smitty1976bus Samba Member
Joined: January 21, 2013 Posts: 369 Location: Cape Cod
Posted: Fri May 22, 2015 7:06 pm Post subject: Is it ok to put a Porsche 1.7L in my 1978 Westy? |
Hi All,
I've been searching for an engine to put into my 78 Westy, and don't have a lot of money to do so. The bus came with a 1.8L from a 1976 bus, and it's in pretty rough shape, it will need a total rebuild, if it's even salvageable. I just found a VW guy with a Porsche 1.7L, and he offered it to me for a couple thousand dollars, and my 1.8L for a trade. My question is: is this a good deal? I've been told that the 1.8L i have was only used for 1 year, and thus, a rare engine. Is it worth anything being in the really rough condition it's in?
Another question is, will a Porsche 1.7 be a smart engine for my bus? Will it last?
Thank you
Sean |
sonofamitch Samba Member
Joined: May 27, 2012 Posts: 325 Location: Evergreen, CO
Posted: Fri May 22, 2015 7:16 pm Post subject: |
For a couple grand you're better off trying to source out a 2.0L with the original fuel injection system. It doesn't get much better than that. What is the condition of the 1.7? If it's been rebuilt it might not be a bad deal. _________________ '77 Westy 2.0L FI
http://www.thesamba.com/vw/forum/viewtopic.php?t=568454&highlight= |
Posted: Fri May 22, 2015 7:32 pm Post subject: |
Oh yea, I forgot to mention that the Porsche 1.7L has been completely rebuilt, and in great running condition. I just don't know if it has enough low end torque to get the bus moving. |
Xevin Samba Member
Posted: Fri May 22, 2015 7:36 pm Post subject: |
I would be concerned about the lack of torque. Especially a camper.
Then there's the fiddling to get it to work properly. Engine tins etc. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri May 22, 2015 8:51 pm Post subject: |
Without knowing what cam is in it, it would be hard to make any kind of decision on how it would move a bus. A stock cam would be pretty much the same as a bus cam, but I suspect few people build Porsche motors using stock cams.
I agree with others, if you are paying a couple of grand, then get yourself a 1800 or 2000 built for you. FWIW, if your present motor was originally from a '76 model and hasn't been altered over the years then it would be a 2000 and not an 1800. |
raygreenwood Samba Member
Posted: Fri May 22, 2015 9:23 pm Post subject: |
Well...if we are being precise here....the 1.7l.... if its from a 411/412/914....with injection, and not carbs (because none of those cars had 1.7l with carbs in the 914, 412 and qnything other than the 68-70 411)......then they had 99 ft lbs of torque......7 more than any bus 1.8....and 6 ft/lbs less than a 2.0 bus engine. The real issue is that the 914/411/412 engine made its peak torque at about 3500 rpm.....and the 2.0 bus made its peak torque at about 2800 rpm.
However......the 1.7 with 80 to 82 hp at 4900-5000 rpm (depending on year of 1.7) as compared to the bus making 70 at 4200 rpm........if you had the gearing and cooling....you could almost make them act similar...but the 1.7 will always be at risk of overheating under load in a 4000 lb bus. Just some things to think about. Ray |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri May 22, 2015 9:27 pm Post subject: |
Is it really a Porsche motor? What's the engine code? Any pics? |
Xevin Samba Member
Posted: Fri May 22, 2015 10:15 pm Post subject: |
raygreenwood wrote: |
Love it when the professor sets the table
To me this translates to the Porsche or whatever being a PITA. Unless you got mad mechanic skills and are into that sort of thing.
Thanks Ray! _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
1967250s Samba Member
Posted: Sat May 23, 2015 12:10 am Post subject: |
A couple thousand?? and a trade?? Think on that- there is a reason he wants that 1.8 motor. You should be able to do a good rebuild for quite a bit less than that. Also, the 1.7 was really built for revving, nearly the same HP, but less torque, the 1.8 not so much. This will change the way your tranny works with the motor; it'll bog and not work nearly as efficiently. _________________ '72 Elm Green Deluxe |
Posted: Sat May 23, 2015 8:26 am Post subject: |
yes, these are all the questions I've been asking myself, and feel the same way, thank you. I'm not sure on all the specs of the Porsche engine, I'm going to call the owner of it later on today and have a nice conversation on it.
He also says that my 1.8L is not worth rebuilding, that it was an unreliable engine to begin with. It all makes me very suspicious. My 1.8L engine code is:
ED210313
I looked it up, and correction, it's a 1975 1.8L
I'll post the specs of the Porsche engine after I speak to the guy. Thank you all, youve been very very helpful
Smitty |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 23, 2015 9:13 am Post subject: |
smitty1976bus wrote: |
ED210313...I looked it up, and correction, it's a 1975 1.8L |
Was that on the fan shroud? or on the actual case down between the fan shroud and breather tower?
Regardless you'll never be shure what it is until it's apart and measured, cases and fan shrouds get swapped.
