oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Thu Apr 23, 2015 5:02 pm Post subject: Anyone Towing your beetle? |
Suggestions and your experiences wanted...
Has anyone towed one of these..
Using this..
With one of these?
I have a stock beetle and stock hitch on the Bus, just bolts onto the tow eyes and nothing else on the Vanagon but the tongue weight can't be all that much with 4 wheels in tow . What do you think?
Thanks all |
microbus Samba Member
Joined: October 12, 2007 Posts: 527 Location: Alberta, Canada
Posted: Thu Apr 23, 2015 5:09 pm Post subject: |
add safety chains to the tow bar.... _________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Apr 23, 2015 5:20 pm Post subject: |
shouldn't you ask this in the vanagon section seeing that is what you want on opinion on?
I've been towing bugs cross country since the 70's with various vehicles. No problems _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Thor_orr Samba Member
Joined: July 20, 2013 Posts: 85 Location: Day creek, WA
Posted: Thu Apr 23, 2015 5:25 pm Post subject: |
I towed my bug 2800 miles with a tow bar. Seattle WA to Ashville NC no issues. Didn't used a vanagon but think you'd be fine. No backing up and no tight corners! Definitely add safety chains too. I've heard of people having problems with the steering wheel bucking back and forth when taking off but i didn't experience it. I recommend wiring your stock tail lights into a four tab trailer harness pretty easy and then you don't have to fuss with tow lights that scratch your very nice paint. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Apr 23, 2015 5:29 pm Post subject: |
Syncro Vanagon pulling a bug- many times without trouble.
2wd Vanagon, no experience. _________________
EverettB wrote: |
FU#5 |
mukluk Samba Member
Posted: Thu Apr 23, 2015 10:00 pm Post subject: |
I towed my '68 Bug a few times with my old '84 Vanagon back in the day, worked just fine (even towed the Vanagon once with the Bug using a strap, but that's a different story). _________________ 1960 Ragtop w/Semaphores "Inga" |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Fri Apr 24, 2015 3:33 am Post subject: |
Saftey chains and lights are a must. Been towing beetles with a tow bar for ever. Never used a vanagon though.
Just last month, 150 miles.. _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
Kiptere Samba Member
Joined: February 13, 2013 Posts: 419 Location: Houston
Posted: Fri Apr 24, 2015 5:41 am Post subject: |
Make sure the tires are aired up on the bug. _________________ 62 Bug
70 Bug
68 Bug
70 Bug Vert |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Abscate Samba Member
Posted: Fri Apr 24, 2015 1:01 pm Post subject: |
No tongue weight on a tow bar. You don't have the balance issue nor the wagging issue like a two wheel trailer, it just follows the tow vehicle like a puppy dog. _________________ .ssS! |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Fri Apr 24, 2015 1:25 pm Post subject: Re: Anyone Towing your beetle? |
oldhuldy67 wrote: |
Thanks all |
Your tow bar looks like it is new!
I ALWAYS try to avoid backing up!!! _________________ Jesucristo es mi Seņor y Salvador! |
manfang Samba Member
Posted: Fri Apr 24, 2015 5:35 pm Post subject: |
Bugs tow super easy. You'll need to figure out what to do for lights. Some folks splice into the wiring harness for the bug. I opt'd for cheap harbor freight magnetic lights which went on top of the car going to the paint shop. Coming home I zip tied a 2x4 to the rear bumper and mounted the lights there.
No backing up at all with this setup, you'll tweak the bug front end since it will quickly jack knife on you. I'd also recommend leaving the bug in neutral.
Matt |
surfbeetle Samba Member
Posted: Fri Apr 24, 2015 11:40 pm Post subject: |
I have towed my '67 bug for years with a towbar. Don't back up, it will bend the towbar, my father did it and the towbar was never the same. If you must backup, I have done for short distances such as backing up my driveway into the garage by putting the front tires up on wheel dollies. In California, they require a safety chain from the tow vehicle to the tow'd vehicle. Chains to the towbar only don't cut it. Keep the transmission in neutral, you don't want to blow up your engine. _________________ 67 Beetle Build Thread
69 Beetle |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sat Apr 25, 2015 2:05 am Post subject: |
Nice looking bug! Not sure if it has steering wheel lock. If so you need to turn the key and then detach the battery. And put it in neutral, of course. _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Apr 25, 2015 5:44 am Post subject: |
You can back up with a tow bar provided there is a driver steering the tow bar'd car.
Most old VWs can be dinghy tow'd until the tires blow or wheels fall off.
If its good enough to drive, its good enough to tow. Tires, steering, fluids, etc, all need to be up and in good condition.
Be sure no joker has slid in for a free ride to the next town and or pop'd it into gear or pulled the brake up.
No (corrected) Engine in the car.. no problem as long as be sure to zip tie a clutch disc to lock the transaxle input shaft to simulate a stopped engine. If not damage WILL occur.
For lights I like splicing into the original lighting system at the park/tail and L/R turn circuits so the tow'd car also has front maker/turns/stops.. This allows all 4 park lights to operate as parks and left and right turns to operate as combined turns and stops... just like a trailer.
I know dont really need front stop lights.. but it sure is nice and comforting to see the lights on or flash, the car steady while towing at night and the extra side lighting visibility.
If its a one time tow.. slap on lights are just fine.
Never had a Syncro.. but a Beetle pulls so well.. and is virtually along for the ride I wouldnt have a problem with it.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Posted: Sat Apr 25, 2015 11:26 am Post subject: |
VOLKSWAGNUT wrote: |
No ENGINE in the car.. no problem as long as be sure to zip tie a clutch disc to lock the transaxle input shaft to simulate a stopped engine. If not damage WILL occur. |
That's what ya mean, right Ken? _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Sat Apr 25, 2015 11:45 am Post subject: |
57BLITZ wrote: |
That's what ya mean, right Ken? |
Yeah...
Funny had engine spelled wrong.. went back to correct and spelled transaxle.. It was my fist cup of coffee...
Of course towing a CV equipped car (IRS) without a transaxle is possible.. as long as the CV shafts are removed.
Usually and often edited |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Sat Apr 25, 2015 4:47 pm Post subject: |
I realize it's a 67 so it doesn't have a steering wheel lock but if it did don't do like I did 35 years ago. I started out towing with the ignition/steering wheel lock in the locked position but the steering wheel still moved, that is until I came to the first hard right turn and it locked up in the hard right position. When the tow vehicle went to go straight The towed vehicle wanted to continue making a hard right. I bent up that front end pretty good. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Posted: Sat Apr 25, 2015 4:51 pm Post subject: |
Forgot to mention I was towing it with a School bus camper so it took quite awhile to realize the tow vehicle was trying to make right turns while I was blissfully rolling along down the road. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
