Baja rack I have been working on
5.0 Chero
5.0 Chero is offline
PostPosted: Wed May 06, 2015 10:10 am    Post subject: Baja rack I have been working on Reply with quote
Flush_Gordon337
Flush_Gordon337 is offline
PostPosted: Wed May 06, 2015 10:31 am    Post subject: Reply with quote
Now that's a nice rack!
I like to sit in my barn and play with my Thing!!!
1974 Type 181
Berrien 902
5.0 Chero
PostPosted: Thu May 07, 2015 1:29 pm    Post subject: Reply with quote
Found it on Ebay thought the shape would work well on the bug
mattfarmer
mattfarmer is offline
PostPosted: Fri May 08, 2015 8:37 am    Post subject: Reply with quote
nice!!!!
dirtslinger
dirtslinger is offline
PostPosted: Sat May 09, 2015 10:15 am    Post subject: Reply with quote
I think you mounted it backwards
5.0 Chero
PostPosted: Sat May 09, 2015 10:50 am    Post subject: Reply with quote
no the air deflector faces forward but I did try it the other way and if I was not using the air foil as a light mount I may have ran it that way
enjoyther1de
enjoyther1de is offline
PostPosted: Sun May 10, 2015 3:34 pm    Post subject: Reply with quote
Sweet. What kind of rack is that? I'm looking for something like that.
HBB took me to BBV.
5.0 Chero
PostPosted: Sun May 10, 2015 7:23 pm    Post subject: Reply with quote
http://www.aaproductsinc.com/collections/racks
Dr OnHolliday
Dr OnHolliday is offline
PostPosted: Sun May 10, 2015 7:44 pm    Post subject: Reply with quote
Not the rack I was hoping to see...
1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
Bashr52
Bashr52 is offline
PostPosted: Mon May 11, 2015 4:24 am    Post subject: Reply with quote
Weird, the way you have it mounted is the way they show it is supposed to go on the website, but I do agree it looks like it should go the other way....
5.0 Chero
PostPosted: Mon May 11, 2015 9:46 am    Post subject: Reply with quote
Sorry Very Happy
5.0 Chero
PostPosted: Thu May 14, 2015 4:28 pm    Post subject: Reply with quote
ok here it is sitting the other way I have not make a new light bar yet
the lights will sit here
so what way do I mount it?
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Fri May 15, 2015 8:18 am    Post subject: Reply with quote
I'm thinking your really not going to benefit from all those lights with it on this way..
Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER
Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc
5.0 Chero
PostPosted: Fri May 15, 2015 8:25 am    Post subject: Reply with quote
no the lights will be mouted up front thats what the aluminum angle is for I just turned the rack around to see what it looks like, The other pictures show where the 5 lights will be mounted the plate the lights are mounted on now will be removed also
ORANGECRUSHer
PostPosted: Fri May 15, 2015 11:07 am    Post subject: Reply with quote
I was being fececious BTW. I know it was hard to tell from the tone of my voice.
nice lookin bug. Is that a filler cap on the back quarter panel?
Brian H.
OrangeCrushER
5.0 Chero
PostPosted: Fri May 15, 2015 11:27 am    Post subject: Reply with quote
Yea it has an aluminum tank beind the seat It (gas cap) will changed as soon as I find a filler that I like
5.0 Chero
PostPosted: Tue May 19, 2015 12:27 pm    Post subject: Reply with quote
here are some mock up pictures with the rack reversed
5.0 Chero
PostPosted: Wed May 20, 2015 10:45 am    Post subject: Reply with quote
High Lift mounts mock up
5.0 Chero
PostPosted: Wed May 20, 2015 10:59 am    Post subject: Reply with quote
mounts finished using locking lug nuts to slow down any would be thief
dirtslinger
PostPosted: Thu May 21, 2015 12:36 pm    Post subject: Reply with quote
I think it looks great and more like it should turned around.
