cdub65 Samba Member
Joined: April 23, 2014 Posts: 61 Location: Las Vegas, NV
Posted: Thu Apr 23, 2015 2:20 pm Post subject: Oil pump issue |
So after putting my refreshed 1600 in my 65 bug i had oil leaks. So after i got them to stop i still have some oil leaking out of the top of the oil pump. (seems that's where it is coming anyways). I went ahead and took it back off put all fresh gaskets on it and still leaks and its leaking on my exhaust. Is there anything i can do to stop this or maybe a trick? Anything will help. Thanks for your time. |
vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Thu Apr 23, 2015 6:06 pm Post subject: |
Are you sure the oil slinger is on the crankshaft properly? The leak would be right at the top of the oil pump. |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Apr 23, 2015 11:27 pm Post subject: |
vwsteve wrote: |
this! _________________ 67 bug x3
67 ghia
64 bug |
cdub65 Samba Member
Posted: Fri Apr 24, 2015 9:34 am Post subject: |
The oil Pump Slinger went in the correct way yes it locked in place |
Posted: Fri Apr 24, 2015 1:48 pm Post subject: |
It isn't part of the oil pump. It is the big tapered washer on the end of the crankshaft. |
cdub65 Samba Member
Posted: Fri Apr 24, 2015 6:38 pm Post subject: |
he motor ran when I got it and I never touched that part its not pouring out but still enough for it to get on my exhaust and burn off and smell so I will check that. so I am guessing if it is on wrong I will have to take the motor apart to fix the issue or............... anything will help and thanks for clarifying that vwsteve |
Posted: Fri Apr 24, 2015 11:34 pm Post subject: |
I assumed the motor was apart since you said it was refreshed. Yes, the case would have to come apart to fix it. Do you by any chance have a bad (or cheap aftermarket) crankshaft pulley?
Oil pumps do leak quite often but not usually at the top. That is why I suspect it is coming out around the crankshaft. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Sat Apr 25, 2015 12:03 am Post subject: |
Sand seal. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
cdub65 Samba Member
Posted: Sat Apr 25, 2015 8:47 am Post subject: |
It is a stock pulley . Should I order up a new pulley and see if that will solve the issue? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Sat Apr 25, 2015 10:53 am Post subject: |
If leaking from pulley, there are a couple of easier things to check first.
Do you have a breather hose from oil filler to carb air cleaner? If so is the hose clear of oil/water mayo like stuff?
Check that both valve cover gaskets have not drooped open at center top.
Pull pulley and clean out the oil return grooves in it. _________________ In Stereo, Where Available! |
