stanthedog Samba Member
Joined: October 11, 2006 Posts: 357 Location: Portland,oregon.
Posted: Tue May 19, 2015 2:43 pm Post subject: clutch slipping |
Brand new flywheel(did not check distance on clutch to pp), new kennedy pp, new porsche style cushlock clutch, all new stuff. clutch slip's some in 3rd, alot in 4th. I'm going to pull the engine probably within a few days and start checking things. So, what's the distance supposed to be from clutch to pp mounting surface?
Engine is a 2074cc in a 72 ghia.
On an additional note, I've had the engine out a number of times chasing gremlins out. one was vac leaks because I couldn't get a socket on the intake nuts. tried the 12mm nuts(which I have now) couldn't find 10mm flanged. So, I made a set of flanged 9mm nuts from 44 rockwell 4340. Gonna put them on during this gremlin chasing session. |
LivinInnaVWBus Samba Member
Posted: Tue May 19, 2015 4:41 pm Post subject: |
Did you adjust your clutch cable after installing the new parts? |
Posted: Tue May 19, 2015 5:06 pm Post subject: |
Ya, even tried it a little loose to see if it would help. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Tue May 19, 2015 5:08 pm Post subject: |
flywheel depth about .825-.835"
I'd have a new disk ready. What's good about the cushloc besides it's the cheapest?? |
Posted: Tue May 19, 2015 7:59 pm Post subject: |
When I bought it, they(advertisers ) said they were good. What would work better that wouldn't slam my trans to piece's. I'm willing to switch. bought it about 10 yrs ago. |
modok Samba Member
Posted: Tue May 19, 2015 8:39 pm Post subject: |
I was just wondering, never tried cushlok, but I kinda suspect it won't "recover" well after slipping a lot.
Daikin is good. |
Posted: Wed May 20, 2015 11:21 am Post subject: |
Just looked at the old reciepts, clutch is a super disk from CB performance. I'm gonna have to pull it, so I might replace it. Whats a good clutch that won't be to grabby. The st-1 kennedy is probably fine. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed May 20, 2015 1:10 pm Post subject: |
Daikin or kushlok should do it. I'm surprised u slipped the super disc unless oil got on there. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Wed May 20, 2015 2:07 pm Post subject: |
Did have an oil leak from the front oil galley, some dipshit( ) screwed up the threads. Got it fixed, didn't see any oil on the disk. guess I'll find out this weekend.
Empi sells a daikin either repackaged or knockoff- any good? Best I can get locally. |
Posted: Wed May 20, 2015 3:49 pm Post subject: |
It held my old 2276 with 44 wedges, 9.6 cr , fk8 and idas. So I'd say yes if your under 180hp. _________________ 2276 IDA's 86C 11-1 DD !
modok Samba Member
Posted: Wed May 20, 2015 5:01 pm Post subject: |
I have no idea what part is most suspect. I guess just check everything. |
Posted: Wed May 20, 2015 5:26 pm Post subject: |
Reciept's also show crank and flywheel are DRD.
Thank's all, will start checking. |
Posted: Sun May 24, 2015 2:06 pm Post subject: |
Would it be of any advantage to go closer to .825 to make it tighter. got the flywheel off today, clutch looks fine. but will replace anyway since I have the replacement(another super disk). Probably will resurface both surfaces. |
Posted: Sun May 24, 2015 2:49 pm Post subject: |
Checked with depth mic. .831" . flywheel is all brown, looks like heat treat. even the clutch surface, should it be like that? I would think it should be bright shiney bare metal.
I.D. of the flywheel PP relief measures 9.244", PP O.D. measures 9.25+.
Seems like that could be a problem. |
Posted: Sun May 24, 2015 4:06 pm Post subject: |
So, I took about .002" off the clutch face on the flywheel, zero'ed the DRO, came out .83, faced the PP surface. Mic'ed .828". chucked the PP, dialed it in and took about .005" off the OD, so now it fits in the flywheel-snugly. Hope that cures my clutch prob. |
