bus bruce Samba Member
Posted: Tue May 19, 2015 4:51 pm Post subject: MN Vanagon trouble |
I just got done rebuilding a 1983.5 Vanagon. Gaskets rings seals pumps coils spark plugs and wires. It's all new. I am a first time owner. I used the Bently to get through the rebuild. Now everything rolls over. I have spark gas and compression. I just got done adjusting the timing. Pretty sure I had it. But it doesn't start no matter what I do. Andy thoughts or knowledgable people I could contact in the Twin Cities that could help a guy out? |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Tue May 19, 2015 7:27 pm Post subject: |
Id go back to basics. Double check tdc. Got tdc on compression stroke? Ok now check valves. You can have gas spark and compression but if not at the right time no fire. Oh and then make sure rotor is pointing at the number one plug connection on the distributer cap. |
Posted: Tue May 19, 2015 7:33 pm Post subject: MN Vanagon trouble |
Yeah I checked timing today. Thought I was going to get it. I did try to find TDC. I used the notch and that should be TDC right. Then I looked at the rotor and it was at 5 o'clock and that's where my number 1 went. Then 432. Still off |
Posted: Tue May 19, 2015 7:55 pm Post subject: |
At this point i would want to know mechanically where tdc is . Pull #1 plug and feel for the pressure escaping the plug hole. Then comparing all factors rotor, valves, notch etc. |
AKWesty Samba Member
Joined: April 12, 2014 Posts: 680 Location: Haines, Alaska
Posted: Tue May 19, 2015 8:01 pm Post subject: |
Do you have a compression gauge? You said you have compression. What are your numbers. My point is that if you did not adjust your rockers correctly then you could have valves hanging open. The compression test will give some numbers. I would also pull your valve covers and use a flashlight to make sure your push rods are seated properly. They are tough to get seated correctly on the first try. _________________ 84' Westy 2wd
EJ22 - 4spd - Peloquin TBD
GW +1.5 Springs
215/70-16's
www.CatchTheKraken.com
"Never go to Alaska as a young man because you'll never be satisfied with any other place as long as you live." -John Muir |
kustomizingkid Samba Member
Joined: October 16, 2014 Posts: 142 Location: Minneapolis, MN
Posted: Tue May 19, 2015 10:10 pm Post subject: |
I'm in the Twin Cities, shoot me a pm if you want some help. |
morymob Samba Member
Posted: Wed May 20, 2015 5:02 am Post subject: |
If at where u think is tdc, stick a probe thru plug hole , is piston up, then see iif #1cyl, BOTH valves closed then check plug wires to be correct order AND #1 has rotor pointing at it regardless where this may be, if don't match bently possibly dizzy drive gear a few teeth off, not important if u verify the above.if ok have someonrcrank mtr check 4 spark at at a plug (s) if ok here next is if pump runs, injectors spray fuel, . |
Posted: Fri May 29, 2015 4:30 am Post subject: MN Vanagon trouble |
Well thanks for all the help. The Kustomizingkid stopped up and I think we are both stumped. Compression is all good I have spark and gas. It doesn't want to fire over even with starter spray. What am I missing. Is there anything else I should be checking for? |
Posted: Fri May 29, 2015 7:02 am Post subject: |
So I went up and checked the van out. When I got there it had no compression on one bank and timing was off. Reset timing and verified with a timing light, cranking over. Reset the pushrods on the 1/2 bank of cylinders. It has an even 75 psi on all four cylinders which is a little low, but not too crazy for a never ran fresh rebuild.
Even compression on all 4 cylinders.
Spark verified on all 4 cylinders.
Timing check with a light on #1.
Fuel Verified to be spraying from injector.
Maf had suspect reading for the air meter side, correct for air temp.
Plug wires on correctly, rotor points at #1 at TDC
The strangest part is it didn'f even puff or pop with a small shot of starter fluid. I don't think I have ever seen a motor with spark not at least pop a little with starter fluid. I an totally stumped by that. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Fri May 29, 2015 7:29 am Post subject: |
That IS odd. Agree on the starting spray - compression alone will practically set that stuff off. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Fri May 29, 2015 7:57 am Post subject: |
Yeah that should at least make it puff a little |
Posted: Fri May 29, 2015 9:40 am Post subject: |
I would rotate all the wires 180° around the cap and see what that does. Easy to reverse if that doesn't make it run.
Are you getting the smell of raw fuel coming out the tail pipe? |
Posted: Fri May 29, 2015 11:05 am Post subject: |
#1 is spot on... Checked with a timing light. Dunno how the others could possibly be wrong. |
Posted: Fri May 29, 2015 12:52 pm Post subject: |
kustomizingkid wrote: |
#1 will also appear to be spot on when it is actually 180° out on the cap. Having the wires be 180° out is all too common and gives the symptoms you are seeing. |
Posted: Fri May 29, 2015 1:14 pm Post subject: |
That did t make a diff |
akyrie Samba Member
Joined: March 24, 2010 Posts: 519 Location: Driftless, Wisco
Posted: Fri May 29, 2015 3:41 pm Post subject: |
So close! keep at it. Did you push the rotor down in the dizzy? happened to me once. A friend drove 2.5 hrs over to help fix the van, and all he had to do was pop that rotor down. heh, we got beers early. _________________ Although I got a funny message from the Porsche guys, it read, "what a mighty ship that you must sail"
....has anyone else received that?
82 AHU DK, 1950's Puch-black |
Posted: Fri May 29, 2015 3:45 pm Post subject: |
Well I just took the distributor cap off to inspect things for the 5th time. It looks bad and even one of the firing spots is covered by a small piece of plastic. So I am getting a new one. That may be a reason why it isn't firing and the reason it sounds like it's missing! |
Posted: Fri May 29, 2015 5:23 pm Post subject: |
Wildthings wrote: |
Durr... I getcha
I am very on top of inline 4 vw's, diesel and gas from 75-04... Wbx not so much. |
Posted: Sat May 30, 2015 4:34 am Post subject: |
Put a couple strips of masking tape, one on dizzy,( put alignment marks on tape 4 your starting spot) another beside it on a handy spot on block. Loosen dizzy clamp so u can turn by hand, have somr crank over eng while u turn dizzy cw to start and see if u get cyl firing, none try other way. Have had to do this sometimes to get a eng run starting point. |
Posted: Sat May 30, 2015 6:50 am Post subject: |
When finding tdc via feeling the pressure escaping the plug hole watch for the intake valve having just opened and then close just before you feel the air escape. Just did this recently on a friends aircooled to find the distributer 180 off. |
