MagmaJctAz Samba Member
Joined: November 26, 2011 Posts: 289 Location: Mesa, AZ
Posted: Sun Jun 07, 2015 8:13 am Post subject: |
Are you sure your tester works? How many times have you checked the "good" cylinder?
Did you make sure the spark plug holes are not cross-threaded causing your tester to only be partly threaded?
Regards,
Mike _________________ 1974 Super Beetle. Owned since 1995. Daily Driver. Turned over odometer twice!
1971 Fastback. Check out my Fastback resurrection thread!
http://www.thesamba.com/vw/forum/viewtopic.php?t=627711&highlight= |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jun 07, 2015 11:48 am Post subject: |
Somewhere in whole concept you are continually doing the same thing wrong..... You can not change piston and cylinders and fix (?) head and still have same conditions as before..... Unless you keep repeating same mistake in your processes....
Changing valve lash from .006 to .008 will do nothing to solve your compression problem and only make engine noisier, that alone should be a clue you are continually doing something wrong....
I really have to wonder if you know how to count cylinders and how to put proper cylinder at TDC to test leak down and have doubts about you tester.......
Are you sure you are bringing each cylinder up to TDC compression when you are adjusting valve for that cylinder...
I know it is brutal to hear and I apologies for that... You need help, time to find local VW Guru and enlist his help, because what we are doing here isn't working.... I know its brutal but we are not here and we can only respond to what you are telling us...
HERC Samba Member
Posted: Tue Jun 09, 2015 7:21 am Post subject: |
I was starting to enjoy this. _________________ Herc |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2616 Location: West Coast (Michigan's)
Posted: Tue Jun 09, 2015 11:27 am Post subject: |
This likely isn't going to change his results but I think it's important to tell him that staggering the ring gaps is important. I forget exactly what I was told before but maybe someone else will help me... No gap pointed down, one at 10 o'clock, one at 12 o'clock, other at 2 o'clock?? _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
I Ride Sand Samba Member
Posted: Tue Jun 09, 2015 11:48 am Post subject: |
hmm.... go test your tester on a known good engine. any engine at all. if your daily driver is showing 0 compression, you know where the problem lies. also, if you have the engine together, why not try starting it?
Another option is buying a cheapo dial indicator. this is how i set my valves so there is no question they are closed.
1. set indicator on a valve i *think* is closed and set the dial to zero near the max end of its reading. this way as the valve opens, the dial will start to show the valve opening, hesitating, then start closing.
2. rotate engine until the valve opens fully, then then from the point it is at the max lift turn the crank one full turn. this will make %100 sure the valve is closed, period.
3. set the valve to .006 if using aluminum pushrods, loose zero with steel pushrods.
4. repeat on each and every valve. dont get lazy.
if your valves are set right, you have freshly redone heads, and new pistons, rings, and cylinders it has to have compression. |
HERC Samba Member
Posted: Tue Jun 09, 2015 12:45 pm Post subject: |
DrOnHoliday might be onto something.
In the first post, with warped cylinders, he said It was so close to starting.
Now, with new shit the same thing.
No sputter, no running for 10 seconds ?
Shit, if I went outside right now, drained my oil, crapped down my filler neck and filled it with lemon pledge, I'll still get half way down the fucking street before she even warms up.
There must be another couple of problems somewhere else. _________________ Herc |
Posted: Tue Jun 09, 2015 3:40 pm Post subject: |
Did you by chance split case and have cam out...OR did you put on new degree wheel pulley?
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 707 Location: Louisiana
Posted: Tue Jun 09, 2015 8:16 pm Post subject: |
Am I reading past the part where the new P&C's and the fixed head were installed and the engine wouldn't run still?
I'm not seeing where he tried to start the engine after that.
I agree with DrOnHoliday.
I watched a youtube video of a new exhaust install on a sandrail that exhausted smoke from the oil filler vent tube, and lots of it.
Smoked from the stinger quite a bit as well.
I'd have to try to start the engine with the new pistons and cylinders. _________________ One thing I ask from the Lord, This only do I seek:
That I may dwell in the House of The Lord all the days of my Life, to gaze on the beauty of The Lord and to seek Him in His Temple~Psalms 27:4
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
https://www.thesamba.com/vw/forum/viewtopic.php?t=779597&highlight=
https://youtube.com/@SCOFabwerx?feature=shared |
HERC Samba Member
Posted: Wed Jun 10, 2015 7:41 am Post subject: |
We are also totally bypassing the rebuilt carb and the compufire.
Have fire and fuel been established?
That motor has been cooked ,and probably not on Rotella t.
That cam may be round now with no lift or duration.
gotta split the case. _________________ Herc |
Posted: Wed Jun 10, 2015 8:21 am Post subject: |
HERC wrote: |
gotta split the case. |
splitting the case will not do us any good. you can check for a flat cam without splitting the case. also, the chance of the cam lobes be COMPLETLY gone is nil. it will stop running before it is round and completely gone. a dial indicator on the rocker adjuster can tell boatloads of info without even pulling a head. |
Posted: Wed Jun 10, 2015 11:55 am Post subject: |
ORANGECRUSHer wrote: |
You can't start a thread like this and then just vanish! |
thats usually what happens....... |
HERC Samba Member
Posted: Thu Jun 11, 2015 8:13 am Post subject: |
I dunno.....I'd still split it to see what else the heat destroyed. Shit, I probably wouldn't even use that case. _________________ Herc |
dcj63000 Samba Member
Joined: September 18, 2014 Posts: 28 Location: Columbia MO
Posted: Thu Jun 11, 2015 4:21 pm Post subject: |
Sorry for the delay in response. I really needed to not even think about this project for a bit. Couple of points...I appreciate the very honest criticism because I am NO pro at this.
-I did not try and start the engine after new P/C install. Figured what was the point if no compression. (And I assume(d) that I have done something wrong and don't want to damage anything).
-The rings are staggered.
-I checked the compression with 2 different gauges, with the same results. I can check on a good engine though.
- I believe I am at TDC with aftermarket crank pulley. However I did not install the pulley myself. When I set to what the pulley says #1 TDC the #2 exhaust valve is in rocking position. I guess this is not exact enough eh?
-fire and fuel were established the last time I tried to start engine. |
Posted: Thu Jun 11, 2015 4:30 pm Post subject: |
dcj63000 wrote: |
Sorry for the delay in response. I really needed to not even think about this project for a bit. |
understandable. sometimes its best to walk away for a bit.
dcj63000 wrote: |
-I checked the compression with 2 different gauges, with the same results. I can check on a good engine though. |
Hey, quick thought. how are you kicking this engine over to check for compression? I just realized that if you are trying to do it by hand you will never get a good reading. so just trying to nail down the variables, you are cranking this with the starter, right? |
Posted: Thu Jun 11, 2015 5:38 pm Post subject: |
correct. |
Posted: Thu Jun 11, 2015 5:40 pm Post subject: |
might as well ask. When the rockers are off the heads, the valves should be fully closed corrrect? |
72Pstroke Samba Member
Joined: April 04, 2011 Posts: 182 Location: North Idaho
Posted: Thu Jun 11, 2015 5:45 pm Post subject: |
They will be fully closed with the rockers off, but the rockers need to be on and adjusted to check compression. If the valves won't open to let air in, there is nothing to compress.
Tim |
Posted: Thu Jun 11, 2015 5:54 pm Post subject: |
Thanks. Just double checking. |
Posted: Thu Jun 11, 2015 7:48 pm Post subject: |
You will need rockers for compression test..
You do not need rockers for leak down...
IF it were me, I would start it and run it put at least a hour on it then do compression or leak down text...
