DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Sat May 16, 2015 1:34 pm Post subject: Top end rebuild/performance upgrade questions?? |
67 delux bus we purchased a year ago came with a stock 1600 of unknown history. It ran pretty good all fall with the exception of fouling plugs(solex not properly adjusted, & 009) and serious oil leaks at the pushrods tubes, so while I got it out I'm redoing the top end as follows:
AA thickwall 88s slip in the case
L3 heads or Kaddyshack KS1000s
40 idfs or 36 dells
1.25 rockers
Tri mill exhaust with j-tubes.....maybe 1-3/8 sidewinder if available
Inlet/outlet 26mm oil pump(CB Perf)
What do you think of the above upgrades?
Also when I pull the heads and measure the deck height on the current 85s can I assume that deck height will be the same with the AA 88s? The reason I ask is because both Aircooled.net and Kaddyshack ask what cc would you like on your heads in order to dial in my desired c.r....8.25-8.75 range. This way I can order everything at once rather than the p/c 1st then the heads later after I figure the deck height.
Or better yet perhaps someone can recommend head cc to get me within my c.r. range!
Thanks |
Posted: Sat May 16, 2015 1:40 pm Post subject: Re: Top end rebuild/performance upgrade questions?? |
the head CC is independent to the deck height. So order the heads with the TARGET CR AND DH that you are aiming for. Then use the shims to achieve that DH.
Running some quick #s, to get 8.5:1 and .060" DH you need 47cc.
I like to see heads with bigger chambers than that (for use on bigger engine in future).
51cc goes to 8:1 exactly.
If you also tighten DH to .040" and 51cc, you get 8.3:1. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Sat May 16, 2015 1:53 pm Post subject: |
I used the AA 88's in the past and remember they had less deck than stock 85.5's. .035 - .040" if I recall. Each engine is different though and you need to mock up and measure. _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
Posted: Sat May 16, 2015 1:56 pm Post subject: |
I'd order the P&Cs and do a quick mock up to check the current DH, then you'll know where you are at.
The reason is what are you going to do if you order everything at once, and then during your mock up you find your deck height is .090"? _________________ It's just advice, do whatever you want with it!
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Sat May 16, 2015 3:31 pm Post subject: |
My deck on an untouched AE case with .010 cylinder shim and 88 AA's is .062 _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Jun 09, 2015 6:17 pm Post subject: |
Just pulled the heads and 1600p/c off this engine and there is a lot oil and grime buildup above and below the cylinders. I plan to clean up this area as well as the entire shortblock. Some degreaser and water will get into the motor....will this be a problem?
What's the best way to cleanup a shortblock that you just want to rebuild the topend? |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Jun 09, 2015 6:25 pm Post subject: |
The thickwall 88(AA'S) I built last had .054 deck out of the box. I added 49cc heads...8.3:1. Done
link...http://www.thesamba.com/vw/forum/viewtopic.php?t=519555&highlight=thickwalls _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue Jun 09, 2015 6:29 pm Post subject: |
A gasket kit is only $25. I would tear the block apart and clean everything. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7221 Location: Videbaek Denmark
Posted: Thu Jun 11, 2015 5:59 am Post subject: |
Tight deck and 8,3 - 1 CR is what I would do on such engine.
36 Dells.
That FF thing is nice. HOWEVER, it reduces the efficiency of the stock cooler, because the oil bypasses more. Then you need a relatively large external cooler to make up for that.
T |
Posted: Thu Jun 11, 2015 8:44 am Post subject: |
Correct me if I'm wrong but with the Maxi pumps not all of the oil gets filtered, some oil can bypass the filter. I never trusted those style pumps _________________ 71 Super - Backroad Thrasher
mark tucker Samba Member
Posted: Thu Jun 11, 2015 8:54 am Post subject: |
it's a bus ,I would ff it.add a ext cooler,use a 30mm pump, go throught the entire engine or you are wasting time&$$ get the right cam&lifter combo for the app.I would also go with the 40 hpmx's.there new..040 deck+-.005 . 40x35 stainless valves.8.5 cr. extra oil gally&sloted lifter bores. fully balanced assy, groove mains for better oiling. copper head gadgets,if it were mine i would also add some stroke to help push that bus around easyer. |
Posted: Thu Jun 11, 2015 3:42 pm Post subject: |
Mark...my original intent was to just take care of some oil leaks that required removal of the heads and get in a few upgrades like heads and carbs that could be reused in a small stroker(74 x 90.5) that I'll build this winter along with the installation of a new wire harness.
Just completed a 4 wheel disc brake conversion using Porsche 944 parts, converted to IRS beetle rear suspension and tranny and installed a Womack 4" adjustable front beam. The wife says shes spent a lot of $$$ on this bus and she's ready to ride. The $3000 plus dollars it will take to build a proper engine like the one you discribed will be done when the bus goes back in the garage in Nov.
Working 10-12hr work days, maintaining a yard, and visiting elderly relatives on weekends means anything I do to the bus that could be done in a day turns into a couple of weeks.....just want to make the wife happy so she can enjoy it while the weather is nice. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Jun 11, 2015 3:54 pm Post subject: |
What I would do is clean the shortblock and mock up #1 cylinder. Then I'd go with 50cc/.050 for 8.3cr. Send in your cylinder to get milled if necessary. Have a chance to take a look at what cam is in there yet? _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Thu Jun 11, 2015 6:57 pm Post subject: |
jfats808 wrote: |
What I would do is clean the shortblock and mock up #1 cylinder. Then I'd go with 50cc/.050 for 8.3cr. Send in your cylinder to get milled if necessary. Have a chance to take a look at what cam is in there yet? |
It's a stocker and was in the bus when we purchased it. Ran OK besides oil leaks at all the pushrod tubes. I could have just put it back together as is and just replaced pushrods and seals since the heads are not hurt. I figure even with a stock cam a 1700 with either a set of LN3 or KaddieShack KS1000 which have 40x35 valves, 40 webbers, and performance exhaust should make an easy 65mph. |
MURZI Samba Member
Posted: Thu Jun 11, 2015 7:19 pm Post subject: |
40x35's on that combo will be a mistake.... I have built this combo a couple of times. (once with 40x35's) The stock valves will give you much more lower end grunt. The engine will be way more snappy with stock valves. trust me...... _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Wed Jun 24, 2015 9:28 am Post subject: |
MURZI wrote: |
40x35's on that combo will be a mistake.... I have built this combo a couple of times. (once with 40x35's) The stock valves will give you much more lower end grunt. The engine will be way more snappy with stock valves. trust me...... |
How much of a mistake?? I ask because I would like to reuse these heads when I build a small stroker around 1900 to 2000cc and the heads will probably not have 500 miles on them when I take them off the 1700cc engine. |
MURZI Samba Member
Posted: Wed Jun 24, 2015 10:02 am Post subject: |
So with stock cam and 1.25's..... 415ish lift. .315x1.31 This screams stock head to me. No bottom end. Not what you want in a bus.
If you are going to build a bigger engine later, buy the heads for THAT engine based on ITS cam, compression, purpose. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Thu Jun 25, 2015 10:35 am Post subject: |
Those AA's come with valve pockets? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
