tunnvar Samba Member
Joined: October 24, 2011 Posts: 261 Location: Austin, Texas
Posted: Sat Apr 25, 2015 7:14 am Post subject: Wiring Novice - New Turn Signal Housing |
Can anybody shed some light on this? My old turn signal housing has 2 wire connections plus a ground. My new ones has 1 wire connection and a ground. Did I get the wrong housing? If not, which wire do I connect?
Cheers. _________________ 1970, Deluxe, 1600cc, Type 1 Dual Port
[url=http://www.vw-mplate.com/mplate2-35638.png]Click to view image[/URL] |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Sat Apr 25, 2015 8:14 am Post subject: |
Did you get these from CIP? I ended up getting the same ones and are wired for 1156 bulbs, where the originals were 1157 (Two Wires)....Pretty stupid.
I simply switched the old pots..Had to JB weld one of them on as the plastic tabs were broken off..
I should also suggest you closely inspect the slots for the bulbs for burrs..I chased around bad grounds and burnt a few relays before I took my lenses off and housings to discover a nasty little piece that was touching the mount!
Good Luck _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
fes Samba Member
Posted: Sat Apr 25, 2015 10:40 am Post subject: |
tunnvar wrote: |
Thanks Fes. Yes I got them from CIP. Are there others you can buy that have two wires going in for the correct bulbs? If not, I'll do what you did. |
I'm not sure, CIP just sells them as " '68 thru "72"..I found the pots that came on these kind of cheesy anyway..what year is your bus? _________________ '68 Campmobile-Pedro
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51060 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 25, 2015 10:42 am Post subject: |
You shopped by price and didn't read the full description eh?
Those Euro ones can be modified as already mentioned, careful which way you put the bulb in though or you'll get a bright parking light and a dim signal.
Or send them back and spend the extra $10 a side for the correct parts. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
fes Samba Member
Posted: Sat Apr 25, 2015 10:47 am Post subject: |
busdaddy wrote: |
Or send them back and spend the extra $10 a side for the correct parts. |
It's funny you mention that, because I'm almost certain the duals were not available when I bought mine 4 or 5 years ago.. also no description either..I could be wrong tho..I rarely shop by $$ alone..I just had a "WTF" moment when i went to install _________________ '68 Campmobile-Pedro
Posted: Sat Apr 25, 2015 10:51 am Post subject: |
I just looked at thier site, left and right "uses single filament bulb" or ambidextrous "uses dual filament bulb" listed, more $ for the dual one, both say mediochre reproduction (3 stars). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
fes Samba Member
Posted: Sat Apr 25, 2015 10:59 am Post subject: |
I just looked too.. sure enough they are there,Maybe a newer addition since i bought mine or I just missed it then..send 'em back and get the right ones or modify yer new ones to save the shipping costs..your choice,either way you're not screwed _________________ '68 Campmobile-Pedro
Posted: Sat Apr 25, 2015 11:03 am Post subject: |
fes wrote: |
.I just had a "WTF" moment when i went to install |
Not the first time that's happened when shopping there _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
