Duncan's 1966 Ghia Coupe rebuild
Page: 1, 2, 3, 4, 5  Next
Mr.Duncan
Mr.Duncan is offline
PostPosted: Thu May 14, 2015 11:06 am    Post subject: Duncan's 1966 Ghia Coupe rebuild Reply with quote
Afternoon!
I've recently acquired a Bone stock 1966 One owner Ghia. 85,000 miles.
It hasn't run in 12 years due to the owner parking it in the garage.
Good news, the engine still turns over by hand, and the 6 volt electrical system is 100% stock and in-tact. (stock 1300 SP)
I will be posting photos soon, so just wait for those.
I've been working on type 1 air-cooled's for about 4 years now, however I work mainly on the 70'+ years.
My plan is to change the oil, set the valves, basic tune up (static time at first) plugs/wires/cap/rotor/ rebuild the carb/ new fuel pump/ new rubber fuel lines.
Pop-in a new 6 volt battery and see if I can get it started. And then change the oil again. And check the compression.
Depending on how bad the gas tank is from sitting, I may replace it.
Next, Without question I plan to rebuild the ENTIRE brake system for safety. Everything down to the metal lines will be replaced, however this year has disks all around, and a single circuit master cylinder.
I plan to upgrade to Disks in the front, as I did with my Bug, but I assume I will need to change to a dual circuit master cylinder?
(some advice would be nice)
Also the car has EMPI wide 5 GT-5 (vw lugs) rims. Which will be removed, and powder coated with new 165/80/R15 Yokohama tires.
Lastly, In the near future, I plan to replace the entire wire harness (just so i know everything is 100% new, and switching to a 12 volt system, any recommendations here would be great.
Nice to be apart of this forum, and will post updates here Soon.
Cheers- Thomas
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
c21darrel
c21darrel is offline
PostPosted: Thu May 14, 2015 11:28 am    Post subject: Reply with quote
Welcome and congrats, 66 is a good year!
Photos!
For sure drain and replace the fuel.
If fuel pump works...no need to replace.
Photos!
You will be hard pressed to buy aftermarket parts that are anywhere as good as the originals, Keep fuel tank as long as it is not swiss cheese. Pinholes can be simply repaired...
Dont throw anything away...at least until you have satisfactory replacement.
Disc brake conversion is not too difficult on a balljoint 66, nice upgrade. I would go to a dual circuit M/C.
In the 80's...I went 12 volt on a 66, replaced dash bulbs... and kept the 6 volt starter, 12 volt solenoid. Will fire your motor quickly!
Where are the pics? Very Happy
GhiaBuild
1967 DC build
sb001
sb001 is offline
PostPosted: Thu May 14, 2015 5:22 pm    Post subject: Reply with quote
Wait until you see the pics-
love that color.
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri May 15, 2015 12:20 am    Post subject: Reply with quote
Welcome to The Ghia Forum. Very Happy
Like the other's I'm looking forward to seeing the pictures...post them to The Samba Gallery. If you're not sure why you should upload them to The Gallery, check out the link at the bottom of my signature, it's important Smile
Sorry if you already know this but I don't like to miss the opportunity to spread the message. Wink
John.
sputnick60
sputnick60 is offline
PostPosted: Fri May 15, 2015 5:26 am    Post subject: Reply with quote
Welcome Mr Duncan.
We wish you every success with your '66 and look forward to seeing it evolve. Just wondering how your plans are for the brakes.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Mr.Duncan
PostPosted: Fri May 15, 2015 11:29 am    Post subject: Reply with quote
sputnick60 wrote:
Welcome Mr Duncan.
Nicholas
As of right now, a front ball-joint disk brake kit in the front with a Bus (larger bore) master cylinder. and Stock Drum brakes in the rear.
1966 Ghia (sold)
1966 Red Beetle
Mr.Duncan
PostPosted: Fri May 15, 2015 11:31 am    Post subject: Reply with quote
Does the 66' Ghia use the same style front beam and shocks as a 66' Beetle?
If so, I plan to get OEM style Oil shocks from Wolfsburgwest.