A 1.7 isn't going to play well with your transmissions gearing (assuming you still have a 6 rib transmission), your best bang for the buck would be 2.0. The 1.8 would make a good base for a rebuild either as a 1.8 or 2.0 with different crank and rods. He's full of sh*t regarding the unreliability, they all run almost forever with good maintenance and the correct gearing or melt down fast with neglect and abuse regardless of size. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat May 23, 2015 9:18 am Post subject: |
ED210313
Smitty |
I for one and many others believe the 1.8 is the best air cooled engine VW ever made. More powerful than the 1700 so it doesn't need to be run as hard while not as prone to head problems as a 2.0. |
oorwullie Samba Member
Joined: May 01, 2003 Posts: 2365 Location: fribourg,switzerland
Posted: Sat May 23, 2015 9:31 am Post subject: |
i ran a W engine out of a 411 in my 75 6 rib westie. used all the original bus engine tin, heat exchangers etc and used solex carbs from an 1800 AP euro engine with carbed vanagon pointless (in europe) ignition.
after some trial and error with timing etc the bus went like a rocket and used barely any gas.
yes, i did find it helped to keep it revving.
the engine was a factory recon missing the injectors with barely any mileage on it that i scored for $100 from the basement of a local VW agency.
i thought i'd screwed it with hard driving and off the clock on the highway but when i took it out the bus i saw that my fresh 2k black was all burned away around the no.1 plug hole. simply a shorting plug cap.
i fitted a 2 litre then cos i had and still have plenty good engines but i still have the 1700 and might fit it somewhere again some day.
so i'd say if you have access to one for reasonable money and have a pair of functioning hands and braincells plus all the bay parts for a conversion then go for it.
but your engine specialist sounds like some kinda scammer to me, maybe take a knowledgable aquaintance with you to interogate him! |
Posted: Sat May 23, 2015 10:25 am Post subject: |
Wasted youth wrote: |
Thats the funny part.....there is no "Porsche" 1.7. Its, the same engine from case #s down to the last part # as the VW 411 and 412....and made on the same assembly line. The only 914 unique parts are a couple of sheet metal pieces and the reversed exhaust headers. Thats why I would be wary of high costs for the engine especially if used.
Great engines for lighter, higher geared cars....but not rare....not unique to Porsche and not worth excessive $. Ray |
Brian Samba Moderator
Posted: Sat May 23, 2015 11:39 am Post subject: Re: Is it ok to put a Porsche 1.7L in my 1978 Westy? |
is this a good deal? |
Not really. I'd just get your motor rebuilt then spend the extra money to get the heads spruced up for that extra power, if that's what you're going for. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Bleyseng Samba Member
Posted: Sat May 23, 2015 4:30 pm Post subject: |
Yes, Ray is right as the 914 and 411's used the same Djet 1.7L 80hp engine. The 1.8L was a Ljet engine for the 914, 411's and bus but the bus had slightly less CR.
The only true "Porsche" engine is the 2.0L 914 with the special 3 bolt intake heads. I have seen a couple of them run in a bus with some mods. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
morymob Samba Member
Posted: Sun May 24, 2015 6:01 am Post subject: |
Most engines of ANY type vehicles like the 914 have been driven hard put up wet, or of a different wording, had the crap run out of them,not a good trade in my2cts. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sun May 24, 2015 6:43 am Post subject: |
Riiiight. Then why does he want it? _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
cefalu Samba Member
Joined: May 14, 2012 Posts: 135 Location: San Francisco Bay Area, CA
Posted: Sun May 24, 2015 8:27 am Post subject: |
I have a 1.8 sourced from a 914 in my '74 Westfalia. It moves along just fine, I'm happy with the power.
I picked up the 914 1.8 that's in my bus on craigslist for $500. It had been recently rebuilt. The 1.8 heads have bigger valve's that the 2.0 heads.
The real problem is checking the oil. The 914's dipstick is on top and you need to open the engine hatch to check it, which is a pain if you are camping and have a bunch of stuff stored in the "wayback".
However, an ED engine code is for a 1975 bus motor, not a 914. Your dipstick should be in the correct place. The '75's had L-jet EFI. _________________ 1970 Jeepster Commando
1974 Volkswagen P27 Westfalia Camper
1974 Mercedes SL350 Euro Market Model
1974 Jeep J-20 ZZ
1985 Alfa Romeo GTV6
2005 Toyota 4Runner V8 Sport
2008 Mercedes E350 Wagon
2018 Lexus GX460 |
Posted: Sun May 24, 2015 8:49 am Post subject: |
morymob wrote: |
Actually its the other way around. 411 and 412 are roughly 2200 lbs....and the 914 ranged from 100-150 lbs less.
Both the 914 and 411/412 had higher gearing as well as the 914 had a five speed. So outside of shift points, general running of all other type 4 cars (411,412, 914) drove around with significantly lower cruising rpm, less than half the weight, much better aerodynamics. ....which corresponded to less chronic overheating etc.
From my experience....bus cases and heads with high miles are beat to shit. Outside of 2.0l 914 with the inherent cracking problems....its rare to find 914 engines with sunken valve seats etc. Ray |
