one4house Samba Member
Joined: July 18, 2009 Posts: 1121 Location: Sherman Texas
Posted: Sat May 23, 2015 3:12 pm Post subject: Type 1 vs Type 3 Square 4 bolt Rims |
4 bolt rims are the same between type 1 and type 3, correct? I am picking up another square, but the rims and tires Adee not part of the deal. I'm just making sure of my options.
This square is a 66, but it has been converted to late 4 bolt pattern. _________________ My Old 64 Field Find
My Old 66 Squareback
My Old 66 Beetle
My Old 70 Squareback |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Sat May 23, 2015 3:43 pm Post subject: |
My understanding is that the offset is different between Type 3 and Type 1 wheels. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Sat May 23, 2015 5:29 pm Post subject: |
type one rims are normally 4 inches wide and type three rims are 4.5 wide. the offset is is also different. _________________ 70 fastback automatic 06 invader |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
Posted: Sat May 23, 2015 9:53 pm Post subject: Re: Type 1 vs Type 3 Square 4 bolt Rims |
one4house wrote: |
This square is a 66, but it has been converted to late 4 bolt pattern. |
66 was the 1st year for 4 lug rims on a type 3. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun May 24, 2015 12:13 am Post subject: Re: Type 1 vs Type 3 Square 4 bolt Rims |
Bobnotch wrote: |
one4house wrote: |
66 was the 1st year for 4 lug rims on a type 3. |
Man, I'm learning something new all over this thread. Thank you. _________________ My Old 64 Field Find
My Old 66 Beetle
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Wed May 27, 2015 1:37 pm Post subject: |
Hi. The Bentley manual for 68 and later lists the wheel as a 4 1/2" with an offset of 46mm. Not sure if the earlier type 3 used the same wheel or the 4" wheel.
The type 1wheel, which may be more prevalent, showed different offsets for the 4" and 4 1/2" wheels. These offsets varied from 34mm to 46mm.
The Bentley for type 1's listed a 4" wheel with a 40mm offset. The 34mm offset wheel was for the latest cars, I believe.
I hope this helps, Bill. |
Randall Samba Member
Joined: October 03, 2004 Posts: 1402 Location: Orange County, Alta California, El Norte
Posted: Wed May 27, 2015 4:58 pm Post subject: |
Look at the two posts by Russ Wolfe: http://www.thesamba.com/vw/forum/viewtopic.php?t=271076
His first post says that genuine VW wheels have a stamp indicating the offset. His second post shows a page from the VW dealer parts book (that is likely found in more than one location on TheSamba) with a table showing the offset of Type 1-4 wheels. Take note of the "*" indicating 40 mm offset for Type 1 up to March 1972. |
