Gmiee5 Samba Member
Joined: December 06, 2008 Posts: 388 Location: Portland Oregon
Posted: Wed Apr 29, 2015 9:45 pm Post subject: 1961 80's resto |
I picked up a 61 bug about 2 years ago. It has been sitting in line behind several other vw's my son has decided he wants to role it this summer.
this is before:
this is how I found it:
there was lots of parts missing. the floors need replaced.
front end needs replaced. needs new wiring harness. and so on ..
_________________ _______________________
Gmiee5 Samba Member
Posted: Wed Apr 29, 2015 9:56 pm Post subject: |
First step is to remove body from pan.
we removed the pans
and reinstall new ones:
first we removed the back support piece off of the new pans
Gmiee5 Samba Member
Posted: Wed Apr 29, 2015 10:11 pm Post subject: |
It's time to remove the front nose
_________________ _______________________ |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Thu Apr 30, 2015 4:35 am Post subject: |
So are you going to do it up the same as in the old picture? |
carcrazed Samba Member
Posted: Thu Apr 30, 2015 8:52 am Post subject: |
Wow..does that first picture throw me back to high school years!! Yea...keep us updated. I would love to know how you plan to paint it? _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Thu Apr 30, 2015 10:12 am Post subject: |
Gmiee5 wrote: |
So . . . once upon a time, somebody put it on a frame rack and ripped that poor bug. You'd think that maybe they could have welded it back together before sending it on it's way!
Glad to see it in good hands now . . . all the best with your project! _________________ Jesucristo es mi Seņor y Salvador! |
Gmiee5 Samba Member
Posted: Thu Apr 30, 2015 10:27 am Post subject: |
My son used a nose I have been saving for this project. for a template
pile is getting bigger
We have put the body back on the pan and will be using a set of finders for the mock up _________________ _______________________ |
Gmiee5 Samba Member
Posted: Fri May 01, 2015 9:33 am Post subject: |
57BLITZ wrote: |
Gmiee5 wrote: |
Glad to see it in good hands now . . . all the best with your project! |
I was struggling with why there was rips on both sides like that. that makes perfect since . _________________ _______________________ |
Rome Samba Member
Joined: June 02, 2004 Posts: 9602 Location: Pearl River, NY
Posted: Sat May 02, 2015 4:37 pm Post subject: |
Ambitious! Great that you found it and are reviving it. Is the black cat yours, or the PO's?
The front fenders actually appear decent apart from the surface rust. Do you just want to find better OG ones which have the blinker openings still there?
This might be a bit premature, but have you thought about what wheels and bolt patterns? 4-bolts all around, or 5-bolts? |
Gmiee5 Samba Member
Posted: Sun May 03, 2015 10:24 am Post subject: |
We are keeping the same paint buff it it out,repair the rust and damage paint
the new nose and inside the front area.
It will be my son's summer car
as for rims I'm going back to wide 5 not sure what..
Gmiee5 Samba Member
Posted: Sun May 03, 2015 10:30 am Post subject: |
the nose we just fitted is way to damaged on the passenger side. I have a better nose that we will fit this week.
Also to save time we are talking about using a different pan this summer that my son has done for a 59 project he has been working on .
Gmiee5 Samba Member
Posted: Sun May 03, 2015 11:08 pm Post subject: |
nose number 2.. much better
Gmiee5 Samba Member
Posted: Mon May 04, 2015 8:11 pm Post subject: |
nose is on .. drivers side is done, passenger side needs more welding and 4 holes used for a gas heater .
bluebus86 Banned
Posted: Mon May 04, 2015 9:56 pm Post subject: |
Gmiee5 wrote: |
I specially like the easy fill brake reservoir on the replacement clip, no fussy cap to deal with!!!!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Gmiee5 Samba Member
Posted: Mon May 04, 2015 11:33 pm Post subject: |
that's a very hard to find feature _________________ _______________________ |
Gmiee5 Samba Member
Posted: Mon May 11, 2015 8:30 pm Post subject: |
after patching 4 big holes for a gas heater and welding up tons of rips
done with the welding
Gmiee5 Samba Member
Posted: Tue May 12, 2015 10:30 am Post subject: |
I buffed out half of the hood. I should look good .
I need to match the white for the finders and the nose.
I was told it is corvette white this is 88 corvette white and corvette classic white. I am planning on taking the car to the paint store to match the color
Gmiee5 Samba Member
Posted: Sun May 31, 2015 8:01 pm Post subject: |
Finished up the wheel wells and undercoated them .
Gmiee5 Samba Member
Posted: Sun May 31, 2015 8:03 pm Post subject: |
started buffing out the bod
Gmiee5 Samba Member
Posted: Sun May 31, 2015 8:08 pm Post subject: |
color matched the white.
replaced the wiring harness. the turn signal switch.
installed the pedals a different gas tank . installed the interior.
fired up the engine and adjusted the brakes and clutch.