Can anyone confirm? I assume the ride quality is great with oil shocks, I put gas ones in my Beetle, and they were WAY to stiff.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113413031E
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111513031G
Also, I assume the best supplier of rubber seals & products would be West Coast Metric? Just like for the Beetle.
1966 Ghia (sold)
1966 Red Beetle
c21darrel
PostPosted: Fri May 15, 2015 11:49 am    Post subject: Reply with quote
Yes, so its easy to swap over to ghia disc. 4-lug Embarassed
Type 1 is type 1 Very Happy Pan is a few inches wider per side. Mechanicals the same.
GhiaBuild
1967 DC build
Mr.Duncan
PostPosted: Fri May 15, 2015 11:50 am    Post subject: Reply with quote
I Plan to keep the stock 5 lug Rims
1966 Ghia (sold)
1966 Red Beetle
c21darrel
PostPosted: Fri May 15, 2015 11:55 am    Post subject: Reply with quote
I got all my seals from WCM, good stuff, no problems i recall.
BTW, can you hook a guy up with tickets for the game? Cool
GhiaBuild
1967 DC build
WooleyNelson
WooleyNelson is offline
PostPosted: Fri May 15, 2015 12:56 pm    Post subject: Reply with quote
you will then need to scour the aftermarket for what you need.
VW discs on Ghias were all 4 lug
Mr.Duncan
PostPosted: Fri May 15, 2015 12:58 pm    Post subject: Reply with quote
Yes, I was planning on this kit.
http://vwparts.aircooled.net/0-Offset-Wide-5-Disc-Brake-Kit-1966-Ball-Joint-T1-p/401500.htm
1966 Ghia (sold)
1966 Red Beetle
c21darrel
PostPosted: Fri May 15, 2015 1:13 pm    Post subject: Reply with quote
no drop spindles Crying or Very sad
GhiaBuild
1967 DC build
Mr.Duncan
PostPosted: Fri May 15, 2015 1:14 pm    Post subject: Reply with quote
As much as a few people may not like, I prefer stock height.
unless you can convince me otherwise. lol
1966 Ghia (sold)
1966 Red Beetle
c21darrel
PostPosted: Fri May 15, 2015 1:18 pm    Post subject: Reply with quote
Great, and the next thing you're going to tell me is it will have stock 1300 too Rolling Eyes Wink
GhiaBuild
1967 DC build
Mr.Duncan
PostPosted: Fri May 15, 2015 1:19 pm    Post subject: Reply with quote
So, I have a question you Ghia Guys can answer,
I noticed... No vent windows..?
How do you stay cool while driving? I know the front nose vents route air into the car, but where is the exit? Any way to point it at your face?
Cheers-
1966 Ghia (sold)
1966 Red Beetle
Mr.Duncan
Currently saving a 1776 for it Wink
1966 Ghia (sold)
1966 Red Beetle
c21darrel
PostPosted: Fri May 15, 2015 1:29 pm    Post subject: Reply with quote
A.You just cant drive it in the summer
B. Cut a hole and ragtop it Embarassed
C. Univents
D. Hold your arm out the window to steer air in.
E-Z. http://www.thesamba.com/vw/forum/viewtopic.php?t=512209&highlight=venting
1776 Applause Applause Applause
GhiaBuild
1967 DC build
sputnick60
PostPosted: Fri May 15, 2015 6:27 pm    Post subject: Reply with quote
As for rubber seals and the like, I used WCM on my first Ghia but for the '66 I found the ones for KGPR and HOG were better. Generally KGPR will have a wider Ghia selection
Nicholas.
Bloku
Expert Noob
Bloku is offline
PostPosted: Fri May 15, 2015 8:18 pm    Post subject: Reply with quote
I made this post about a year ago. It is about getting some more air in. I am waning the air deflector thing but mod it where it scoops in more air. http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20
1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1976 BMW 2002 (Bored and Stroked w/ 5-Speed)
1981 BMW E21
1986 Toyota 4Runner (Dead engine and trans)
1989 Toyota 4x4 PU
1994 BMW E36 (Daily)
Page 1 of 5
