wingman Samba Member
Posted: Sat May 09, 2015 12:27 am Post subject: Plenum removal |
How can I remove the plenum with engine in the car? I cannot figure out the way to remove the nut next to the firewall since it is hidden behind the throttle assembly. I managed to remove one flat head screw that attaches the throttle to the plenum but the other just won't budge
Is it even possible to remove the nut with throttle body and engine in place?
Thanks,
Michael |
Lars S Samba Member
Posted: Sat May 09, 2015 6:32 am Post subject: Re: Plenum removal |
wingman wrote: |
Thanks,
Michael |
Im not sure its possible, it will be tight anyway. The eye for the bolt is quite hidden behind the TB. Have you tried to tighten the other screw again to reduce the force on the stuck one?
Lars S
_________________ Porsche 914 -72, Bahia Red daily driver
VW411 2-d -70, White, sold
VW412 4-d, -73, Gold Metallic, daily driver
Suzuki T500, -69, Candy Gold, sold
Suzuki K50, -77, Black, daily driver
BMW R69S -69, White, sold
Husqvarna 118cc, -47, Black, Sold |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sat May 09, 2015 7:40 am Post subject: |
You can do it....and as Lars noted.....it is VERY tight......and very ffrustrating. You need to lower the engine slightly and remove the runners and all or the nuts/bolts holding the plenum until you can tilt it up slightly pivoting on the bolt you have no access to at the rear.
The first time I had to remove a plenum this way I took an older wrench and ground and bent it to get at the nut.
After I was finished I think i reversed that bolt to have better access to the nut for the next time. Ray |
Posted: Sun May 10, 2015 10:54 pm Post subject: |
Thanks guys. I tried to undo the stuck one with the other tighten without success the passing weekend. I will give it a couple more try this week before I go with the hard route |
Posted: Tue May 12, 2015 7:51 pm Post subject: |
Finally got it out today. Did not know I can actually undo the nut from the bolt side of the engine |
Posted: Fri May 15, 2015 5:15 pm Post subject: |
wingman wrote: |
Been there! dont beat your head. Its hard to see....and I swore it was a stud long ago when I first ran into this.
I flipped the bolt around on mine because there was easier access from the other side. Ray |
Posted: Tue May 26, 2015 7:51 pm Post subject: |
I was so glad when I found it is not a stud. I have spent weeks trying to get this sucker off from the other side. |
