RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Mon May 18, 2015 3:13 pm Post subject: 914 2 liter rocker arms? |
I am told that 914 2 liter rocker arms are different than type 4 bus/vanagon rockers. Unfortunately the rockers from a 2 liter engine I am putting together were inadvertently mixed in with some bus rockers. Can anyone tell me how to identify them? They all look the same except the casting numbers. |
Posted: Thu May 21, 2015 6:50 am Post subject: |
Really, no one?
How about a picture of the rockers with the valve cover off?
Please? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Thu May 21, 2015 12:34 pm Post subject: |
RPGreg2600 wrote: |
Really, no one?
Please? |
No.....2.0 rocker arms are the same as 1.7L rocker arms in ratio i am fairly sure...all accept the 8mm adjusting screw.....the do the difference being that some 2.0l rocker arms may already clearanced for the 911 style swivel feet. All type 4 engines had the same rocker ratio....411/412/bus or 914.
Most of the middle years bus....with 1.8s had the 10mm adjusting screws. I think the late bus 2.0 had the opportunity 10mm adjusting screw as well.
A quick comparison can be set up by mounting four of them across on a rocker shaft...making sure that the pushrod end is resting at the same height on all...and look at the angle and length of the valve end.
There were some mfg variations as well. There are some rockers that are off by a few degrees. I usually set up a nig with a stub cut off a pushrod to make sure the whole set is the samE.
As far as I am aware....they are all the same ratio in type 4 engines. Ray |
lonewolfe Samba Member
Joined: April 09, 2010 Posts: 59 Location: San Francisco
Posted: Sun Jul 05, 2015 8:19 pm Post subject: 914 rocker arms |
The rocker arms for 1.7 , 1.8 & 2.0
VW/PorscheType 4's have the same rocker ratios. None of these rockers are clearenced from the factory for 911 valve adjuster screws. 1.7 & 1.8 rockers have 8.0mm valve adjustment screws and 2.0 rockers have 10mm valve adjustment screws. 911's have 8.0mm valve adjustment screws. Only the 1.7 & 1.8 rockers can be clearenced to work with 911 swivel feet valve adjustment screws. This a great upgrade over standard valve adjustment screws. _________________ If you hear these words then get out of the way, "Hey Ya'll, Watch this!!!". |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2233 Location: Medford, OR
Posted: Fri Nov 06, 2015 9:45 pm Post subject: |
Are there any ratio rockers options available for the typeVI/914? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Fri Nov 06, 2015 11:01 pm Post subject: |
Yes, Pauter and I believe Tarret makes them. These are roller rockers though. I know for sure Pauter Machine makes them in 1.4, 1.5 and 1.6 ratios.
Pauter.com _________________ If you hear these words then get out of the way, "Hey Ya'll, Watch this!!!". |
Posted: Sat Nov 07, 2015 7:33 am Post subject: |
Thank you. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
