Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Tue Sep 01, 2015 7:17 pm Post subject: |
Also, the outer steering box clamp stop is not welded to the beam like the inner one that I relocated, it appears to be a rivet. To keep from weakening the beam by trying to extract it & relocate it, I bolted the clamp to the steering box where it needed to be located & then welded the clamp to the beam, I hope that doesn't bite me in the ass. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Sep 01, 2015 7:26 pm Post subject: |
Before I painted the beam, I used some brake bleeder dust covers to keep from clogging the Zerk fittings on the beam, they fit so well I think I'll leave them. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Sep 04, 2015 6:38 am Post subject: |
Well, in preparing to lengthen the tie rods, I came across an interesting tidbit that I wasn't aware of.
The Thing tie rod (on the right) is already a little beefier from the factory.
So is the sway bar, I do not know yet if I'll be able to stuff it down the tie rod. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Sep 04, 2015 4:36 pm Post subject: |
As it turns out, a VW engineer decided that Thing the passenger side tierod needed to be large enough to accommodate the larger sway bar
Posted: Sat Sep 05, 2015 6:22 pm Post subject: |
I drilled a hole into the tierod so i could rosette weld the sway bar into the tierod _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Sep 05, 2015 6:32 pm Post subject: |
Then I threaded the tierod end all the way in to ensure maximum adjustment & secured the swaybar & filling in the hole.
Posted: Mon Sep 07, 2015 8:29 pm Post subject: |
Well I Thought I uploaded a pic of my progress but it failed to & I already deleted the pic. I couldn't find a another Thing tierod to use as a donor so I ended up getting a piece of 1/2" pipe to use as a filler, I left roughly 3/16" between the pieces so I could weld directly to the swaybar insert & fill the gap by swirling the weld into the tierod pieces, here's the completed part.
Posted: Wed Sep 09, 2015 5:45 am Post subject: |
Here it is after a quick coat. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Sep 09, 2015 7:20 pm Post subject: |
The drivers side tierod was the same diameter from bug to Thing, this meant I could cut both at different points to get the length with only one seam.
The tierod was 9" long, so I split that in half & added one inch to the right on one tierod, then to the left of center on the other tierod.
That left me with a two inch longer tierod & a two inch shorter tierod (great because my buddy is narrowing his beam 4").
(Just be careful not to mix up which end is which, one end has a left hand thread & the other is a right hand thread) _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
dustymojave Samba Member
Posted: Wed Sep 09, 2015 8:35 pm Post subject: |
I recommend against using water pipe for tie rods and I hope you're planning to reinforce those joints where you combined the 2 tie rods together. _________________ Richard
SoCalBajas Member
Posted: Thu Sep 10, 2015 11:36 am Post subject: |
Hey Richard, I know, I really didn't want to use black pipe but I couldn't find anything else to fill the 1-3/8" gap. The Thing sway bar was too big to fit in the beetle tierod & I wanted to use the larger bar & couldn't bring myself to make a hybrid of the two.
Here's a pic of the difference in swaybar diameter.
Is the swaybar insert not adequate enough for integrity? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Sep 10, 2015 3:58 pm Post subject: |
After cutting the tierods to length, I then drilled a hole into each half. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
HERC Samba Member
Posted: Fri Sep 11, 2015 7:30 am Post subject: |
I cant wait to this car finished. Hurry up. _________________ Herc |
Posted: Fri Sep 11, 2015 4:17 pm Post subject: |
Thanks HERC, I try to do something to it every day, eating that elephant one bite at a time.
Here's the piece of the swaybar that's going to be part of this tierod. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Sep 14, 2015 8:08 pm Post subject: |
I then assemble the tierod & rosette weld the swaybar to the tierod
Then weld the two halves to the swaybar insert. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Sep 14, 2015 8:13 pm Post subject: |
& clean it up in the sand blaster _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Sep 17, 2015 8:49 am Post subject: |
Now I've removed what's left of the original front beam. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Sep 21, 2015 3:05 pm Post subject: |
And here's the widened beam going back in. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
HERC Samba Member
Posted: Tue Sep 22, 2015 7:23 am Post subject: |
Lookin good bro. _________________ Herc |
Posted: Tue Sep 22, 2015 4:30 pm Post subject: |
Thanks HERC, glad to see I'm not boring the hell out of everyone, I just wanted to show a step by step of how I did it & hope it may inspire others to build their cars (or how not to). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
