Joined: August 31, 2013 Posts: 12815 Location: North Carolina
Posted: Tue Jun 09, 2015 7:13 am Post subject: |
The new balljoints were not equipped with zero fittings so I drilled & tapped the ball joints
HERC Samba Member
Posted: Tue Jun 09, 2015 7:17 am Post subject: |
That's how you do it baby bubba. Brand new _________________ Herc |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2616 Location: West Coast (Michigan's)
Posted: Tue Jun 09, 2015 6:52 pm Post subject: |
ZERK fitting, damn autocorrect.
Then I removed the Zerk fitting from the original balljoint & installed it into the new one. |
Posted: Tue Jun 09, 2015 6:55 pm Post subject: |
@ Herc & ORANGE CRUSHer, thanks guys. |
Posted: Thu Jun 11, 2015 2:46 pm Post subject: |
I finally got the upper arms with new ball joints installed
Now on the lowers. |
Posted: Sat Jun 13, 2015 8:32 am Post subject: |
I finally removed the other beam clamp to relocate it, this is Arguably the worst part of this whole endeavor. |
Posted: Tue Jun 16, 2015 7:44 pm Post subject: |
The Thing lower arms were really rusty, the lower shock bushing had seized to stud & removing the balljoint tested the capacity of my press. Unlike the uppers (that came off the bug) & pressed out smoothly, the lower requires lots of pressure & when it finally yielded, the balljoint shot out of the arm with a bang & every thing flew everywhere. I had to use a torch & air chisel to remove the shock bushing. |
Posted: Wed Jun 17, 2015 7:40 am Post subject: |
Hey OC, I use my bearing separator to support the trailing arm in the press.
Posted: Wed Jun 17, 2015 7:42 am Post subject: |
This allows me to press against the nubs on the trailing arm without them pushing the plates apart. |
Posted: Sun Jun 21, 2015 2:44 am Post subject: |
Now on to the lower spring pack, as I remove the pack I use zip ties to keep it together. |
Posted: Tue Jun 23, 2015 5:47 am Post subject: |
Here is the spring pack with zip ties at both ends & on both sides of the securing dimple where I intend to cut |
Posted: Tue Jun 23, 2015 5:50 am Post subject: |
After tapping the spring pack on the floor a few times on both ends to square up the ends, I cut the pack in half. |
HERC Samba Member
Posted: Tue Jun 23, 2015 6:48 am Post subject: |
Cool. The difficult part is the placement of the new dimples. Once they're dimpled, they're dimpled and the crucial part is tightening them up and having the camber be where you want it.
I had some aftermarket leaves once and the dimples were off. When you'd cinch down on the grub screw, it actually pulled the arm out a bit. Hate when that shit happens. _________________ Herc |
Posted: Tue Jun 23, 2015 4:10 pm Post subject: |
TDCTDI wrote: |
And after installing the spring into the trailing arm & inserting them into the beam, I use a guide to drill a locating dimple into the spring pack. |
Hey Herc, that was definitely a concern of mine, that's why I drilled a locating dimple in the beam while the trailing arm was installed & correctly located. I tried to include all the steps, but I've missed a few. |
dustymojave Samba Member
Posted: Tue Jun 23, 2015 4:12 pm Post subject: |
One can actually adjust the dimples in leaves by carefully disassembling the stack, keep the pieces in order, and hand file the edges of the notch in each leaf. It requires a sense of which leaf needs how much removed from which side of the notch. Drilling the stack as one piece is best done with a carefully setup jig to hold the stack tight and carefully centered. To do it right, the jig should measure from the outer dimple at the end of the stack to the inner dimple location to keep them consistent. Alignment should NEVER be done unless the grub screws on all the torsion leaves are tight. _________________ Richard
SoCalBajas Member
Posted: Wed Jun 24, 2015 1:19 pm Post subject: |
Now the spring pack is two, while I don't have a jig to clamp everything down, I install the spring pack into the appropriate trailing arm, tighten the grub screw, then install the unit into the beam, make sure that the arm to beam is the same distance & use a guide in the adjuster to drill a locating hole in the spring pack. From there I remove the trailing arm & spring pack (leaving the arm attached to the spring so that the grub screw ensures that the clamped portion can't shift & then use a pair of vice grips to keep the leaves from spreading while I use the countersink bit in the locating hole to make the dimple. |
Posted: Thu Jun 25, 2015 7:44 pm Post subject: |
TDCTDI wrote: |
So there you have your jig... _________________ Richard
SoCalBajas Member
HERC Samba Member
Posted: Fri Jun 26, 2015 8:26 am Post subject: |
Cool beans _________________ Herc |
