mchn13 Samba Member
Joined: February 28, 2008 Posts: 240 Location: Columbia, SC
Posted: Fri Apr 24, 2015 1:06 pm Post subject: stock engine deck height/ stock head cc's |
about to pull a freshly rebuilt 1600 i got with a '69 bug i bought, and build a spirited 1600 with it since i have most of the parts. also going to start a stroker with a new case etc.. after i get this '69 rolling.
just wondering since i don't have any gauges yet, what the stock deck height and head cc's are..? planning my target compression and machine work for the heads.
steve _________________ Steve Moore
always over budget on something.always |
Posted: Fri Apr 24, 2015 1:09 pm Post subject: Re: stock engine deck height/ stock head cc's |
They are what they are, you'll know when you measure them. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
g3bill Samba Member
Joined: March 30, 2015 Posts: 247 Location: So. Cal usa
Posted: Fri Apr 24, 2015 1:12 pm Post subject: |
.065 give or take a few, searched for it last night _________________ I have Dial-Up an a hole in my pocket:)......Where are the 3 Stooges when we need them:)
'67 Camper PT westfail w/tent, hammock, jump seat. uping the motor to 1900 w/88bore/78crank.
& will be using carb 34 pict 3 ....Someday?
'82 Toyota 4x4 5sp PU lb, daily driver
Many Corvairs /& 4 rag tops
'63 Chevy 20 Truck w/4sp 292
Want, white plastic end pieces for dash grab handle |
mchn13 Samba Member
Posted: Fri Apr 24, 2015 1:39 pm Post subject: |
g3bill wrote: |
.065 give or take a few, searched for it last night |
thanks man _________________ Steve Moore
g3bill Samba Member
Posted: Fri Apr 24, 2015 4:02 pm Post subject: |
I cant find my Berg tech sheets but; http://www.thesamba.com/vw/forum/viewtopic.php?t=334830&view=previous _________________ I have Dial-Up an a hole in my pocket:)......Where are the 3 Stooges when we need them:)
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Fri Apr 24, 2015 7:33 pm Post subject: |
Are you asking what stock spec was? There were many configurations of the 1600 twin port. I believe there was as low as a 6.9:1 compression ratio for certain models.
If you're going to do a cam swap, it's a waste to return the compression back to whatever worked for the stock cam. Wilder cams require more compression to work properly. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
g3bill Samba Member
Posted: Fri Apr 24, 2015 8:22 pm Post subject: |
bugguy1967 wrote: |
If you're going to do a cam swap, it's a waste to return the compression back to whatever worked for the stock cam. Wilder cams require more compression to work properly. |
Have you read this , esp near bottom. think thats the van he took me for a ride in, WOW what power for a vw van!
http://www.geneberg.com/article.php?ArticleID=155 _________________ I have Dial-Up an a hole in my pocket:)......Where are the 3 Stooges when we need them:)
mchn13 Samba Member
Posted: Fri Apr 24, 2015 10:11 pm Post subject: |
bugguy1967 wrote: |
Yeah just wondering what stock cc's were or compression. Going to build a mouse motor till i get a stroker built:. I have two fresh-ish 1600's, and want
To buid one for the summer til i can get my stroker built on the standard case..
Going to build a bastard 1600 loosely based on specs ive seen here:
1600cc
Pp stock heads/single hd springs
163 web cAm
9.5:1 comp
8 dowelled crank/flywheel
1 3/8 merged _________________ Steve Moore
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Fri Apr 24, 2015 10:25 pm Post subject: |
Yep, about .060 deck and the head CC was, ah, 52?? I think, for 311 heads, 7.5-1
Stepped (smog) heads dropped it to 7.1-1
the step is .060 deep and the remainder is about 47cc
They had a bit more deck with the paper gaskets under the cylinders, but replacement pistons are usually a bit shorter as a general rule, which evens that out.
Rod length was not closely controlled either, so the deck can be .050-.070 depending on what combo of parts.
As for what stock years came with what heads that had this or that cc and what models had dished pistons well sorry I can't remember all that. |
GTV Samba Member
Posted: Sat Apr 25, 2015 7:51 am Post subject: |
My original engine from my '72 beetle had steps in the chambers and dished pistons. I never measured it, but the compression must have been stupid low... I had Tims rework the original heads, bore it for 88's, cut out the steps, .048" ish deck and I was at 8.6:1. _________________ EMPI Power Rules! |
Posted: Sat Apr 25, 2015 11:22 am Post subject: |
the issue is the people have been swapping parts for over 40 years. It's not a common situation for the car to have what it did when it rolled off the lot. That's why I said it has what it has, you have to check it. _________________ It's just advice, do whatever you want with it!
mchn13 Samba Member
Posted: Sat Apr 25, 2015 4:14 pm Post subject: |
[email protected] wrote: |
the issue is the people have been swapping parts for over 40 years. It's not a common situation for the car to have what it did when it rolled off the lot. That's why I said it has what it has, you have to check it. |
True. I am going to check them as soon as i tear into it. Thanks _________________ Steve Moore
