Marya Samba Member
Joined: August 31, 2004 Posts: 353 Location: Portland, OR
Posted: Sat May 02, 2015 12:48 am Post subject: Please see this damage and advise |
Hello,
I'd like to know if this damage should be or even can be cut out and patched somehow (haven't noticed sheet metal in this area) e.g. welded, or if I should just buy a new old same-year sliding door? I'm having a guy do some welding for the rear corners / battery tray area anyway but would just like to get a sense of what I should do about this area. As you can see if you look closely, there's some daylight coming in!
On the outside it's less obvious...there's some rust just under the window that you can see but it's way worse looking on the inside.
Thank you!
_________________ 1970, Riviera, 1600 cc type I [single port] |
Danpa Samba Member
Joined: August 21, 2007 Posts: 1240 Location: Valparaiso, in
Posted: Sat May 02, 2015 5:12 am Post subject: |
If I were you, I'd get a new door. This could be a rust free area, with wrinkle free OG metal, perfectly straight, no filler, in the time it would take to remove and replace the door.
Now, if it were for a hard to find part for say, a barndoor, that would be different. It looks like you have a baywindow, though. Should be easy enough to find a good one.
Dan |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sat May 02, 2015 6:10 am Post subject: |
If bus parts are available at a reasonable price and you did not weld/fabricate it yourself ,replacing is the better option if you can find a door that is in good condition.
If you have to hunt all over and pay a classic car price then have it patched up. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Marya Samba Member
Posted: Tue May 05, 2015 7:10 pm Post subject: |
Thank you both - very much. This is exactly what I was hoping you'd say. _________________ 1970, Riviera, 1600 cc type I [single port] |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Wed May 06, 2015 12:12 pm Post subject: |
http://www.averysaircooled.com/ might have the door & is pretty close to Portland. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Marya Samba Member
Posted: Wed May 13, 2015 8:28 pm Post subject: |
Thank you! I sent an email. _________________ 1970, Riviera, 1600 cc type I [single port] |
