My weekend warrior 1970 baja bug build
Page: Previous  1, 2, 3 ... 8, 9, 10 ... 12, 13, 14  Next
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Tue Jul 28, 2015 3:42 pm    Post subject: Reply with quote
And I purtied it up too.
VWCOOL
VWCOOL is offline
PostPosted: Tue Jul 28, 2015 4:33 pm    Post subject: Reply with quote
Great build thread! Inspiring me to get my Baja project underway!
TDCTDI
TDCTDI is offline
PostPosted: Tue Jul 28, 2015 7:10 pm    Post subject: Reply with quote
Thank you sir, I was hoping I could help someone by showing a step by step process. Even better is that everyone gives their input & experience to help out.
TDCTDI
TDCTDI is offline
PostPosted: Sat Aug 01, 2015 10:19 am    Post subject: Reply with quote
I fabbed & welded the gusset on the other spindle.
Here's what it looks like after welding with flux core wire before cleaning all the spatter & residue.
TDCTDI
TDCTDI is offline
PostPosted: Mon Aug 03, 2015 5:35 am    Post subject: Reply with quote
Now its shiny too.
HERC
HERC is offline
PostPosted: Mon Aug 03, 2015 6:26 am    Post subject: Reply with quote
Looks goot Cool
Herc
TDCTDI
TDCTDI is offline
PostPosted: Fri Aug 07, 2015 6:10 am    Post subject: Reply with quote
Hahaha, my views count just said boob.
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 20, 2015 5:08 pm    Post subject: Reply with quote
Well, I finally found a few seconds to rub together and assembled the passenger side.
Then I get to disassemble the drivers side & paint the trailing arms.
dustymojave
dustymojave is offline
PostPosted: Thu Aug 20, 2015 5:21 pm    Post subject: Reply with quote
Goin' commando with the beam?
Richard
SoCalBajas Member
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 20, 2015 6:44 pm    Post subject: Reply with quote
Hey Richard, no, I'll paint it too, I still need to relocate the steering box stops & limiters & the damper mount. As much as I'd like to go rack & pinion, I think I'll keep it simple for now so I can enjoy driving it as opposed to having another project that never gets completed.
TDCTDI
TDCTDI is offline
PostPosted: Mon Aug 24, 2015 5:38 pm    Post subject: Reply with quote
I made some more time & started shifting the other components on the beam.
I started by removing the steering box clamp locating tab.
And then welded it back to the beam 2" back towards the center.
dustymojave
PostPosted: Mon Aug 24, 2015 9:59 pm    Post subject: Reply with quote
You DO understand that will require new custom tie rods...Don't you? What are your plans for that?
Richard
SoCalBajas Member
TDCTDI
TDCTDI is offline
PostPosted: Tue Aug 25, 2015 11:37 am    Post subject: Reply with quote
Hey Richard, fully aware of having to lengthen them also. as per your suggestion either here or elsewhere, I kept the swaybars from both beams & the tie rods from both also. I plan to cut all four tierods to achieve the correct length & stuff the swaybar inside the tierods & weld it all together. Or perhaps grab a set of tierods off a domestic truck (so I can use the larger tierod ends) & cut them down & just rethread the right hand threaded one. Let me know which you'd suggest, thanks.
TDCTDI
TDCTDI is offline
PostPosted: Wed Aug 26, 2015 5:52 pm    Post subject: Reply with quote
Made some more progress.
I ground the old welds off the steering damper bracket, then coerced them off with a chisel & a BFH.
Then I welded it back on 2" closer to the center.
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 27, 2015 4:39 pm    Post subject: Reply with quote
Well guys, there it is, all the fabrication on beam is completed, now I just need to clean it up, paint it & install it. This is effectively a 6" wider ball joint beam, the thing spindles add 1" per side & I added 2" per side with adding the adjusters.
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 27, 2015 4:57 pm    Post subject: Reply with quote
Here it is with a stock width beam.
dustymojave
PostPosted: Thu Aug 27, 2015 11:39 pm    Post subject: Reply with quote
If you're prepared to ream the spindle steering arms out for larger tie rod ends, go for Ford F100/F150. Thees days, the aftermarket rack and pinion makers are boring theirs for International rod ends. International parts are getting hard to come by. But there is a new one which has the same stud size as International, but the same tie rod thread size as Ford. I recommend just going with the Ford rod ends. You could take a whole tie rod from a wrecking yard and cut it in half to make both outer ends.
Richard
SoCalBajas Member
TDCTDI
TDCTDI is offline
PostPosted: Sat Aug 29, 2015 8:21 am    Post subject: Reply with quote
Well, I painted it this morning, I can't wait to start assembling it. I am going to lengthen the existing tie rods for now (since I have them) & will eventually upgrade to ford ones.
dustymojave
PostPosted: Tue Sep 01, 2015 4:59 pm    Post subject: Reply with quote
Lengthening the stock tie rods makes sense.
So did you move the pitman arm stops?
Richard
SoCalBajas Member
TDCTDI
TDCTDI is offline
PostPosted: Tue Sep 01, 2015 7:07 pm    Post subject: Reply with quote
Yes sir. It was a PITA, my 90* die grinder wouldn't fit between the tubes so i couldn't cut all of the welds with that so I finessed the rest with the sawzall. I just didn't point it out but it guess I should have so others would know to do so if they were silly enough to follow my lead.
Page 9 of 14
