greenboat4 Samba Member
Joined: April 04, 2014 Posts: 81 Location: Fort Myers
Posted: Sat May 02, 2015 1:22 pm Post subject: Rear Shocks cutting into CV boots help please |
I purchased a 1967 bus, lowered, IRS rear suspension and the rear shocks are cutting into and CV joint boots. It appears that who ever did the install of the rear IRS (lowered) suspension did something wrong. Would you be so kind as to advise on what I need to do to fix my problem? please see pictures below. Thank you in advance for helping me out
quartermilecamel Samba Member
Posted: Sat May 02, 2015 3:23 pm Post subject: |
relocate that shock absorber top mount more forward? Not too familiar wth what type of control arms do that but Id say easiest way would be to move the metal top mount twards the front.
Is the tire centered in the wheel well front to back? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sat May 02, 2015 6:50 pm Post subject: |
Definitely need to relocate that top shock mount. _________________ nothing |
Posted: Sun May 03, 2015 2:36 am Post subject: |
Do all conversations (rear swing axle to IRS) need the top shock mount moved forward? |
busworks Samba Member
Joined: May 21, 2004 Posts: 201 Location: Moncks Corner,S.C.
Posted: Sun May 03, 2015 4:54 am Post subject: |
It looks like that top shock mount has already been moved once. Definately not in the right place. Cut the welds and move it to where it looks good/should be.
Typically not a problem with the top mount being in the way of the axle. |
Pinetops Samba Member
Posted: Sun May 03, 2015 5:03 am Post subject: |
I can't believe whoever lowered that thing left them like that. I'd go through everything to see what else they rushed. _________________ "A rolling bus gathers no rust." |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1300 Location: North Carolina
Posted: Sun May 03, 2015 6:22 am Post subject: |
I experimented on mine by cutting away the outer casing of an old shock so it wouldnt touch. You can purchase a shock w/o the casing, having said that it still looks like the shock is at a sever angle.
I will end up repositioning the upper shock mount on my IRS conversion. |
Posted: Sun May 03, 2015 12:54 pm Post subject: |
It's not hard to fab a new mount closer to the frame and get the shock straight |
Posted: Wed May 27, 2015 3:48 am Post subject: |
Ok relocating the top shock mount.
What shock to I purchase?
1967 Bus with 1969 IRS Bug rear end lowered
Thank you for helping |
Posted: Thu May 28, 2015 10:22 am Post subject: |
I like KYB Gas-Adjust for the rear. They handle the weight of the bus well. |
Posted: Thu May 28, 2015 11:29 am Post subject: |
greenboat4 wrote: |
https://www.thesamba.com/vw/gallery/pix/1345208.jpg
Take a look at the severe shock angle in this pix....seems to me that the upper shock mount should be located just below the frame rather than to the side as it is in the pix. This means you need a real short shock that still has the necessary range.....the major shock manf usually have all their shock dimensions listed its just a matter of scrolling thru their online PDF catalogs. I have the same problem to resolve as soon as I finish my rear disc brake conversion. Monroe shocks list max height and compression as well as what type upper/lower mount. |
