Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri May 08, 2015 6:12 am Post subject: |
That notch helps the C-clamp to not slip around as much on the angle iron. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Fri May 08, 2015 6:16 am Post subject: |
The torsion tubes are now forced into the angle iron and make the tubes as straight as possible. |
Posted: Fri May 08, 2015 6:23 am Post subject: |
ORANGECRUSHer wrote: |
just curious, have you had any prolblems with the threads on those adjusters yet? |
Not yet, I place a wet rag over them to keep welding slag/spatter from fouling them. Are they known to be an issue? |
Posted: Fri May 08, 2015 6:28 am Post subject: |
Be sure to avoid anything that may cause the angle iron not to mate directly to the tube. Such as the steering box clamp position tabs. |
Posted: Fri May 08, 2015 10:39 am Post subject: |
I just had some cross-threading problems when I did mine a couple months ago which is why I replaced the old set. I think it was a combination of crap chinese meturgy and trying to fit everything together under tension which could not be avoided. I'd just keep doin what your doin and if you take the screws out again keep the threads lubed.
good work looks good _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Fri May 08, 2015 1:23 pm Post subject: |
good work looks good |
Thanks for the heads up on the fasteners, I was thinking I would trim them down a bit but if they're subpar then I might source some grade 8 bolts, that would probably be easier than trying to adjust with an Allen key anyway. |
Posted: Fri May 08, 2015 4:30 pm Post subject: |
After welding the two halves back together, I started the hateful task of removing the beam clamp. |
Posted: Fri May 08, 2015 6:46 pm Post subject: |
Here's the clamp repositioned. |
Posted: Sat May 09, 2015 1:34 pm Post subject: |
Not being totally satisfied with the capabilities of my welder (or perhaps with my abilities) I transported the assembly over to my buddies at Henry's Muffler Shop & let the guys that weld hundreds of times a day to weld it all back together. You can do all the cutting at home, line everything back up & have a professional do the final welding. |
Posted: Mon May 11, 2015 6:10 am Post subject: |
Now that it's all back together, I loosened the center securing grub screw & slide the upper spring pack out. |
Posted: Mon May 11, 2015 7:39 am Post subject: |
Here's the spring pack after cutting, I like to use zip ties to bind the leaves together to keep them together. |
Posted: Mon May 11, 2015 7:45 am Post subject: |
To make it easier to get the spring pack to slide into the adjuster, I like to taper the end of the spring pack. |
Posted: Mon May 11, 2015 8:01 pm Post subject: |
Then I install a new seal. |
Posted: Mon May 11, 2015 8:08 pm Post subject: |
And after installing the spring into the trailing arm & inserting them into the beam, I use a guide to drill a locating dimple into the spring pack. |
Posted: Tue May 12, 2015 6:10 am Post subject: |
After making the dimple in the spring pack larger on the drill press, i slathered the spring pack with grease again to protect it from rust (it's worked great for the last 45 years) & re-install the assembly into the beam. |
dustymojave Samba Member
Posted: Thu May 14, 2015 5:53 pm Post subject: |
I like to wrap the spring pack with a zip-tie to hold it together while sliding it in. It will slide along the pack when it hits the adjuster or stock center anchor block. _________________ Richard
SoCalBajas Member
Posted: Thu May 14, 2015 7:17 pm Post subject: |
Thanks Dusty, I guess we think alike, the zip tie I used is barely visible through the grease just above the opening in the lower tube. Thanks for pointing that out, I guess since I'm doing a step by step I should be a little more attentive. Any & all pointers are greatly appreciated. |
Posted: Thu May 14, 2015 7:31 pm Post subject: |
Hey Dusty/Richard (let me know if you prefer Richard instead), my plan is to use two steering boxes with the one on the right serving as an idler arm & flipping the pitman arm on it to mirror the drivers side with a drag link in between. I'm going to use ford tie rods & ends. This will require enlarging the tapered seats on all the holes (thus correcting the tapered seats that will now be pointing downwards on the inverted passenger arm). What's your take on this as I'm sure I'm not the only one to have done this? |
Posted: Sat May 16, 2015 4:29 pm Post subject: |
Before sliding the spring pack in I clamped it together & dimpled it on the drill press. |
