DHale_510 Samba Member
Joined: August 27, 2010 Posts: 378 Location: Nampa Idaho
Posted: Fri Jun 12, 2015 7:27 am Post subject: |
- I believe I am at TDC with aftermarket crank pulley. However I did not install the pulley myself. When I set to what the pulley says #1 TDC the #2 exhaust valve is in rocking position. I guess this is not exact enough eh?
#1 is at TDC ;and full compression] when #3 has the valves both moving [no compression].
Dennis |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Fri Jun 12, 2015 9:23 am Post subject: |
you can also slide a screwdriver down into the spark plug hole, turn the engine over by hand and you'll be able to see exactly when it's at TDC because the driver will quit pushing out.
Make sure you have the actual #1 cylinder as it is common for some engine tins to actually be marked wrong. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
dcj63000 Samba Member
Joined: September 18, 2014 Posts: 28 Location: Columbia MO
Posted: Fri Jun 12, 2015 12:26 pm Post subject: |
Im going to attempt to start this weekend. Ty |
I Ride Sand Samba Member
Posted: Sat Jun 13, 2015 9:47 am Post subject: |
dcj63000 wrote: |
Good luck! i hope it purrs like a box of kittens! |
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 715 Location: Louisiana
Posted: Mon Jun 15, 2015 6:17 am Post subject: |
And let it warm up quite a bit before stopping and starting again.
I ruined a sportbike engine rebuild just because I was trying to tune the carbs while the motor was breaking-in. Too many short heat cycles glazed the cylinders and it would not seat the rings. _________________ Brian H.
HERC Samba Member
Posted: Mon Jun 15, 2015 6:34 am Post subject: |
Hopefully the distributor is not 180 degrees off. _________________ Herc |
Posted: Mon Jun 15, 2015 5:10 pm Post subject: |
We have compression! There were a couple of causes.
1. I wasn't using the adapter on the compression tester. The tester seemed tight in the spark hole but I don't think it was spot on. Got readings when I used the adapter.
2. I went ahead and actually looked at the piston placement to determine TDC when setting the valve clearance. I set the valve clearance to .006 at actual TDC for each cylinder.
3. Discovered I had compression in all cylinders with the valve covers off. When I put the covers on to attempt a start I noticed i had no compression again! THis is why...
The small indents on the first picture are actually where the rocker arms were hitting the valve covers not enabling the valves to close correctly. I was tightening the bolts down too far. I set them to 7 ft lbs and now we have compression. Maybe this will help someone in the future.
The engine is not exactly purring like a kitten but it is firing when you turn the key. It hasn't actually started. Ive been through and through the carb so im guessing it is the timing.
I know the Bosch is set at (roughly) 7.5 - 10 degrees BTDC at idle speed but what to set it at to try and get the engine to start? Does the compufire change this? Thanks all |
Dale M. Samba Member
Posted: Mon Jun 15, 2015 6:52 pm Post subject: |
Put the bolt on valve cover up on shelf... Go back to stamped steel valve covers with spring bails... Alloy covers are pretty but that is about all.... The bolt on covers are going to be a continuing source of grief becasue if not tight enough they will leak and if too tight (but leak stops) they will hit valves valves...
Even with steel cover I had issue of rocker hitting valve cover and had to shave a little bit off of rocker so it did not scrape/hammer on valve cover... This occurs on exhaust valves for #1 and #4 cylinders... The hitting also cause valve cover to move and let oil out...
UMMM by the way where your upper cylinder tins...
dustymojave Samba Member
Posted: Mon Jun 15, 2015 7:00 pm Post subject: |
Ok. Good work finding those issues.
Have you tried static timing the distributor?
- connect a simple 12V light with alligator clips to the same side of the coil as the small wire to the distributor (negative "-" side) and to ground anywhere on the engine.
- remove the distributor cap
- turn the ignition to "on" as it would be if the engine were running, but do NOT crank the starter.
- turn the engine over clockwise looking at the crank pulley.
- the light should light up when the engine is in firing position.
