David23 Samba Member
Posted: Tue May 19, 2015 12:33 pm Post subject: 69 bug., .passenger side mirror, NEEDED .what are my options |
I just started driving a bug again ...and this 69 I picked up has only a left side mirror well I have to admit I am not always in the slow lane.....and am in need of a passenger side rear view mirror ....any suggestions that actually work ? ...any suggestions that don't work ?...thanx ! |
slagathor Samba Member
Joined: December 08, 2012 Posts: 253 Location: Oakland, CA
Posted: Tue May 19, 2015 12:47 pm Post subject: |
i plan on adding a passenger side mirror too but like you, i have no mount for it
however i plan on buying the mirror and mounting bracket in the link below:
http://www.mooreparts.com/5331-AC857846-4/
it just mounts to the door frame |
TX-73 Samba Member
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2400 Location: Gladstone, Ore
Posted: Tue May 19, 2015 8:22 pm Post subject: |
Also look into the Karmann Ghia mirror and it's mount. Little easier to install then a OEM Bug mirror, looks pracitically the same _________________ 1972 1302
HPMX 40's & 019 |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Tue May 19, 2015 9:27 pm Post subject: Re: 69 bug., .passenger side mirror, NEEDED .what are my opt |
David23 wrote: |
I added a passenger side mirror to my '68 Beetle. Drill a small pilot hole first to make sure it matches the other side. Then measure carefully and enlarge the hole to the correct size.
Mine did not have the nut welded inside the door, so I clamped a nut onto a stick and fed it up inside the door until I could thread the mirror into it. I elected to use the expensive OEM mirror (I believe it was VW Mexico or Brazil), as it matched the original German mirror perfectly.
I don't have a close-up picture, but here's one:
_________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Wed May 20, 2015 6:33 am Post subject: |
cletus_zuber wrote: |
Also look into the Karmann Ghia mirror and it's mount. Little easier to install then a OEM Bug mirror, looks pracitically the same |
.....thank you for the suggestion, which year ghia mirror would work and look the same? would I look for a 69 mirror just like the bug ? |
Posted: Thu May 21, 2015 8:00 pm Post subject: |
Not sure of any details about this, you can probably search "right side mirror' or passenger side mirror here or in the gallery for more info.
I thought about this when i did my r side mirror, ended up going OEM, drilling the big hole, taking the door all apart to install the goofy nut etc etc. _________________ 1972 1302
HPMX 40's & 019 |
marklock Samba Member
Joined: September 20, 2011 Posts: 118 Location: SE Michigan
Posted: Sun May 24, 2015 11:11 am Post subject: |
Could install the older side mirrors. Not too much money or work involved.
_________________ 1968 Beetle project |
Posted: Wed May 27, 2015 6:32 am Post subject: |
I like it ! |
