Air conditioning
reluctantartist
reluctantartist is offline
PostPosted: Fri May 08, 2015 7:09 pm    Post subject: Air conditioning Reply with quote
So I was looking around at ac options and I came across this.
http://www.seanhylandmotorsport.com/blog/12-v-air-...t-for-you/
With a higher output alternator this looks like it could be a viable option.
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
raygreenwood
raygreenwood is offline
PostPosted: Fri May 08, 2015 8:12 pm    Post subject: Reply with quote
Not likely in an aircooled normal engine.... at 24-31amps running and it will need about 2x that for start up cycle......and then add in everythiny else in the system at max emergency rain at night.....style usage.....and you will need a HUGE alternator. That......and 6,000+ BTU is quite small. Not bad but not stellar.
But...its a great concept and for a water cooled mid sized engine that can spare the load.....not bad. Ray
Lars S
Lars S is offline
PostPosted: Fri May 08, 2015 10:18 pm    Post subject: Reply with quote
Just trying to understand the system:
Input: 25A at 12V equals to 300W.
Output: 6000btu/h equals to 1800W.
So the cooling factor COP is 1800/300 = 6.
Normally in a car AC system the factor is about 2 to 4 as far as I know.
Not saying that something is wrong...just trying to understand...
Lars S
Porsche 914 -72, Bahia Red daily driver Smile
VW411 2-d -70, White, sold Sad
VW412 4-d, -73, Gold Metallic, daily driver
Suzuki T500, -69, Candy Gold, sold Sad
Suzuki K50, -77, Black, daily driver
BMW R69S -69, White, sold Sad
Husqvarna 118cc, -47, Black, Sold Sad
raygreenwood
PostPosted: Sat May 09, 2015 7:35 am    Post subject: Reply with quote
Lars S
I know. ...the basic math, shows that it is an energy hog. Yes....it should cool.....but that is not a lot of btu......and aclot of power for what btu is there. But....if you have a large enough power to weight ratio in your vehicle and have plenty to spare.....go for it. Ray
Lars S
Lars S is offline
PostPosted: Sat May 09, 2015 7:45 am    Post subject: Reply with quote
Lars S
What is suspicious to me is that 300w input power should normally generate something like 900btu/h...to generate 1800btu/h the input should be about 600W 50Amps...and I hope it is not...
Lars S
raygreenwood
PostPosted: Sat May 09, 2015 9:05 am    Post subject: Reply with quote
I could see this being used in say......a van/SUV based small RV....that already has a huge alternator.....like 125-150, amp running off of a V6 or V8.
See the strange thing about going the route of electric AC.....is that it is really unnecessary. If you are willing to spend....or fabricate. ....at that level.....just get a modern up date variable stroke AC compressor.
There has been a lot of research into AC compressor systems in conversations over on the STF.
Modern AC compressors like those on my 2006 Jetta and my 2012 Golf....and on most other modern cars since say....the mid to late 90s.....use AC compressors a helical drive, swash plate system with an infinitely variable piston stroke. They use a bypass refrigerant bleed that bleeds head pressure to crankcase side on the compressor to vary the stroke length while running....based on rpm and engine load.
So in traffic....at low rpms.....the compressor runs a stroke that may only be a few millimeters.....and takes very small percentage of power from the engine to run. Ae long as the interior of the car and the coil under the dash has already been generally cooled down....the compressor supplies enough pressure and refrigeration to keep it cool.
As you accelerate the compressor stroke and efficiciency increases. It also drops down to low again at highway speeds. Some use a combination of controls inputs to the electronic bleed valve....that takes inputs from thermostat and control valve as well as line pressure etc.....others are just rpm based.
The issue for getting one of these modern compressors is finding one that fits and has the correct direction of rotation for an ACVW. But if you are willing to fabricate bracketing.....you can make one fit.
The bypass valve control could probably be controlled directly, from a, dash rheostat. So you start out on high....using max power from the engine like and old school AC compressor....about 5hp draw.....until you get the car chilled down. Then turn the knob down to say about 5% just to keep you cool.....and you end up using maybe 1/2hp draw for highway cruising.
I know the AC on my Golf...what little I use it.....affects my highway gas mileage by maybe 1mpg Max. Also you cant feel any drag in driving in traffic. Ray
ClassicCamper
ClassicCamper is offline
PostPosted: Sun Oct 25, 2015 9:01 pm    Post subject: Reply with quote
I had a 1970 411 underdash restored by Gilmore Enterprises. He never disappoints:
The compresor is already installed in the engine.
raygreenwood
PostPosted: Sun Oct 25, 2015 9:28 pm    Post subject: Reply with quote
Nice!
Ray
ClassicCamper
PostPosted: Tue Mar 15, 2016 11:56 pm    Post subject: Re: Air conditioning Reply with quote
Received my condenser from Gilmore a few days back. This is designed to to sit in the spare tire well with a plastic cone over the top, thus allowing the tire to still reside in the trunk. If this Gilmore system works as well as those I installed in a couple of my last beetle and bus restos, I'll be styling come the summer months. Here is the piece:
I do have copies of VW Air Conditioner part/schematic books with ZVW part numbers as well as the break-out of every nut and bolt used to run the A/C units from all ACVWs 1967-80. I don't break these sets up, but since I'm partial to my T4 friends, PM me and we'll see what we can work out if interested. I'll keep everone posted as to how this build goes via this thread.
1973 412 Wagon
1976 Westy
1978 SB Vert
raygreenwood
PostPosted: Wed Mar 16, 2016 6:53 am    Post subject: Re: Air conditioning Reply with quote
This is one of two methods the factory used for adding AC. A couple of important points to consider.
1. You are going to have to cut two 3" wide slots about 14" long in the spare tire well. The one on the lead edge being intake and the trailing one being exhaust. If your car already used this method you may already have them.
2. If memory serves, the original used a special condensor in that configuration. It was not a straight flat condensorr. It was a double row condensor with the tubes at about a 45° angle to match the plane of the incoming and outgoing air.
I cannot remember if the cone under the spare tire had a fan under it.
3. This raises the spare tire and the lid about 2.5" to 2.75"....I dont have exact measurements. The dealer install method was to strip out the vinyl trunk liner on each side of the spare tire hatch and the basket weave on top of the spare tire lid......and glue sheets of foam the same thickness on top of all three areas and then reapply the vinyl. In this way the trunk has a nice flat bottom.
4. The dryer went under the right front fender.
5. Do you have the pulley that sandwiches between the fan and crank. Ray