It's possible for it to be firing when the pistons are up and the valves are open if the distributor is out of place. So you need to make sure that when the light is lit, the valves for that cylinder are closed. When # 1 is at TDC and the valves for #1 are closed, the distributor rotor should be pointing at about 4:30 to 5:00 where there SHOULD be a little notch in the top edge of the distributor body. The #1 plug wire should be in the cap at that location. I've seen VW mechanics of LONG experience get them in the wrong order or get the distributor drive shaft oriented wrong. It can happen to the best. _________________ Richard
SoCalBajas Member
Posted: Mon Jun 15, 2015 9:40 pm Post subject: |
The tins are sitting in my shed. Took em off to work on engine lol. I cant afford to shelf those covers right now but thats good to know for later. The wife wasn't not exactly thrilled I bought new P/C's
The way i have set static timing is a little different. Instead of turning the engine until the light turns on I have set the pulley to 10 degrees BTDC (also tried it today at 7.5) then checked the light by turning the distributor clockwise until it turns off, then counter-clockwise until it just turns on. Will this get the same result?
And I did check all the plug locations and rotor location to ensure i was on #1. I will make sure the valves are fully closed and try static time the way you described to make sure its firing when I think it is. |
Aerindel Samba Member
Joined: May 30, 2015 Posts: 459 Location: Western Montana
Posted: Mon Jun 15, 2015 10:10 pm Post subject: |
Quote: |
The way i have set static timing is a little different. Instead of turning the engine until the light turns on I have set the pulley to 10 degrees BTDC (also tried it today at 7.5) then checked the light by turning the distributor clockwise until it turns off, then counter-clockwise until it just turns on. Will this get the same result? |
It should. Its how I got mine started for the first time. Is your accelerator pump working? If the ignition and valves are timed at all correctly you should be able to get it to at least briefly run by just dumping some raw gas down the intake and cranking the engine. It will start out flooded as you crank grow leaner until at some point it hits a combustible ratio at which point it should run for a couple seconds before leaning out and dying (assuming non-functional carb) If you can't get it to even do that then is badly out of time or has a non-functional ignition. _________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046 |
Posted: Tue Jun 16, 2015 3:15 pm Post subject: |
Set pulley at 7.5 ° BTDC (#1 cylinder top of compression stroke)
You want to turn dist. counter clockwise till it goes off them back clockwise to point it just comes on...
This is point where points open and current flow stops in primary winding of coil, at this point the magnetic field in primary winding collapses educing a magnetic field across the secondary winding of coil to produce high voltage arc to fire plug(s)...
Also at this point if you are timing on #1 "TDC" the rotor should be pointing the #1 tower on dist cap...
Posted: Tue Jun 16, 2015 4:34 pm Post subject: |
Accelerator pump is working, I can see it squirt fuel when throttle is hit.
I have been turning distributor clockwise then counter.Just to verify, I have been doing this backwards? I do not have points...
Before the rebuild Kit on the carb I soaked it in Berrymans Carb Cleaner. Has always worked wonders for me in the past. Not to say there isint something wrong with the carb that I do not know about. That is deff possible.
Thanks again all. |
Posted: Tue Jun 16, 2015 4:52 pm Post subject: |
I know this thread has gone past the original topic but I noticed the the degrees on my crank pulley are not spot on TDC compression stroke. When the #1 piston is at real TDC the crank pulley shows 4 degrees BTDC. I know it is not ideal but is it OK to do the ignition timing using the 4 degree mark at my *TDC* or 0 ? |
Posted: Tue Jun 16, 2015 7:34 pm Post subject: |
dcj63000 wrote: |
Thanks again all. |
Timing concept works with electronic modules also....
Posted: Wed Jun 17, 2015 5:06 am Post subject: |
dcj63000 wrote: |
with the Chinese quality of most pulleys this doesn't surprise me. If your absolutely certain and confirmed that you have TDC and it's pointing at 4BTDC then I would take a hack saw blade and score the edge of the pulley there for future reference. Then when money allows pick up a new degree ring for the pulley and put it where it belongs. Or just leave it and use your own mark. Just be certain your not seeing some kind of slack/slop and you have only turned the crank clockwise to find TDC.
BTW static timing is just to get you close to begin with. When you go for max advance you'll be moving it anyway. at least that's how I see it. _________________ Brian H.
Posted: Wed Jun 24, 2015 2:12 pm Post subject: |
Well, its been a week. got it running yet? |
