jl_1303 Samba Member
Posted: Tue Apr 21, 2015 4:12 pm Post subject: Which one is a more quiet Exhaust? |
I put on the A1 Sidewinder on my 2276 the other day. It was wow, I mean really loud, especially from 2500 rpm onwards.
This is the A1 Sidewinder I put on.
Having said that, I also have another Berg exhaust laying around that I could use.
The Berg system
Is this a hideaway muffler or single QP? Is this quiet?
If this is also not quiet, should I be getting the dual QP like the one Glenn uses.
Thanks for your help. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3682 Location: Eastern WA
Posted: Tue Apr 21, 2015 4:19 pm Post subject: Which one is a more quiet Exhaust? |
The Berg one is not a hideaway, it is a single quiet and will/should be quieter than the A1. I have that same muffler on my 1776 out of my 61. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Tue Apr 21, 2015 7:57 pm Post subject: |
Or of this CSP Competition Exhaust is a more quiet option:
vwsb74 Samba Member
Posted: Tue Apr 21, 2015 8:03 pm Post subject: |
Look at my gallery. I have a1 sidewinder with glass pack . _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Posted: Tue Apr 21, 2015 8:13 pm Post subject: |
vwsb74 wrote: |
Look at my gallery. I have a1 sidewinder with glass pack . |
Is that quiet? |
vwsb74 Samba Member
Posted: Tue Apr 21, 2015 8:18 pm Post subject: |
jl_1303 wrote: |
vwsb74 wrote: |
Is that quiet? |
Yes! I can't stand the stock a1 muffler noise too:( _________________ 74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Apr 21, 2015 9:32 pm Post subject: |
Either way, you will give up some performance the further you migrate from the A1. It is a better flowing exhaust from the choices. However, if you need quieter, the Berg is is probably the best compromise and i would suggest doing a dual merge muffler if the single isnt quiet enough.This is the performance compromise thay we all deal with on many levels. You should listen to my wasp stepped header and empi phatboy, its a whole nother decibel level. More performance, the more we all compromise someplace. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
vwsb74 Samba Member
Posted: Tue Apr 21, 2015 9:47 pm Post subject: |
Adding a straight pipe glass pack won't hurt performance I think. If there is maybe 3hp or less. _________________ 74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
74 Thing Samba Member
Posted: Wed Apr 22, 2015 8:14 am Post subject: |
It's the muffler not the header. You are getting the droan when cruising. You can try a different muffler. I spoke to someone running the same exhaust as you and had them remove the A-1 (I believe Magnaflow) muffler and replace it with one of the Dynomax VT mufflers and it helped a lot (has a flapper to cut down on the droan when cruising). http://www.dynomax.com/mufflers/dynomax-vt-mufflers
Also some have run the exhast into one muffler on the passenger side and then from there run a pipe under the tranny cradle and into another muffler on the driver side and out the back. This is supposed to really cut down the noise.
What size is that Berg set up-PM me about it. Thanks! |
Posted: Wed Apr 22, 2015 11:06 pm Post subject: |
How is the Dual QP compared to the stock exhaust in noise level? |
Posted: Wed Apr 22, 2015 11:17 pm Post subject: |
vwsb74 Samba Member
Posted: Wed Apr 22, 2015 11:18 pm Post subject: |
You see the pea shooter on your sidewinder? Just remove that and install the straight pipe glass pack like you install the peashooter . You will be amazed how quiet your engine on the freeway .
[img][/img] _________________ 74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7179 Location: Videbaek Denmark
Posted: Thu Apr 23, 2015 1:57 am Post subject: |
One muffler alone will not make the exhaust quiet, A1 or Berg. The Berg - may - be an expansion type muffler. Those will quiet it down a little more on cruise, but they will still bark at wot.
If you think that style of muffler (A1 with pea shooter look) is loud, the Berg will be a disappointment too for ya.
The solution with one muffler in extension to the sidewinder is not always good. On engines with cam durations in the 256-263 degrees @ 0,050 the exhaust length is apparently very wrong, because it hurts performance a lot. On these engines we do a "road racing" style muffler system with one muffler on each side of the engine, in line, and the piping crosses under the transmission. That works very well, and only kills 2-4 hp.
If you chose a black steel type dual QP like the Bugpack brand, if you can still get those, they are quieter than a sidewinder, but the ground clearance is annoyingly low. Dependant on the header of course, these start to limit the engine at around 150 hp.
T |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Thu Apr 23, 2015 2:17 am Post subject: |
Go with the berg header and find some dual QP mufflers! |
Rome Samba Member
Joined: June 02, 2004 Posts: 9602 Location: Pearl River, NY
Posted: Thu Apr 23, 2015 3:45 am Post subject: |
If you pursue a different muffler than the one you now have for the Berg header, note the position of the triangular mounting flange on the muffler. Namely, the header has the flange oriented so that the bottom edge is parallel to the ground. This was Berg's design for a header on Ghias and Busses, so that the lower two pipes and the 4-into-1 collector came up slightly higher for better ground clearance. You needed to buy a matching muffler which also had its flange located the same way. By contrast, most generic headers have that flange with the right side vertical. That would mean that a generic muffler would not fit your Berg header unless you cut and rewelded either flange to match the other component.
Posted: Thu Apr 23, 2015 3:47 am Post subject: |
Alstrup wrote: |
T |
Do you have a picture that you can post to show?
On the other hand, what do you think of the CSP Super Competition? Is that a quiet exhaust, in your opinion? |
Posted: Thu Apr 23, 2015 4:55 am Post subject: |
Rome wrote: |
Good point.
I now recall a couple of years ago I had this Berg Dual QP I bought from a fellow Samba member. I tried to fit that to this header and found that the orientation of the flange does not allow the Dual QP to go horizontal and I thought that may not be a Berg Dual QP, as it did not fit.
Do you know if Berg sells a Dual QP that would fit this header? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Thu Apr 23, 2015 5:22 am Post subject: |
I have a Berg header and dual QP. i tried a Magnaflow Phat Boy but it was obnoxiously loud and removed it after a 5 mile drive.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Apr 23, 2015 5:44 am Post subject: |
Glenn, how does the Dual QP noise compared to stock? |
Glenn Mr. 010
Posted: Thu Apr 23, 2015 6:39 am Post subject: |
I haven't had a stock engine/exhaust in 35 years.
You tell me.
Member #1009
#BlueSquare |
