blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Wed Apr 22, 2015 2:53 pm Post subject: What can you use for the two foam rubber seals rear fender ? |
When I get around to replacing my right rear fender there is the seal around the cool air intake grill also there are two impregnated foam rubber blocks at the top corners. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22411 Location: Kimball, Mi
Posted: Wed Apr 22, 2015 7:46 pm Post subject: Re: What can you use for the two foam rubber seals rear fend |
blues90 wrote: |
Isp sells the foam seal. As for the foam blocks, you can use some foam from an old chair your neighbor is throwing out, as nobody offers them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Dodgy Samba Member
Joined: January 30, 2006 Posts: 517 Location: Leicester, UK
68vwfasty Samba Member
Joined: March 26, 2014 Posts: 277 Location: Portland, OR
Posted: Thu Apr 23, 2015 1:21 pm Post subject: |
Like Bob said you can find some foam pretty easy that will work. I got mine from a foam pad used to apply car wax. The key is to find some foam with the proper thickness and then cut to length and width. I glued them in with spray adhesive and then I applied a little light oil to them. Careful putting the fender on, I think I knocked one of mine off accidentally and had to glue it again. |
vwsplitvan Samba Member
Posted: Thu Apr 23, 2015 3:17 pm Post subject: |
The rubber/foam seal from Woolies works a treat.
I have some neoprene sheet 25mm that I cut into 25mm x25mm cubes. That is just right and does not absorb moisture.
If u need some just let me know. _________________ SBS #20 UK
RHD 62 Ragtop Beetle Beryl Green
LHD 69 Squareback Peru Green
LHD 63 Splitscreen Highroof Pearl White |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Apr 23, 2015 3:25 pm Post subject: |
vwsplitvan wrote: |
Yes, critical point is that you must use CLOSED cell foam, not OPEN cell foam, or it will act like a sponge and rust the area out. |
Posted: Thu Apr 23, 2015 6:40 pm Post subject: |
vwsplitvan wrote: |
If u need some just let me know. |
Sure I could use some but you are all the way in the UK. |
Posted: Thu Apr 23, 2015 8:54 pm Post subject: |
blues90 wrote: |
vwsplitvan wrote: |
McMaster Carr sells the closed cell foam too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
