Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sun Apr 26, 2015 6:55 pm Post subject: My weekend warrior 1970 baja bug build |
Hello everyone, I recently acquired a two owner (original owner & son-in-law) 1970 beetle that I purchased for a friend who fell through on the deal. After threatening to cut it up if he didn't liberate from me, I had to follow through when he didn't pick it up in a timely manner. |
Posted: Sun Apr 26, 2015 7:00 pm Post subject: My weekend warrior 1970 baja |
Here are a few pics of what I started with.
Posted: Sun Apr 26, 2015 7:14 pm Post subject: |
My beetle turned 45 this month.
Posted: Sun Apr 26, 2015 7:20 pm Post subject: |
I originally wanted to go the class 11 route.
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Sun Apr 26, 2015 9:02 pm Post subject: |
That is a clean car. Keep It stock. If it was beat up I would say sure, hack it into a baja, but I like it as an 11 car. Just sayin. _________________ HBB took me to BBV. |
Brian Samba Moderator
EnjoyNukaCola Samba Member
Joined: January 27, 2014 Posts: 491 Location: Santa Clarita
Posted: Sun Apr 26, 2015 9:39 pm Post subject: |
+1 _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Mon Apr 27, 2015 4:13 am Post subject: |
But that didn't feel like living up to the threat of cutting it up.
Posted: Mon Apr 27, 2015 4:32 am Post subject: |
Thanks for all the input, while it shows really well in the pictures, it was a good enough paint job to preserve what was left. It had been sitting for 4 years in that spot & has been off the road since 04. It'll need the usual floor pans & the headlight buckets were rusted out as is the rear parcel tray floor.
Posted: Mon Apr 27, 2015 4:36 am Post subject: |
That seems a bit more committed. |
Posted: Mon Apr 27, 2015 9:14 am Post subject: |
Here it is with new sneakers.
Posted: Mon Apr 27, 2015 9:29 am Post subject: |
To gain more clearance between the fenders & tires I first started at the rear by re-clocking the torsion bars & to increase the downward motion of the rear suspension I notched the spring plates.
Posted: Mon Apr 27, 2015 9:46 am Post subject: |
Here's a comparison of before & after from one side to the other.
Posted: Mon Apr 27, 2015 9:51 am Post subject: |
With its new exhaust also. I decided to keep it simple at first & keep the original engine so I rebuilt the carb, installed a pertronix breakerless ignition & a quick tune-up. |
Posted: Mon Apr 27, 2015 11:28 am Post subject: |
Not the prettiest of welds but I flanged the header to the heat exchangers.
Posted: Mon Apr 27, 2015 11:43 am Post subject: |
Most of these modifications are ideas I've gotten from lurking around the HBB forums & I'm trying to employ as many as I can to keep this build as inexpensive as possible but still end up with a fun car. I hope some of the new to the scene crowd can see this & realize that it can be done without spending the big bucks that have gone into most of these newer builds. |
Posted: Mon Apr 27, 2015 11:52 am Post subject: |
[img]https://www.thesamba.com/vw/gallery/pix/1343048.jpg[/
Here's the 100mm axle upgrade, I sourced a set of used axles & stubs from a Porsche 924 off Craigslist for $100. |
Posted: Mon Apr 27, 2015 11:55 am Post subject: |
And a set of conversion flanges I ordered for $90 shipped. |
Posted: Mon Apr 27, 2015 12:12 pm Post subject: |
After some research I found some bilsteins that were about 1-1/2 longer & had about 1/2" longer travel from a chrysler town&country that had the same bolt diameter (also good to use on those VW rabbit truck rears. |
Posted: Mon Apr 27, 2015 1:17 pm Post subject: |
Not overly impressed with the tire clearance on the rear. |
