about what "A" and "T5" mean. The lock is marked with a "K" series lock code and the K300 blank does insert into the keyhole fully.
fcampbell356
PostPosted: Fri Jun 05, 2015 8:45 am    Post subject: key Reply with quote
"A" is for the early 356A, and the T5 is for the early 356B.
This K300 series is for the later 356B/C 1963 on.
tweet
tweet is offline
PostPosted: Fri Jun 05, 2015 9:05 am    Post subject: Reply with quote
Thank you for the clarification, it helps a lot.
