Chevy432 Samba Member
Posted: Sat Apr 25, 2015 3:53 pm Post subject: 1980 VW Rabbit Services |
So here's an interesting bunch of questions, but to start off I'm not exactly looking restore my car but I want to fix up as much as I can do so it has less chance of dieing on me could you guys give me a big list of everything that either goes wrong in an older car and or what I should be looking at checking/fixing. I have no experience with cars but I'm hoping repairing my car will enlighten me 👍 thanks! |
bvolks Samba Member
Joined: April 26, 2004 Posts: 845 Location: New Brunswick, Canada
Posted: Sun Apr 26, 2015 5:43 am Post subject: |
The biggest issue I had with my 1980 Rabbit was water leaking around the windshield onto the fuse box causing constant electrical problems. _________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Mon Apr 27, 2015 11:20 am Post subject: |
Diesel or Gasoline ? ? Rabbit. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Posted: Tue Apr 28, 2015 12:56 pm Post subject: |
Old n' slow wrote: |
Diesel or Gasoline ? ? Rabbit. |
It's a 1.6 gasoline 👍 |
Posted: Tue Apr 28, 2015 1:07 pm Post subject: |
I thought maybe it was Diesel, then I could give you something's to consider. Since its gasoline there isn't much I could tell you, just like any car keep it serviced regularly and watch for salt caused rust if it isn't already rusted. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Sat May 02, 2015 4:33 pm Post subject: |
bvolks wrote: |
The biggest issue I had with my 1980 Rabbit was water leaking around the windshield onto the fuse box causing constant electrical problems. |
The other issue with the Fuse box was very underrated design, so even without leaks they still went bad.
The 1.6 motor with FI is/was a good motor, oil temp was hot, and later 1.8 motors got oil coolers.
As long as you change the oil and keep up on service they are good cars.
Now, 35 years later, all the ones with electrical demons have been crushed. _________________ Good Luck
Al |
